Greetings,
I’m trying to run the 5MW_TLP_DLL_WTurb_WavesIrr_WavesMulti case and I am running into some problems. To begin with, I have not modificed the AeroDynv15 file, but on execution I get this error message:
Running AeroDyn.
FAST_InitializeAll:AD_Init:ParsePrimaryFileInfo:ParseLoVar:
>> A fatal error occurred when parsing data from ".\NRELOffshrBsline5MW_Onshore_AeroDyn15.dat".
>> The variable "CompAA" was not found on line #13.
I get this error for most of the 5MW NREL r-test files, unless I change the CompAero variable to 0.
I attach the AeroDyn file code underneath (eventhough it’s the default code).
Thanks a lot!
------- AERODYN v15 for OpenFAST INPUT FILE -----------------------------------------------
False Echo - Echo the input to "<rootname>.AD.ech"? (flag)
"default" DTAero - Time interval for aerodynamic calculations {or "default"} (s)
1 WakeMod - Type of wake/induction model (switch) {0=none, 1=BEMT, 2=DBEMT, 3=OLAF} [WakeMod cannot be 2 or 3 when linearizing]
2 AFAeroMod - Type of blade airfoil aerodynamics model (switch) {1=steady model, 2=Beddoes-Leishman unsteady model} [AFAeroMod must be 1 when linearizing]
1 TwrPotent - Type tower influence on wind based on potential flow around the tower (switch) {0=none, 1=baseline potential flow, 2=potential flow with Bak correction}
0 TwrShadow - Calculate tower influence on wind based on downstream tower shadow (switch) {0=none, 1=Powles model, 2=Eames model}
True TwrAero - Calculate tower aerodynamic loads? (flag)
False CavitCheck - Perform cavitation check? (flag) [AFAeroMod must be 1 when CavitCheck=true]
False Buoyancy - Include buoyancy effects? (flag)
False CompAA - Flag to compute AeroAcoustics calculation [used only when WakeMod = 1 or 2]
"unused" AA_InputFile - AeroAcoustics input file [used only when CompAA=true]
"default" AirDens - Air density (kg/m^3)
"default" KinVisc - Kinematic viscosity of working fluid (m^2/s)
"default" SpdSound - Speed of sound in working fluid (m/s)
"default" Patm - Atmospheric pressure (Pa) [used only when CavitCheck=True]
"default" Pvap - Vapour pressure of working fluid (Pa) [used only when CavitCheck=True]
====== Blade-Element/Momentum Theory Options ====================================================== [unused when WakeMod=0 or 3]
2 SkewMod - Type of skewed-wake correction model (switch) {1=uncoupled, 2=Pitt/Peters, 3=coupled} [unused when WakeMod=0 or 3]
"default" SkewModFactor - Constant used in Pitt/Peters skewed wake model {or "default" is 15/32*pi} (-) [used only when SkewMod=2; unused when WakeMod=0 or 3]
True TipLoss - Use the Prandtl tip-loss model? (flag) [unused when WakeMod=0 or 3]
True HubLoss - Use the Prandtl hub-loss model? (flag) [unused when WakeMod=0 or 3]
True TanInd - Include tangential induction in BEMT calculations? (flag) [unused when WakeMod=0 or 3]
False AIDrag - Include the drag term in the axial-induction calculation? (flag) [unused when WakeMod=0 or 3]
False TIDrag - Include the drag term in the tangential-induction calculation? (flag) [unused when WakeMod=0,3 or TanInd=FALSE]
"Default" IndToler - Convergence tolerance for BEMT nonlinear solve residual equation {or "default"} (-) [unused when WakeMod=0 or 3]
100 MaxIter - Maximum number of iteration steps (-) [unused when WakeMod=0]
====== Dynamic Blade-Element/Momentum Theory Options ============================================== [used only when WakeMod=2]
2 DBEMT_Mod - Type of dynamic BEMT (DBEMT) model {1=constant tau1, 2=time-dependent tau1, 3=constant tau1 with continuous formulation} (-) [used only when WakeMod=2]
4 tau1_const - Time constant for DBEMT (s) [used only when WakeMod=2 and DBEMT_Mod=1 or 3]
====== OLAF -- cOnvecting LAgrangian Filaments (Free Vortex Wake) Theory Options ================== [used only when WakeMod=3]
"unused" OLAFInputFileName - Input file for OLAF [used only when WakeMod=3]
3 UAMod - Unsteady Aero Model Switch (switch) {2=B-L Gonzalez, 3=B-L Minnema/Pierce, 4=B-L HGM 4-states, 5=B-L 5 states, 6=Oye, 7=Boeing-Vertol} [used only when AFAeroMod=2]
True FLookup - Flag to indicate whether a lookup for f' will be calculated (TRUE) or whether best-fit exponential equations will be used (FALSE); if FALSE S1-S4 must be provided in airfoil input files (flag) [used only when AFAeroMod=2]
1 AFTabMod - Interpolation method for multiple airfoil tables {1=1D interpolation on AoA (first table only); 2=2D interpolation on AoA and Re; 3=2D interpolation on AoA and UserProp} (-)
"../5MW_Baseline/Airfoils/Cylinder1.dat" AFNames - Airfoil file names (NumAFfiles lines) (quoted strings)
"../5MW_Baseline/Airfoils/Cylinder2.dat"
"../5MW_Baseline/Airfoils/DU40_A17.dat"
"../5MW_Baseline/Airfoils/DU35_A17.dat"
"../5MW_Baseline/Airfoils/DU30_A17.dat"
"../5MW_Baseline/Airfoils/DU25_A17.dat"
"../5MW_Baseline/Airfoils/DU21_A17.dat"
"../5MW_Baseline/Airfoils/NACA64_A17.dat"
"../5MW_Baseline/NRELOffshrBsline5MW_AeroDyn_blade.dat" ADBlFile(1) - Name of file containing distributed aerodynamic properties for Blade #1 (-)
"../5MW_Baseline/NRELOffshrBsline5MW_AeroDyn_blade.dat" ADBlFile(2) - Name of file containing distributed aerodynamic properties for Blade #2 (-) [unused if NumBl < 2]
"../5MW_Baseline/NRELOffshrBsline5MW_AeroDyn_blade.dat" ADBlFile(3) - Name of file containing distributed aerodynamic properties for Blade #3 (-) [unused if NumBl < 3]
====== Hub Properties ============================================================================== [used only when Buoyancy=True]
0.0 VolHub - Hub volume (m^3)
0.0 HubCenBx - Hub center of buoyancy x direction offset (m)
====== Nacelle Properties ========================================================================== [used only when Buoyancy=True]
0.0 VolNac - Nacelle volume (m^3)
0,0,0 NacCenB - Position of nacelle center of buoyancy from yaw bearing in nacelle coordinates (m)
====== Tail fin Aerodynamics ========================================================================
False TFinAero - Calculate tail fin aerodynamics model (flag)
"unused" TFinFile - Input file for tail fin aerodynamics [used only when TFinAero=True]
====== Tower Influence and Aerodynamics ============================================================ [used only when TwrPotent/=0, TwrShadow/=0, TwrAero=True, or Buoyancy=True]
12 NumTwrNds - Number of tower nodes used in the analysis (-) [used only when TwrPotent/=0, TwrShadow/=0, TwrAero=True, or Buoyancy=True]
TwrElev TwrDiam TwrCd TwrTI TwrCb !TwrTI used only with TwrShadow=2, TwrCb used only with Buoyancy=True
(m) (m) (-) (-) (-)
0.0000000E+00 6.0000000E+00 1.0000000E+00 1.0000000E-01 0.0
8.5261000E+00 5.7870000E+00 1.0000000E+00 1.0000000E-01 0.0
1.7053000E+01 5.5740000E+00 1.0000000E+00 1.0000000E-01 0.0
2.5579000E+01 5.3610000E+00 1.0000000E+00 1.0000000E-01 0.0
3.4105000E+01 5.1480000E+00 1.0000000E+00 1.0000000E-01 0.0
4.2633000E+01 4.9350000E+00 1.0000000E+00 1.0000000E-01 0.0
5.1158000E+01 4.7220000E+00 1.0000000E+00 1.0000000E-01 0.0
5.9685000E+01 4.5090000E+00 1.0000000E+00 1.0000000E-01 0.0
6.8211000E+01 4.2960000E+00 1.0000000E+00 1.0000000E-01 0.0
7.6738000E+01 4.0830000E+00 1.0000000E+00 1.0000000E-01 0.0
8.5268000E+01 3.8700000E+00 1.0000000E+00 1.0000000E-01 0.0
8.7600000E+01 3.8700000E+00 1.0000000E+00 1.0000000E-01 0.0
True SumPrint - Generate a summary file listing input options and interpolated properties to "<rootname>.AD.sum"? (flag)
0 NBlOuts - Number of blade node outputs [0 - 9] (-)
1, 9, 19 BlOutNd - Blade nodes whose values will be output (-)
1, 2, 6 TwOutNd - Tower nodes whose values will be output (-)
