Dear Jason
my name is masataka
I’d like to know the detatil settings of nrel.gov/docs/fy09osti/38060.pdf in FAST V8.
now I’m calculating the power Curve but it’s just rise leave or constant value.
So I want to know the settings of normal power curve that is rise from cut in and rated constant value.
my settings is below. could you correct my settings?
------- AERODYN v15.03.* INPUT FILE ------------------------------------------------
“default” DTAero - Time interval for aerodynamic calculations {or “default”} (s)
0 WakeMod - !!0Type of wake/induction model (switch) {0=none, 1=BEMT}
1 AFAeroMod - !!1Type of blade airfoil aerodynamics model (switch) {1=steady model, 2=Beddoes-Leishman unsteady model}
1 TwrPotent - !!1Type tower influence on wind based on potential flow around the tower (switch) {0=none, 1=baseline potential flow, 2=potential flow with Bak correction}
False TwrShadow - !!TrueCalculate tower influence on wind based on downstream tower sh
False TwrAero - !!TrueCalculate tower aerodynamic loads? (flag)
2 SkewMod - Type of skewed-wake correction model (switch) {1=uncoupled, 2=Pitt/Peters, 3=coupled} [used only when WakeMod=1]
true TanInd - Include tangential induction in BEMT calculations? (flag) [used only when WakeMod=1]
False AIDrag - !!FalseInclude the drag term in the axial-induction calculation? (flag) [used only when WakeMod=1]
False TIDrag - !!FalseInclude the drag term in the tangential-induction calculation? (flag) [used only when WakeMod=1 and TanInd=TRUE]
“Default” IndToler - Convergence tolerance for BEMT nonlinear solve residual equation {or “default”} (-) [used only when WakeMod=1]
100 MaxIter - Maximum number of iteration steps (-) [used only when WakeMod=1]
3 UAMod - !!3Unsteady Aero Model Switch (switch) {1=Baseline model (Original), 2=Gonzalez痴 variant (changes in Cn,Cc,Cm), 3=Minemma/Pierce variant (changes in Cc and Cm)} [used only when AFAeroMod=2]
True FLookup - Flag to indicate whether a lookup for f’ will be calculated (TRUE) or whether best-fit exponential equations will be used (FALSE); if FALSE S1-S4 must be provided in airfoil input files (flag) [used only when AFAeroMod=2]
“Airfoils/profile100.dat” AFNames - Airfoil file names (NumAFfiles lines) (quoted strings)
“Airfoils/profile45.dat”
“Airfoils/profile35.dat”
“Airfoils/profile30.dat”
“Airfoils/profile25.dat”
“Airfoils/profile21.dat”
“Airfoils/profile20.dat”
“Airfoils/profile16.dat”
“NRELOffshrBsline5MW_AeroDyn_blade.dat” ADBlFile(1) - Name of file containing distributed aerodynamic properties for Blade #1 (-)
“NRELOffshrBsline5MW_AeroDyn_blade.dat” ADBlFile(2) - Name of file containing distributed aerodynamic properties for Blade #2 (-) [unused if NumBl < 2]
“NRELOffshrBsline5MW_AeroDyn_blade.dat” ADBlFile(3) - Name of file containing distributed aerodynamic properties for Blade #3 (-) [unused if NumBl < 3]
NREL 5.0 MW Baseline Wind Turbine for Use in Offshore Analysis. Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf).
“DEFAULT” DT - Integration time step (s)
False YawDOF - Yaw DOF (flag)
0 RotSpeed - Initial or fixed rotor speed (rpm)
0.0 PtfmSurge - Initial or fixed horizontal surge translational displacement of platform (meters)
0.0 PtfmHeave - Initial or fixed vertical heave translational displacement of platform (meters)
0.0 PtfmRoll - Initial or fixed roll tilt rotational displacement of platform (degrees)
0.0 PtfmPitch - Initial or fixed pitch tilt rotational displacement of platform (degrees)
2 NumBl - Number of blades (-)
71.5 TipRad - (63!!)The distance from the rotor apex to the blade tip (meters)
9 PreCone(1) - Blade 1 cone angle (degrees)
9 PreCone(2) - Blade 2 cone angle (degrees)
0 PreCone(3) - Blade 3 cone angle (degrees) [unused for 2 blades]
5.0191 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-1.912 ShftGagL - Distance from rotor apex [3 blades] or teeter pin [2 blades] to shaft strain gages [positive for upwind rotors] (meters)
5.0 ShftTilt - Rotor shaft tilt angle (degrees)
95.00 TowerHt - Height of tower above ground level [onshore] or MSL [offshore] (meters)
0 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
-6.7225 PtfmCMxt - Downwind distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
0.0000 PtfmCMyt - Lateral distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
-11.5595 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
56780 HubMass - Hub mass (kg)
2.60789E+06 NacYIner - Nacelle inertia about yaw axis (kg m^2)
0 YawBrMass - Yaw bearing mass (kg)
0.23132E+07 PtfmMass - Platform mass (kg)
0.12577E+10 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
0.19391E+10 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
0.25795E+10 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
17 BldNodes - Number of blade nodes (per blade) used for analysis (-)
“NRELOffshrBsline5MW_Blade.dat” BldFile(1) - Name of file containing properties for blade 1 (quoted string)
“NRELOffshrBsline5MW_Blade.dat” BldFile(2) - Name of file containing properties for blade 2 (quoted string)
“NRELOffshrBsline5MW_Blade.dat” BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
90 GBoxEff - Gearbox efficiency (%)
97 GBRatio - !!23.178Gearbox ratio (-)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
“DEFAULT” DT - Communication interval for controllers (s) (or “default”)
0 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
114 TPCOn - Time to enable active pitch control (s) [unused when PCMode=0]
99999.9 TPitManS(1) - Time to start override pitch maneuver for blade 1 and end standard pitch control (s)
99999.9 TPitManS(2) - Time to start override pitch maneuver for blade 2 and end standard pitch control (s)
99999.9 TPitManS(3) - Time to start override pitch maneuver for blade 3 and end standard pitch control (s) [unused for 2 blades]
8 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
8 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
8 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
90 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
90 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
90 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
5 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
False GenTiStr - Method to start the generator {T: timed using TimGenOn, F: generator speed using SpdGenOn} (flag)
6.9 SpdGenOn - Generator speed to turn on the generator for a startup (HSS speed) (rpm) [used only when GenTiStr=False]
1161.963 VS_RtGnSp - Rated generator speed for simple variable-speed generator control (HSS side) (rpm) [used only when VSContrl=1]
43093.55 VS_RtTq - Rated generator torque/constant generator torque in Region 3 for simple variable-speed generator control (HSS side) (N-m) [used only when VSContrl=1]
0.0255764 VS_Rgn2K - Generator torque constant in Region 2 for simple variable-speed generator control (HSS side) (N-m/rpm^2) [used only when VSContrl=1]
10 VS_SlPc - Rated generator slip percentage in Region 2 1/2 for simple variable-speed generator control (%) [used only when VSContrl=1]
0 THSSBrDp - Time to initiate deployment of the HSS brake (s)
0 HSSBrDT - Time for HSS-brake to reach full deployment once initiated (sec) [used only when HSSBrMode=1]
116.2 HSSBrTqF - Fully deployed HSS-brake torque (N-m)
0 YawNeut - Neutral yaw position–yaw spring force is zero at this yaw (degrees)
9.02832E+09 YawSpr - Nacelle-yaw spring constant (N-m/rad)
1.916E+07 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
99999.9 TYawManS - Time to start override yaw maneuver and end standard yaw control (s)
0.3 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
0 NacYawF - Final yaw angle for override yaw maneuvers (degrees)
---------------------- TUNED MASS DAMPER ---------------------------------------
False CompNTMD - Compute nacelle tuned mass damper {true/false} (flag)
“unused” NTMDfile - Name of the file for nacelle tuned mass damper (quoted string) [unused when CompNTMD is false]
False CompTTMD - Compute tower tuned mass damper {true/false} (flag)
“unused” TTMDfile - Name of the file for tower tuned mass damper (quoted string) [unused when CompTTMD is false]
“ServoData/DISCON_OC3Hywind_x64.dll” DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
“DISCON.IN” DLL_InFile - Name of input file sent to the DLL (-) [used only with Bladed Interface]
“DISCON” DLL_ProcName - Name of procedure in DLL to be called (-) [case sensitive; used only with DLL Interface]
114 DLL_DT - "default"Communication interval for dynamic library (s) (or “default”) [used only with Bladed Interface]
true DLL_Ramp - Whether a linear ramp should be used between DLL_DT time steps [introduces time shift when true] (flag) [used only with Bladed Interface]
0.25 BPCutoff - Cuttoff frequency for low-pass filter on blade pitch from DLL (Hz) [used only with Bladed Interface]
0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
100 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
6.9 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
12.1 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
871 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
43093.55 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
1000000 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
