Wrong settings for yaw controll?
Hi there,
I am brand new to the work with FAST and very happy about the good documentation. Thanks a lot for that!
In the first step I tried to simulate some time series with the NREL 5 MW plant and default settings. In the documentation of the NREL 5 MW I found this:
But I want to test it with a yawing nacelle. Therefore I ran the simulation with different given options of YCMode in the ServoDyn.dat file:
[code]------- SERVODYN V1.02.* INPUT FILE --------------------------------------------
“default” DT - Communication interval for controllers (s)
5 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TPCOn - Time to enable active pitch control (s) [unused when PCMode=0]
2 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
2 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
2 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
5 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TimGenOn - Time to turn on the generator for a startup (s) [used only when GenTiStr=True]
5 YCMode - Yaw control mode {0: none, 1: simple, 3: user-defined from routine UserYawCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TYCOn - Time to enable active yaw control (s) [unused when YCMode=0]
0 YawNeut - Neutral yaw position–yaw spring force is zero at this yaw (degrees)
9.02832E+09 YawSpr - Nacelle-yaw spring constant (N-m/rad)
1.916E+07 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
2 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
0 NacYawF - Final yaw angle for override yaw maneuvers (degrees)
---------------------- TUNED MASS DAMPER ---------------------------------------
False CompNTMD - Compute nacelle tuned mass damper {true/false} (flag)
“NREL5MW_ServoDyn_TMD.dat” NTMDfile - Name of the file for nacelle tuned mass damper (quoted string) [unused when CompNTMD is false]
---------------------- BLADED INTERFACE ----------------------------------------
“ServoData\DISCON_win32.dll” DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
0 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
0 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
0 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
0 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
0 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
0 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
True SumPrint - Print summary data to .sum (flag) (currently unused)
0 TStart - Time to begin tabular output (s) (currently unused)
“GenPwr” - Electrical generator power and torque
“GenTq” - Electrical generator power and torque
“YawMomCom” - Nacelle yaw moment command
“NTMD_XQ, NTMD_XQD”
“NTMD_YQ, NTMD_YQD”
[/code]
Only the option 5 user-defined from Bladed-style DLL enabled a yawing nacelle. Is that normal? I expected a yawing nacelle at least to the option 1 simple.
After the simulation with option 5 I noticed a wrong yaw position YawPzn (like in the graph above). The wind direction is constant with 0 deg, but the nacelle yaws anyways to about -3.5 deg. Most likely I did something wrong in the settings in the ServoDyn.dat file? Can anybody give me some tips how I can use a yaw controller or do I have to write my own with UserYawCont()?
Thanks for help.
[1] Jonkman, J.; et al.: Definition of a 5-MW Reference Wind Turbine for Offshore System Development, 02.2009
Dear Achim,
You shouldn’t select YCMode = 5 (user-defined yaw control from Bladed-style DLL) unless you’ve compiled your own Bladed-style DLL with your own yaw controller. You appear to be using the default NREL 5-MW Bladed-style DLL controller, which does not control yaw. (Instead, the default NREL 5-MW Bladed-style DLL controller always commands the yaw rate to be zero, and ServoDyn will treat this as a command to maintain the current yaw angle, which can lead to a small drift in the yaw angle over time.)
There is currently no implementation in ServoDyn for YCMode = 1 (simple), so, you shouldn’t select that either.
You can use the override yaw maneuvers (via ServoDyn input parameters TYawManS, YawManRat, and NacYawF) to force simple linear yaw ramps.
If you need more sophisticated yaw action than what is possible with the override yaw maneuvers, you will have to define your own yaw-control logic either in UserYawCont (YCMode = 3), Simulink (YCMode = 4), or a Bladed-style DLL (YCMode = 5).
thank you for your fast reply. In this case I have to find out how to compile FAST (makefile) with gfortran to specify the UserYawCont() in UserSubs.f90.
I already read the CompilingInstructions_FASTv8.pdf., downloaded and installed MinGW w64 for my windows 8 64 bit computer. I also downloaded the required dll’s and lib’s, described in the pdf and modified the makefile for 64bit with the appropriate path for the liblapack.lib etc.:
   # 32-bit or 64-bit?
#BITS = 32
BITS = 64
   # Location of source files for FAST, and its modules.
FAST_DIR     = ../Source
NWTC_Lib_DIR = $(FAST_DIR)/dependencies/NWTC_Library
NETLIB_DIR   = $(FAST_DIR)/dependencies/NetLib
ED_DIR       = $(FAST_DIR)/dependencies/ElastoDyn
SrvD_DIR     = $(FAST_DIR)/dependencies/ServoDyn
AD_DIR       = $(FAST_DIR)/dependencies/AeroDyn
IfW_DIR      = $(FAST_DIR)/dependencies/InflowWind
HD_DIR       = $(FAST_DIR)/dependencies/HydroDyn
SD_DIR       = $(FAST_DIR)/dependencies/SubDyn
MAP_DIR      = $(FAST_DIR)/dependencies/MAP
FEAM_DIR     = $(FAST_DIR)/dependencies/FEAMooring
MD_DIR       = $(FAST_DIR)/dependencies/MoorDyn
IceF_DIR     = $(FAST_DIR)/dependencies/IceFloe
IceD_DIR     = $(FAST_DIR)/dependencies/IceDyn
TMD_DIR      = $(SrvD_DIR)
DWM_DIR      = $(AD_DIR)
HD_DIR_Reg   = $(HD_DIR)
IfW_DIR_Reg  = $(IfW_DIR)
BIN_DIR      = ../bin
   # Names and locations of the Registry, MAP libraries, and instructions for linking with LAPACK.
   # You will probably need to change these for your system.
ifeq ($(OS),Windows_NT)
   Registry     = $(BIN_DIR)/Registry_win32.exe
   MAP_lib      = $(MAP_DIR)/MAP_x64.lib
   LAPACK_LINK  = -llapack -lblas -LC:/LAPACK/x64
   #MAP_lib      = $(MAP_DIR)/MAP_Win32.lib
   #LAPACK_LINK  = -llapack -lblas -LC:/LAPACK/win32
else
   Registry     = registry.exe
   MAP_lib      = $(MAP_DIR)/MAP.so
endif
   # Name of compiler to use and flags to use.
FC      = gfortran
FFLAGS = -g -O0 -fbacktrace -ffree-line-length-none -x f95-cpp-input -fcheck=all
LDFLAGS = -O2 -m$(BITS) -fbacktrace
#FC      = gfortran
#FFLAGS  = -O2 -m$(BITS) -fbacktrace -ffree-line-length-none -x f95-cpp-input
#LDFLAGS = -O2 -m$(BITS) -fbacktrace -Wl,--stack=999999999,--large-address-aware
#FFLAGS  = -O0 -m$(BITS) -fbacktrace -ffree-line-length-none -x f95-cpp-input -g -pg
#LDFLAGS = -O0 -m$(BITS) -fbacktrace -Wl,--stack=999999999,--large-address-aware -g -pg
#-DDOUBLE_PRECISION
# -mthreads
# some useful gfortran options:
#  -DFPE_TRAP_ENABLED
#  -Wl,--large-address-aware   # not necessary when $(BITS) is 64 (64-bit target)
#  -Wl,--stack=999999999       # not necessary when $(BITS) is 64
#  -Wconversion-extra -Wconversion
#  -fdefault-real-8 -fcheck=bounds,do,mem,pointer -std=f2003 -O0 -v -Wall
#  -pg                          # generate debugging info for debugger
# http://gcc.gnu.org/onlinedocs/gfortran/Option-Index.html#Option-Index
# makefile:
# --warn-undefined-variables
   # Destination and RootName for executable
OUTPUT_NAME = FAST
DEST_DIR    = ..\bin
But I don’t know the next step. Neither the command ggc makefile , gfortran makefile nor make in the command prompt does compile FAST.
As you see I am also new to use compilers. I am very grateful for more assistance.
Achim,
I answered your similar compiling question here: Compiling Fast v8 using gfortran
The command you need is mingw32-make
Dear @Jason.Jonkman
I am studying some parameters of the ServoDyn module in OpenFAST v3.5.3. My wind turbine is the NREL onshore 5MW baseline wind turbine, and in the "BLADED INTERFACE” module, the “DLL_FileName” is set to DISCON.dll from this link (https://openfast.readthedocs.io/en/main/source/install/index.html). I have the following four questions, and are they correct?
  1. Even when YCMode=5, automatic yaw alignment to wind direction cannot be achieved, because I have not seen where the parameter for yaw error (the angle between wind direction and turbine axis not exceeding a certain value, such as ±15°) is input. To implement fixed yaw, the following parameters can be input, or more complex adjustments can be made by recompiling the source code.
  2. When PCMode = 5, it can automatically achieve maximum power below the rated wind speed, with constant power above the rated wind speed. However, the requirement for pitch rate is ignored, such as the 8°/s from Table 7-2 on page 27 of the “Definition of a 5-MW Reference Wind Turbine for Offshore System Development” report.
  3. For VSContrl = 5, HSSBrMode = 5, and HSSBrMode = 5, these functions can be selectively used to assist with the turbine’s control requirements, i.e., achieving maximum power below the rated wind speed and constant power above the rated wind speed. However, these requirements can also be achieved with HSSBrMode = 0 or HSSBrMode = 0.
  4. The parameters of “BLADED INTERFACE”, shown in the red box of the figure below, are currently unavailable in FAST and are only some parameters of the GH Blade model.
Dear @Yangyang.Li
Hope you are doing well.
I am not from NREL staff. But, i think i can respond to your first question.
1- As stated earlier by @Jason.Jonkman, the NREL baseline controller does not have the capacity to control yaw of the nacelle. Indeed, if you enable NacelleYaw DoF in ElastoDyn, you will obtain nacelle yaw different from zero due to gyroscopic yaw moment.
So, if you are not interested in studying nacelle yaw, i would simply recommend to set the Nacelle Yaw DoF in ElastoDyn to False and set YCMode in ServoDyn to 0.
Hope this can help.
Best Regards
Riad
Dear @Yangyang.Li,
Thanks, Riad.
Here are my responses:
  1. I agree with @Riad.Elhamoud that the original baseline controller DISCON.dll for the NREL 5-MW wind turbine does not have active yaw control as an option. If you want active yaw control, you can either implement your own logic, or switch from the original controller to ROSCO: GitHub - NREL/ROSCO: A Reference Open Source Controller for Wind Turbines.
  2. I’m not sure why you say that the 8deg/s pitch rate limit will be ignored, but the original baseline controller for the NREL 5-MW wind turbine does enforce this pitch rate limit.
  3. The original baseline controller for the NREL 5-MW wind turbine does not support engagement of the high-speed shaft brake. In fact, this brake would not be deployed for this turbine, or most utility-scale wind turbines, except during maintenance operations.
  4. The original baseline controller for the NREL 5-MW wind turbine does not make use of the parameters below BPCutoff in the BLADED INTERFACE section of the ServoDyn input file. Whether a Bladed-style dynamic library makes use of these inputs will depend on the specific dynamic library you are using (user defined).
Dear @Jason.Jonkman
Thank you for your prompt responses @Riad.Elhamoud & Jason.Jonkman . However, I still have some questions as follows, and are they correct?
  1. Since the original baseline controller does not have yaw control capability, the nacelle axis will actually rotate and translates along the principle axis of the tower top cross-section, rather than moving according to the instantaneous wind direction if PropagationDir = NacYaw (ElastoDyn) = YawNeut = 0 deg. In this case, it can be understood that YawDOF = false, in fact.
  2. For the 8 deg/s pitch rate limit, I calculated a case using a steady wind of 20 m/s without shear effect, yaw=PreCone(1-3)= ShftTilt=0 deg, RotSpeed=11 rpm and TMax=10 s. Then, I output some pitch angles of Blade 1, B1Pitch, at certain moments in the AeroDyn module, as shown in the figure below. However, the rate of change in pitch during these moments is much greater than 8 deg/s, as detailed below.
  3. Whether for onshore or offshore turbines, neither “DISCON.IN = DLL_InFile” nor “DISCON = DLL_ProcName” needs to be changed. The latter is a parameter inside the DLL program, and modifying it here is not meaningful. However, for DLL_FileName, turbine types NREL 5MW, NREL 5MW - ITI Barge, and NREL 5MW - OC3 Hywind require the use of controllers DISCON.dll, DISCON_ITIBarge.dll, and DISCON_OC3Hywind.dll respectively, as shown in the link above.
Dear @Yangyang.Li
I will give you my comment about the first two questions since till now i did not master very well all dll related questions.
1- In my understanding, if you did not disable NacelleYaw in ElastoDyn, the nacelle can rotate freely. When the rotor is spinning, this creates gyroscopic moment that yaw the nacelle. So, although is propagationDir=0 and YawNeut=0 but Nacelle Yaw DoF in ElastoDyn=1, the nacelle yaw will be different from zero.
2- I am surprised by the values in your table. Sorry, i cannot comment because i cannot understand that during 0.05 seconds the blade pitch goes from -16 to 106 degrees.
Dear @Yangyang.Li,
I’ll add my responses:
  1. When YawDOF = TRUE in ElastoDyn, the nacelle-yaw DOF is active and yaw motion is possible, but the yaw motion will be restrained around YawNeut based on the yaw actuator in SerovDyn determined by YawSpr and YawDamp.
  2. The rapid fluctuations in blade-pitch angle you are seeing imply to me that your model is numerically unstable. But you haven’t provided enough information to know why. Did you change the geometry, mass, stiffness, or timestep of the land-based NREL 5-MW wind turbine model? Or perhaps you are not setting proper initial conditions for the rotor speed (RotSpeed) and blade pitch (BlPitch) in ElastoDyn, conditioned on the mean hub-height wind speed?
  3. For the OpenFAST models of the NREL 5-MW baseline wind turbine in various offshore configurations, the name of the dynamic library (DLL_FileName) of the baseline controller changes between models, but the procedure name does not change and should be left as DLL_ProcName = “DISCON”. These baseline controllers do not use an input file, so, DLL_InFile does not need to be set to something specific.
Dear @Jason.Jonkman & @Riad.Elhamoud,
Thank you again for your prompt responses. The yaw rate becomes very small after reaching a steady state, and the pitch motion I previously output was transient and unstable, as you mentioned.
