Dear everyone,
I ran my fast model and found that the power generation was 0. I checked servo and elastdyn and did not find any problems. I hope to get everyone’s help. Thank you very much!
------- OpenFAST INPUT FILE -------------------------------------------
False Echo - Echo input data to <RootName>.ech (flag)
"FATAL" AbortLevel - Error level when simulation should abort (string) {"WARNING", "SEVERE", "FATAL"}
3600 TMax - Total run time (s)
0.01 DT - Integration time step (s)
99999.0 DT_UJac - Time between calls to get Jacobians (s)
1000000.0 UJacSclFact - Scaling factor used in Jacobians (-)
0 CompInflow - Compute inflow wind velocities (switch) {0=still air; 1=InflowWind; 2=external from OpenFOAM}
1 CompHydro - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
0 CompSub - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn; 2=External Platform MCKF}
3 CompMooring - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
0 MHK - MHK turbine type (switch) {0=Not an MHK turbine; 1=Fixed MHK turbine; 2=Floating MHK turbine}
Omitted here, thank you
"IEA-15-240-RWT-UMaineSemi_ElastoDyn.dat" EDFile - Name of file containing ElastoDyn input parameters (quoted string)
"../IEA-15-240-RWT/IEA-15-240-RWT_InflowFile.dat" InflowFile - Name of file containing inflow wind input parameters (quoted string)
"IEA-15-240-RWT-UMaineSemi_AeroDyn15.dat" AeroFile - Name of file containing aerodynamic input parameters (quoted string)
"IEA-15-240-RWT-UMaineSemi_ServoDyn.dat" ServoFile - Name of file containing control and electrical-drive input parameters (quoted string)
"IEA-15-240-RWT-UMaineSemi_HydroDyn.dat" HydroFile - Name of file containing hydrodynamic input parameters (quoted string)
"none" SubFile - Name of file containing sub-structural input parameters (quoted string)
"IEA-15-240-RWT-UMaineSemi_MoorDyn_v2_30mPolyester.dat" MooringFile - Name of file containing mooring system input parameters (quoted string)
"none" IceFile - Name of file containing ice input parameters (quoted string)
------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
"default" DT - Communication interval for controllers (s) (or "default")
5 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
2.0 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
2.0 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
2.0 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
0.0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
5 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
1 GenModel - Generator model {1: simple, 2: Thevenin, 3: user-defined from routine UserGen} (switch) [used only when VSContrl=0]
95.756 GenEff - Generator efficiency [ignored by the Thevenin and user-defined generator models] (%)
7.559987120819503 VS_RtGnSp - Rated generator speed for simple variable-speed generator control (HSS side) (rpm) [used only when VSContrl=1]
19624046.66639 VS_RtTq - Rated generator torque/constant generator torque in Region 3 for simple variable-speed generator control (HSS side) (N-m) [used only when VSContrl=1]
343357.4355671095 VS_Rgn2K - Generator torque constant in Region 2 for simple variable-speed generator control (HSS side) (N-m/rpm^2) [used only when VSContrl=1]
2. VS_SlPc - Rated generator slip percentage in Region 2 1/2 for simple variable-speed generator control (%) [used only when VSContrl=1]
100 TEC_NPol - Number of poles [even integer > 0] (-) [used only when VSContrl=0 and GenModel=2]
9999.9 HSSBrDT - Time for HSS-brake to reach full deployment once initiated (sec) [used only when HSSBrMode=1]
9999.9 HSSBrTqF - Fully deployed HSS-brake torque (N-m)
0.0 YawNeut - Neutral yaw position--yaw spring force is zero at this yaw (degrees)
8458453511.0 YawSpr - Nacelle-yaw spring constant (N-m/rad)
28561762.0 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
0.25 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
---------------------- Aerodynamic Flow Control -------------------------------------
0 AfCmode - Airfoil control mode {0- none, 1- cosine wave cycle, 4- user-defined from Simulink/Labview, 5- user-defined from Bladed-style DLL}
0.0 AfC_Mean - Mean level for sinusoidal cycling or steady value (-) [used only with AfCmode==1]
0.0 AfC_Amp - Amplitude for for cosine cycling of flap signal (AfC = AfC_Amp*cos(Azimuth+phase)+AfC_mean) (-) [used only with AfCmode==1]
0.0 AfC_phase - Phase relative to the blade azimuth (0 is vertical) for for cosine cycling of flap signal (deg) [used only with AfCmode==1]
---------------------- STRUCTURAL CONTROL ---------------------------------------
0 NumBStC - Number of blade structural controllers (integer)
"unused" BStCfiles - Name of the file for blade tuned mass damper (quoted string) [unused when CompNTMD is false]
0 NumNStC - Number of nacelle structural controllers (integer)
"unused" NStCfiles - Name of the file for nacelle tuned mass damper (quoted string) [unused when CompNTMD is false]
0 NumTStC - Number of tower structural controllers (integer)
"unused" TStCfiles - Name of the file for tower tuned mass damper (quoted string) [unused when CompNTMD is false]
0 NumSStC - Number of sbustructure structural controllers (integer)
"unused" SStCfiles - Name of the file for sbustructure tuned mass damper (quoted string) [unused when CompNTMD is false]
---------------------- CABLE CONTROL ----------------------------------------
0 CCmode - Cable control mode {0- none, 4- user-defined from Simulink/Labview, 5- user-defineAfC_phased from Bladed-style DLL}
"../IEA-15-240-RWT/ServoData/libdiscon.dll" DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
"IEA-15-240-RWT-UMaineSemi_DISCON.IN" DLL_InFile - Name of input file sent to the DLL (-) [used only with Bladed Interface]
"DISCON" DLL_ProcName - Name of procedure in DLL to be called (-) [case sensitive; used only with DLL Interface]
"default" DLL_DT - Communication interval for dynamic library (s) (or "default") [used only with Bladed Interface]
False DLL_Ramp - Whether a linear ramp should be used between DLL_DT time steps [introduces time shift when true] (flag) [used only with Bladed Interface]
9999.9 BPCutoff - Cuttoff frequency for low-pass filter on blade pitch from DLL (Hz) [used only with Bladed Interface]
0.0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0.0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0.0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0.0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0.0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0.0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
0.0 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
0.0 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
0.0 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
0.0 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
0.0 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
0.0 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
True SumPrint - Print summary data to <RootName>.sum (flag) (currently unused)
"ES10.3E2" OutFmt - Format used for text tabular output (except time). Resulting field should be 10 characters. (quoted string) (currently unused)
30.0 TStart - Time to begin tabular output (s) (currently unused)
OutList - The next line(s) contains a list of output parameters.
"GenPwr"
"GenTq"
END of input file (the word "END" must appear in the first 3 columns of this last Out_List line)
False Echo - Echo input data to "<RootName>.ech" (flag)
"default" DT Integration time step (s)
False YawDOF - Yaw DOF (flag)
0 RotSpeed - Initial or fixed rotor speed (rpm)
0 PtfmSurge
0 PtfmSway
0 PtfmHeave
0 PtfmRoll
0 PtfmPitch
0 PtfmYaw
120.97 TipRad - The distance from the rotor apex to the blade tip (meters)
3.97 HubRad - The distance from the rotor apex to the blade root (meters)
-4 PreCone(1) - Blade 1 cone angle (degrees)
-4 PreCone(2) - Blade 2 cone angle (degrees)
-4 PreCone(3) - Blade 3 cone angle (degrees) [unused for 2 blades]
-12.098 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
0.0 ShftGagL - Distance from rotor apex [3 blades] or teeter pin [2 blades] to shaft strain gages [positive for upwind rotors] (meters)
-6.0 ShftTilt - Rotor shaft tilt angle (degrees)
-4.7201 NacCMxn - Downwind distance from the tower-top to the nacelle CM (meters)
4.2751 NacCMzn - Vertical distance from the tower-top to the nacelle CM (meters)
0.0 NcIMUxn - Downwind distance from the tower-top to the nacelle IMU (meters)
0.0 NcIMUzn - Vertical distance from the tower-top to the nacelle IMU (meters)
4.3495 Twr2Shft - Vertical distance from the tower-top to the rotor shaft (meters)
144.386 TowerHt - Height of tower above ground level [onshore] or MSL [offshore] (meters)
15 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
-14.400 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
69360 HubMass - Hub mass (kg)
973520 HubIner - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
1836784 GenIner - Generator inertia about HSS (kg m^2)
646895 NacMass - Nacelle mass (kg)
24240914 NacYIner - Nacelle inertia about yaw axis (kg m^2)
28280 YawBrMass - Yaw bearing mass (kg)
1.7838E+07 PtfmMass - Platform mass (kg)
1.2507E+10 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
1.2507E+10 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
2.3667E+10 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
50 BldNodes - Number of blade nodes (per blade) used for analysis (-)
"../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat" BldFile1 - Name of file containing properties for blade 1 (quoted string)
"../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat" BldFile2 - Name of file containing properties for blade 2 (quoted string)
"../IEA-15-240-RWT/IEA-15-240-RWT_ElastoDyn_blade.dat" BldFile3 - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
1 GBRatio - Gearbox ratio (-)
51140939610 DTTorSpr - Drivetrain torsional spring (N-m/rad)
42676833 DTTorDmp - Drivetrain torsional damper (N-m/(rad/s))
"unused" FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
"IEA-15-240-RWT-UMaineSemi_ElastoDyn_tower.dat" TwrFile - Name of file containing tower properties (quoted string)
