Dear Jonkman
When I use OpenFAST for simulation, I encounter the following error. How can I solve the error of UA parameter?
Currently, I am trying to export the angle of attack lift and other parameters of blade nodes, but it seems that all the output results are zero.
OpenFAST input file heading:
FAST Certification Test #18: NREL 5.0 MW Baseline Wind Turbine (Onshore)
Running ElastoDyn.
Running AeroDyn.
AD15 Nodal Outputs: Nodal output section of AeroDyn input file not found or improperly formatted.
Skipping nodal outputs.
Warning: Turning off Unsteady Aerodynamics because UA parameters are not included in airfoil
(airfoil has likely has constant polars). (node 1, blade 1)
(airfoil has likely has constant polars). (node 2, blade 1)
(airfoil has likely has constant polars). (node 3, blade 1)
(airfoil has likely has constant polars). (node 4, blade 1)
(airfoil has likely has constant polars). (node 1, blade 2)
(airfoil has likely has constant polars). (node 2, blade 2)
(airfoil has likely has constant polars). (node 3, blade 2)
(airfoil has likely has constant polars). (node 4, blade 2)
(airfoil has likely has constant polars). (node 1, blade 3)
(airfoil has likely has constant polars). (node 2, blade 3)
