Hi all, currently i am trying to retrace the result of OC4 Phase I Rev 4 with FAST v8.16. Now i am looking for the case 3.2 described as following picture :
I have some questions about the configuration for this load case :
- For the “enabled DOF” column, does it mean all DOF should be enabled in ElastoDyn
- Is it correct for the following setting in ServoDyn in this load case?
PCMode = 5
VSControl = 1
VS_RtGnSp = 1173.7
VS_RtTq = 43093.55
VS_Rgn2K = 0.0255764
VS_SIPC = 10
the data in SIMPLE VARIABLE-SPEED TORQUE CONTROL part is refer to the chapter 5 Drivetrain Properties, Definition of a 5-MW Reference Wind Turbine for Offshore System Development
https://www.nrel.gov/docs/fy09osti/38060.pdf
- For the wind conditions, is it correct for the following setting in BEM thoery Options used in AeroDyn v15?
2 SkewMod
True TipLoss
True HubLoss
true TanInd
False AIDrag
False TIDrag
“Default” IndToler
Thank You for your help.
BR,
Kylee
