I am trying for the first time to use Airfoilprep for extrapolation of Clift and Cdrag curves. In the good old times I had used Foilcheck.
It seems to me that, if the user has only a limited amount of data (as in my case, where my angle of attack goes only up to about 15�, around the beginning of stall), Foilcheck would still be needed.
I quote from the first page of Airfoilprep:
“In some cases you may need to first use the FoilCheck worksheet to develop your table at high angles. If you do this, you should still repeat the FoilCheck calculation to get the appropriate dynamic stall parameters for the 3-D airfoil table.”
No problem at all, I kept the “old” Foilcheck executable, but I am asking myself why did you choose to eliminate it from your web page. Infact, if all what one needs is to extrapolate CL/CD/CM data from a small range to the complete 0-360�, just to go fast to a WTPERF simulation, Foilcheck provides a faster answer.
Actually I was not able to obtain this with Airfoilprep.
thanks a lot and… keep up the good work!
Claudio
Marshall,
thanks for your answer. I will try harder…
the quote comes from about the middle of the “ReadMe” introduction of AirfoilPrep_v2p2.xls and says
“After the 2-D characteristics are established for the correct airfoil section and Reynolds number, the 3-D rotation effects should be accounted for. This is done by copying and pasting the 2-D (blended) table into the 3DStall worksheet, entering the necessary parameters (all shown in red), and running the macro (click on the yellow ‘Calc. 3-D Table’ button). The input table to this calculation should extend to reasonably high angles of attack (30-50�). In some cases you may need to first use the FoilCheck worksheet to develop your table at high angles. If you do this, you should still repeat the FoilCheck calculation to get the appropriate dynamic stall parameters for the 3-D airfoil table.”
I suspect the ReadMe worksheet contains a typo in that it refers to the FoilCheck worksheet instead of the TableExtrap worksheet. I will verify this with Craig Hansen, the spreadsheet’s author.
