Dear all:
I have 3 problems while using openfast regarding aerodynamic loadings, it will be greatly appreciated if you can have the those solved.
Question1:
I have a problem when calculation the yaw bearing loads the 15MW NREL reference turbine in a parked condition(wind speed is 50 m/s), I’m investigating the loads of six dofs, but there is a significant difference between the the YawBrMyn and RtAeroMyh , YawBrMzn and Rt AeroMzh results in different wind propagating directions , small differences also occurred for Mx, while the results of Fx, Fy, agree quite well, similar phenomenon occurs for power generation conditions as well, it seems that the gravity contribution was considered for YawBr My, for the parked condition, I’d already turn off the dofs for blades and tower in elasdyn and switch the wake mode to 0 in areodyn, but I keep the default ShftTilt value. What else do I need to do the get the discrepancies eliminated? The results comparison is shown below (In the plots above, the labels for the x axis are wind propagation direction instead of angle of attack).
Question2:
I want to provide wind loads acting on the blades and RNA for mooring analysis in a parked condition, which is performed in Orcaflex ( decoupled analysis), is it reasonable for me to use the YawBrXXn or AeroXXh results as illustrated above? And is the trend of results I reach above (RtAero results) varying with different angles of attack reasonable?
Question3:
If I want to take into account the wind load effect on the nacelle, how shall I model it in openfast?
Followings are my calculation files for the parked condition.
Yajun
