Hello you all. I need to do the yaw control with YCMode 4 (Simulink/Labview) and to activate it I set True the YawDOF on ElastoDyn.
True Echo - Echo input data to "<RootName>.ech" (flag)
0.0001 DT - Integration time step (s)
True YawDOF - Yaw DOF (flag)
False PtfmSgDOF - Platform horizontal surge translation DOF (flag)
False PtfmSwDOF - Platform horizontal sway translation DOF (flag)
But I have this error on the S-Function:
Error:An error occurred while running the simulation and the simulation was terminated
Caused by:
Error reported by S-function ‘FAST_SFunc’ in ‘fast_sim_actyaw/FAST Nonlinear Wind Turbine/S-Function’:
FAST_Solution:FAST_AdvanceStates:AD_UpdateStates:BEMT_UpdateStates(node 2, blade 1):BEMT_UnCoupledSolve:DeterminePhiBounds:There is no valid value of phi for these operating conditions! Vx = NaN, Vy = NaN, rlocal = NaN, theta = 0.19784.
Thanks in advance
