Hello eveyone,
i’m studing in master’s degree , i’m going to comparing fast and wind tunnul.but i have a big problem about wind load.
the result between fast and wind tunnul is different,so i’m confuse.
i comparing the CFx , CFy , CMz .
am l have the correct setting in fast?
those are my files.
[1].using Test 21 [5MW]
------- FAST v8.16.* INPUT FILE ------------------------------------------------
FAST Certification Test #21: NREL 5.0 MW Baseline Offshore Turbine with OC4 Jacket Configuration
“FATAL” AbortLevel - Error level when simulation should abort (string) {“WARNING”, “SEVERE”, “FATAL”}
60 TMax - Total run time (s)
0.001 DT - Recommended module time step (s)
1 NumCrctn - Number of correction iterations (-) {0=explicit calculation, i.e., no corrections}
99999 DT_UJac - Time between calls to get Jacobians (s)
1E+06 UJacSclFact - Scaling factor used in Jacobians (-)
0 CompHydro - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
0 CompSub - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn}
0 CompMooring - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
[2].NRELOffshrBsline5MW_OC4Jacket_AeroDyn file
--------- AeroDyn v14.04.* INPUT FILE -------------------------------------------------------------------------
NREL 5.0 MW offshore baseline aerodynamic input properties with OC4 jacket tower
“BEDDOES” StallMod - Dynamic stall included [BEDDOES or STEADY] (unquoted string)
“USE_CM” UseCm - Use aerodynamic pitching moment model? [USE_CM or NO_CM] (unquoted string)
“EQUIL” InfModel - Inflow model [DYNIN or EQUIL] (unquoted string)
“SWIRL” IndModel - Induction-factor model [NONE or WAKE or SWIRL] (unquoted string)
0.005 AToler - Induction-factor tolerance (convergence criteria) (-)
“PRANDtl” TLModel - Tip-loss model (EQUIL only) [PRANDtl, GTECH, or NONE] (unquoted string)
“PRANDtl” HLModel - Hub-loss model (EQUIL only) [PRANdtl or NONE] (unquoted string)
“NEWTOWER” TwrShad - INSTEAD OF: 0.0 TwrShad - Tower-shadow velocity deficit (-)
True TwrPotent - Calculate tower potential flow (flag) INSTEAD OF 9999.9 ShadHWid - Tower-shadow half width (m)
False TwrShadow - Calculate tower shadow (flag) INSTEAD OF 9999.9 T_Shad_Refpt- Tower-shadow reference point (m)
“NRELOffshrBsline5MW_OC4Jacket_AeroDyn_Tower.dat” TwrFile - Tower drag file name (quoted string)
True CalcTwrAero - Calculate aerodynamic drag of the tower at the ElastoDyn nodes. TwrPotent must be true.
1.464E-05 KinVisc - Kinematic air viscosity [CURRENTLY IGNORED] (m^2/sec)
“DEFAULT” DTAero - Time interval for aerodynamic calculations (sec)
8 NumFoil - Number of airfoil files (-)
[3].NRELOffshrBsline5MW_OC4Jacket_ElastoDyn file
OC4 TOWER+ NREL 5.0 MW Baseline Wind Turbine for Use in Offshore Analysis. Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf);
“DEFAULT” DT - Integration time step (s)
False YawDOF - Yaw DOF (flag)
False PtfmSgDOF - Platform horizontal surge translation DOF (flag)
False PtfmSwDOF - Platform horizontal sway translation DOF (flag)
90 BlPitch(1) - Blade 1 initial pitch (degrees)
90 BlPitch(2) - Blade 2 initial pitch (degrees)
90 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
15 Azimuth - Initial azimuth angle for blade 1 (degrees)
0 RotSpeed - Initial or fixed rotor speed (rpm)
-0.00702 PtfmHeave - Initial or fixed vertical heave translational displacement of platform (meters)
63 TipRad - The distance from the rotor apex to the blade tip (meters)
0 PreCone(1) - Blade 1 cone angle (degrees)
0 PreCone(2) - Blade 2 cone angle (degrees)
0 PreCone(3) - Blade 3 cone angle (degrees) [unused for 2 blades]
-5.0191 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5 ShftTilt - Rotor shaft tilt angle (degrees)
88.15 TowerHt - Height of tower above ground level [onshore] or MSL [offshore] (meters)
0 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
0 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
[4].NRELOffshrBsline5MW_OC4Jacket_ServoDyn
------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
OC4 Jacket+NREL 5.0 MW Baseline Wind Turbine for Use in Offshore Analysis. Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf);
“DEFAULT” DT - Communication interval for controllers (s) (or “default”)
5 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TPCOn - Time to enable active pitch control (s) [unused when PCMode=0]
0 TPitManS(1) - Time to start override pitch maneuver for blade 1 and end standard pitch control (s)
0 TPitManS(2) - Time to start override pitch maneuver for blade 2 and end standard pitch control (s)
0 TPitManS(3) - Time to start override pitch maneuver for blade 3 and end standard pitch control (s) [unused for 2 blades]
8 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
8 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
8 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
90 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
90 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
90 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
5 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TimGenOn - Time to turn on the generator for a startup (s) [used only when GenTiStr=True]
and this is my model, i also change the Wind attack angle from 0 degree to 70 degree.
model-https://ppt.cc/fE35rx
result-https://ppt.cc/fvQFxx
am i have the correct setting in fast ?
thank u
