Hello again, this is the error that I get:
'‘VS-Rgn2kxVS_RtGnSp^2 must not be greater than VS-RtTq’
This is my .fst now:
Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf); Compatible with FAST v7.02.
False Echo - Echo input data to “echo.out” (flag)
1 AnalMode - Analysis mode {1: Run a time-marching simulation, 2: create a periodic linearized model} (switch)
3600.0 TMax - Total run time (s)
0.005 DT - Integration time step (s)
0 YCMode - Yaw control mode {0: none, 1: user-defined from routine UserYawCont, 2: user-defined from Simulink/Labview} (switch)
1 PCMode - Pitch control mode {0: none, 1: user-defined from routine PitchCntrl, 2: user-defined from Simulink/Labview} (switch)
1 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 2: user-defined from routine UserVSCont, 3: user-defined from Simulink/Labview} (switch)
1 HSSBrMode - HSS brake model {1: simple, 2: user-defined from routine UserHSSBr, 3: user-defined from Labview} (switch)
9999.9 TiDynBrk - Time to initiate deployment of the dynamic generator brake [CURRENTLY IGNORED] (s)
9999.9 TTpBrDp(1) - Time to initiate deployment of tip brake 1 (s)
9999.9 TTpBrDp(2) - Time to initiate deployment of tip brake 2 (s)
9999.9 TTpBrDp(3) - Time to initiate deployment of tip brake 3 (s) [unused for 2 blades]
9999.9 TBDepISp(1) - Deployment-initiation speed for the tip brake on blade 1 (rpm)
9999.9 TBDepISp(2) - Deployment-initiation speed for the tip brake on blade 2 (rpm)
9999.9 TBDepISp(3) - Deployment-initiation speed for the tip brake on blade 3 (rpm) [unused for 2 blades]
9999.9 TYawManE - Time at which override yaw maneuver reaches final yaw angle (s)
0.0 NacYawF - Final yaw angle for yaw maneuvers (degrees)
9999.9 TPitManE(1) - Time at which override pitch maneuver for blade 1 reaches final pitch (s)
9999.9 TPitManE(2) - Time at which override pitch maneuver for blade 2 reaches final pitch (s)
9999.9 TPitManE(3) - Time at which override pitch maneuver for blade 3 reaches final pitch (s) [unused for 2 blades]
0.0 BlPitch(1) - Blade 1 initial pitch (degrees)
0.0 BlPitch(2) - Blade 2 initial pitch (degrees)
0.0 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
0.0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
True YawDOF - Yaw DOF (flag)
0.0 RotSpeed - Initial or fixed rotor speed (rpm)
63.0 TipRad - The distance from the rotor apex to the blade tip (meters)
-5.01910 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5.0 ShftTilt - Rotor shaft tilt angle (degrees)
240.00E+3 NacMass - Nacelle mass (kg)
56.78E+3 HubMass - Hub mass (kg)
0.0 TipMass(1) - Tip-brake mass, blade 1 (kg)
0.0 TipMass(2) - Tip-brake mass, blade 2 (kg)
0.0 TipMass(3) - Tip-brake mass, blade 3 (kg) [unused for 2 blades]
2607.89E+3 NacYIner - Nacelle inertia about yaw axis (kg m^2)
115.926E+3 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
100.0 GBoxEff - Gearbox efficiency (%)
1.0 GBRatio - Gearbox ratio (-)
28.1162E+3 HSSBrTqF - Fully deployed HSS-brake torque (N-m)
“Dummy” DynBrkFi - File containing a mech-gen-torque vs HSS-speed curve for a dynamic brake [CURRENTLY IGNORED] (quoted string)
867.637E+6 DTTorSpr - Drivetrain torsional spring (N-m/rad)
6.215E+6 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
3 PtfmModel - Platform model {0: none, 1: onshore, 2: fixed bottom offshore, 3: floating offshore} (switch)
“Semisub_Platform.dat” PtfmFile - Name of file containing platform properties (quoted string) [unused when PtfmModel=0]
“Semisub_Tower.dat” TwrFile - Name of file containing tower properties (quoted string)
9028.32E+6 YawSpr - Nacelle-yaw spring constant (N-m/rad)
19.16E+6 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
0.0 YawNeut - Neutral yaw position–yaw spring force is zero at this yaw (degrees)
“Dummy” FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
0.0 TBDrConN - Tip-brake drag constant during normal operation, CdArea (m^2)
0.0 TBDrConD - Tip-brake drag constant during fully-deployed operation, CdArea (m^2)
0.0 TpBrDT - Time for tip-brake to reach full deployment once released (sec)
“Semisub_Blade.dat” BldFile(1) - Name of file containing properties for blade 1 (quoted string)
“Semisub_Blade.dat” BldFile(2) - Name of file containing properties for blade 2 (quoted string)
“Semisub_Blade.dat” BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
“Semisub_AeroDyn.ipt” ADFile - Name of file containing AeroDyn input parameters (quoted string)
“Dummy” NoiseFile - Name of file containing aerodynamic noise input parameters (quoted string) [used only when CompNoise=True]
“Semisub_ADAMSSpecific.dat” ADAMSFile - Name of file containing ADAMS-specific input parameters (quoted string) [unused when ADAMSPrep=1]
“Semisub_Linear.dat” LinFile - Name of file containing FAST linearization parameters (quoted string) [unused when AnalMode=1]
True SumPrint - Print summary data to “.fsm” (flag)
1 OutFileFmt - Format for tabular (time-marching) output file(s) (1: text file [.out], 2: binary file [.outb], 3: both) (switch)
True TabDelim - Use tab delimiters in text tabular output file? (flag)
“ES10.3E2” OutFmt - Format used for text tabular output (except time). Resulting field should be 10 characters. (quoted string) [not checked for validity!]
0.0 TStart - Time to begin tabular output (s)
100 DecFact - Decimation factor for tabular output {1: output every time step} (-)
1.0 SttsTime - Amount of time between screen status messages (sec)
1 NTwGages - Number of tower nodes that have strain gages for output [0 to 9] (-)
10 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
1 NBlGages - Number of blade nodes that have strain gages for output [0 to 9] (-)
9 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
OutList - The next line(s) contains a list of output parameters. See OutList.txt for a listing of available output channels, (-)
“WindVxi , WindVyi , WindVzi” - Longitudinal, lateral, and vertical wind speeds
“WaveElev” - Wave elevation at the platform reference point
“GenPwr , GenTq” - Electrical generator power and torque
“RotSpeed , GenSpeed” - Low-speed shaft and high-speed shaft speeds
“TipSpdRat, RotCp , RotCt , RotCq” - Rotor tip speed ratio and power, thrust, and torque coefficients
“PtfmSurge, PtfmSway , PtfmHeave” - Platform translational surge, sway, and heave displacements
“PtfmRoll , PtfmPitch, PtfmYaw” - Platform rotational roll, pitch and yaw displacements
“Fair1Ten , Fair1Ang , Anch1Ten , Anch1Ang” - Line 1 fairlead and anchor effective tensions and vertical angles
“Fair2Ten , Fair2Ang , Anch2Ten , Anch2Ang” - Line 2 fairlead and anchor effective tensions and vertical angles
“Fair3Ten , Fair3Ang , Anch3Ten , Anch3Ang” - Line 3 fairlead and anchor effective tensions and vertical angles
“Fair4Ten , Fair4Ang , Anch4Ten , Anch4Ang” - Line 3 fairlead and anchor effective tensions and vertical angles
“NacYaw , NacYawErr” - Nacelle yaw angle and nacelle yaw error estimate
END of FAST input file (the word “END” must appear in the first 3 columns of this last line).
“OoPDefl1 , IPDefl1 , TwstDefl1” - Blade 1 out-of-plane and in-plane deflections and tip twist
“OoPDefl2 , IPDefl2 , TwstDefl2” - Blade 2 out-of-plane and in-plane deflections and tip twist
“OoPDefl3 , IPDefl3 , TwstDefl3” - Blade 3 out-of-plane and in-plane deflections and tip twist
“TwrClrnc1, TwrClrnc2, TwrClrnc3” - Tip-to-tower clearance estimate for blades 1, 2, and 3
“NcIMUTAxs, NcIMUTAys, NcIMUTAzs” - Nacelle IMU translational accelerations (absolute) in the nonrotating, shaft coordinate system
“TTDspFA , TTDspSS , TTDspTwst” - Tower fore-aft and side-to-side displacements and top twist
“PtfmTAxt , PtfmTAyt , PtfmTAzt” - Platform translation accelerations (absolute) in the tower-base coordinate system
“RootFxc1 , RootFyc1 , RootFzc1” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 1
“RootMxc1 , RootMyc1 , RootMzc1” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 1
“RootFxc2 , RootFyc2 , RootFzc2” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 2
“RootMxc2 , RootMyc2 , RootMzc2” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 2
“RootFxc3 , RootFyc3 , RootFzc3” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 3
“RootMxc3 , RootMyc3 , RootMzc3” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 3
“Spn1MLxb1, Spn1MLyb1, Spn1MLzb1” - Blade 1 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLxb2, Spn1MLyb2, Spn1MLzb2” - Blade 2 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLxb3, Spn1MLyb3, Spn1MLzb3” - Blade 3 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“RotThrust, LSSGagFya, LSSGagFza” - Rotor thrust and low-speed shaft 0- and 90-rotating shear forces at the main bearing
“RotTorq , LSSGagMya, LSSGagMza” - Rotor torque and low-speed shaft 0- and 90-rotating bending moments at the main bearing
“YawBrFxp , YawBrFyp , YawBrFzp” - Fore-aft shear, side-to-side shear, and vertical forces at the top of the tower (not rotating with nacelle yaw)
“YawBrMxp , YawBrMyp , YawBrMzp” - Side-to-side bending, fore-aft bending, and yaw moments at the top of the tower (not rotating with nacelle yaw)
“TwrBsFxt , TwrBsFyt , TwrBsFzt” - Fore-aft shear, side-to-side shear, and vertical forces at the base of the tower (platform)
“TwrBsMxt , TwrBsMyt , TwrBsMzt” - Side-to-side bending, fore-aft bending, and yaw moments at the base of the tower (platform)
“TwHt1MLxt, TwHt1MLyt, TwHt1MLzt” - Local side-to-side bending, fore-aft bending, and yaw moments at tower gage 1 (approx. 50% elevation)
“Wave1Vxi , Wave1Vyi , Wave1Vzi” - Longitudinal, lateral, and vertical wave particle velocities at platform node 1 (approx. platform reference point)
“Wave1Axi , Wave1Ayi , Wave1Azi” - Longitudinal, lateral, and vertical wave particle accelerations at platform node 1 (approx. platform reference point)
“HSSBrTq” - High-speed shaft brake torque
“BldPitch1, BldPitch2, BldPitch3” - Pitch angles for blades 1, 2, and 3
“Azimuth” - Blade 1 azimuth angle
