with OpenFAST 2.3 a UserProp value was introduced for each airfoil table (before it was Ctrl i believe) together with AFTabMod. The intention was to enable control flaps deployed dynamically in the simulation controlled by the dll-controller.
[url]4.1.2. API changes between versions — OpenFAST v3.3.0 documentation
Is it planned to enable the use of this UserProp value as static input given for each airfoil file or each aerodynamic station?
Idea is to use the thickness of the blade as an indicator which airfoil table to use or interpolate. As long as the characteristics of the airfoils are similar in one airfoil file linear interpolation between tables should yield sufficient results while decreasing preprocessing steps.
Simon
