Hi Andy,
I did some more tests and tried to reproduce the error with the NREL model from "5MW_Land_BD_DLL_WTurb" in the v3.0.0 r-test repository.
With the following changes I see the same error as before running with the x64 compiled version from here.
Without the nodal output section in BeamDyn no error is given.
NRELOffshrBsline5MW_BeamDyn.dat (only nodal output added):
---------------------- OUTPUTS -------------------------------------------------
“ES10.3E2” OutFmt - Format used for text tabular output, excluding the time channel.
0 NNodeOuts - Number of nodes to output to file [0 - 9] (-)
1, 2, 3, 4, 5, 6 OutNd - Nodes whose values will be output (-)
“RootFxr, RootFyr, RootFzr”
“RootMxr, RootMyr, RootMzr”
“TipTDxr, TipTDyr, TipTDzr”
“TipRDxr, TipRDyr, TipRDzr”
---------------------- NODE OUTPUTS --------------------------------------------
99 BldNd_BlOutNd - Blade nodes on each blade (currently unused)
OutList - The next line(s) contains a list of output parameters. See OutListParameters.xlsx, AeroDyn_Nodes tab for a listing of available output channels, (-)
“Mxr” - Sectional moment resultants at each node expressed in r r: a floating reference coordinate system fixed to the root of the moving beam; when coupled to FAST for blades, this is equivalent to the IEC blade (b) coordinate system (N-m)
“Myr” - Sectional moment resultants at each node expressed in r r: a floating reference coordinate system fixed to the root of the moving beam; when coupled to FAST for blades, this is equivalent to the IEC blade (b) coordinate system (N-m)
“Mzr” - Sectional moment resultants at each node expressed in r r: a floating reference coordinate system fixed to the root of the moving beam; when coupled to FAST for blades, this is equivalent to the IEC blade (b) coordinate system (N-m)
5MW_Land_BD_DLL_WTurb.fst (only TMax, feature switches, file paths and TStart changed):
2 TMax - Total run time (s)
2 CompElast - Compute structural dynamics (switch) {1=ElastoDyn; 2=ElastoDyn + BeamDyn for blades}
0 CompInflow - Compute inflow wind velocities (switch) {0=still air; 1=InflowWind; 2=external from OpenFOAM}
0 CompAero - Compute aerodynamic loads (switch) {0=None; 1=AeroDyn v14; 2=AeroDyn v15}
0 CompServo - Compute control and electrical-drive dynamics (switch) {0=None; 1=ServoDyn}
0 CompHydro - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
0 CompSub - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn; 2=External Platform MCKF}
0 CompMooring - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
1 TStart - Time to begin tabular output (s)
Output at execution:
OpenFAST
Copyright (C) 2021 National Renewable Energy Laboratory
Copyright (C) 2021 Envision Energy USA LTD
See the “LICENSE” file distributed with this software for details.
OpenFAST-v3.0.0
Compile Info:
- Compiler: Intel(R) Fortran Compiler 1900
- Architecture: 64 bit
- Precision: single
- OpenMP: No
- Date: Jun 23 2021
- Time: 21:25:05
Execution Info:
- Date: 02/03/2022
- Time: 11:32:55+0100
OpenFAST input file heading:
FAST Certification Test #26: NREL 5.0 MW Baseline Wind Turbine (Onshore)
Running ElastoDyn.
Running BeamDyn.
Running BeamDyn.
Running BeamDyn.
Time: 0 of 2 seconds.
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
openfast_x64.exe 00007FF7A1313DB6 Unknown Unknown Unknown
openfast_x64.exe 00007FF7A0CC3567 Unknown Unknown Unknown
openfast_x64.exe 00007FF7A02B8F6D Unknown Unknown Unknown
openfast_x64.exe 00007FF7A02A753E Unknown Unknown Unknown
openfast_x64.exe 00007FF7A02988CE Unknown Unknown Unknown
openfast_x64.exe 00007FF7A021AF0B Unknown Unknown Unknown
openfast_x64.exe 00007FF7A021A93C Unknown Unknown Unknown
openfast_x64.exe 00007FF7A01D1CD3 Unknown Unknown Unknown
openfast_x64.exe 00007FF7A27E8362 Unknown Unknown Unknown
openfast_x64.exe 00007FF7A2CE4134 Unknown Unknown Unknown
KERNEL32.DLL 00007FFC0B707034 Unknown Unknown Unknown
ntdll.dll 00007FFC0D702651 Unknown Unknown Unknown"
