Hi Jonkman
I am currently running the IEA 15MW reference wind turbine (RWT) with a semi-submersible floating platform,my OPENFAST terminated normally and also outputted some results, but I found that the value of some parameters related to twist,for example,TwstDefl1,TwstDefl2,TwstDefl3,TTDspTwst have been constantly 0. I have already turn on all the parameters related to degrees of freedom except TeetDOF in ElastoDyn, so I’m curious why the values of the above parameters have always been 0, and which parts of my settings may still have problems? and below is my OPENFAST running process.
OpenFAST
Copyright (C) 2023 National Renewable Energy Laboratory
Copyright (C) 2023 Envision Energy USA LTD
See the “LICENSE” file distributed with this software for details.
OpenFAST-Unversioned from 18704086dad861ab13daf804825da7c4b8d59428
Compile Info:
- Compiler: Intel(R) Fortran Compiler 2021
- Architecture: 64 bit
- Precision: single
- OpenMP: No
- Date: Feb 18 2023
- Time: 12:16:53
Execution Info: - Date: 12/01/2023
- Time: 09:43:12+0800
OpenFAST input file heading:
Running ElastoDyn.
Running AeroDyn.
AD15 Nodal Outputs: Nodal output section of AeroDyn input file not found or improperly formatted.
Skipping nodal outputs.
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 1, blade 1)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 2, blade 1)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 1, blade 2)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 2, blade 2)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 1, blade 3)
Warning: Turning off Unsteady Aerodynamics because polar has constant data. (node 2, blade 3)
Running InflowWind.
Reading a 62x62 grid (260 m wide, 20 m to 280 m above ground) with a characteristic wind speed
of 12 m/s. This full-field file was generated by TurbSim (from OpenFAST-v3.4.1) on 29-Nov-2023
at 10:32:12.
Processed 20534 time steps of 20-Hz full-field data (1026.7 seconds).
Running HydroDyn.
Setting WaveTMax to 0.0 since WaveMod = 0
WARNING: The requested output channel is invalid: WavesF1xi
WARNING: The requested output channel is invalid: WavesF1zi
WARNING: The requested output channel is invalid: WavesM1yi
WARNING: The requested output channel is invalid: WavesF2xi
WARNING: The requested output channel is invalid: WavesF2zi
WARNING: The requested output channel is invalid: WavesM2yi
WARNING: The requested output channel is invalid: WavesF2yi
WARNING: The requested output channel is invalid: WavesM2xi
WARNING: The requested output channel is invalid: WavesM2zi
Calculating second order difference frequency wave kinematics.
Reading in WAMIT output with root name “.\HydroData/IEA-15-240-RWT-UMaineSemi”.
Calculating second order difference-frequency force using the full quadratic transfer function.
Running MoorDyn (v2.0.0, 2022-12-08).
This is MoorDyn v2, with significant input file changes from v1.
Copyright: (C) 2022 National Renewable Energy Laboratory, (C) 2019 Matt Hall
Parsing MoorDyn input file: .\IEA-15-240-RWT-UMaineSemi_MoorDyn.dat
Warning: invalid output specifier FX. Must start with L, C, R, or B
Warning: invalid output specifier FY. Must start with L, C, R, or B
Warning: invalid output specifier FZ. Must start with L, C, R, or B
Created mooring system: 3 lines, 6 points, 0 rods, 0 bodies.
Finalizing initial conditions using dynamic relaxation.
t=60 FairTen 1: 2.42597E+06, 2.45002E+06, 2.43250E+06
Fairlead tensions did not converge within TMaxIC=60 seconds.
MoorDyn initialization completed.
Running ServoDyn.
Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows).
Using legacy Bladed DLL interface.
FAST_InitializeAll:HydroDyn_Init:HydroDynInput_ProcessInitData: A requested output channel is
invalid
Running ROSCO-v2.8.0
A wind turbine controller framework for public use in the scientific field
Developed in collaboration: National Renewable Energy Laboratory
Delft University of Technology, The Netherlands
Generator speed: 7.6 RPM, Pitch angle: -1.0 deg, Power: 0.0 kW, Est. wind Speed: 12.5 m/s
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:AD_CalcOutput:RotCalcOutput:BEMT_CalcOut
put(node 3, blade 1):UA_CalcOutput:UA_BlendSteady:Temporarily turning off UA due to high angle of
attack or low relative velocity. This warning will not be repeated though the condition may
persist.
put(node 50, blade 2):UA_CalcOutput:Mach number exceeds 0.3. Theory is invalid. This warning will
not be repeated though the condition may persist.
Generator speed: 6.5 RPM, Pitch angle: 6.7 deg, Power: 11715.8 kW, Est. wind Speed: 9.9 m/s
Generator speed: 7.5 RPM, Pitch angle: 4.4 deg, Power: 14676.6 kW, Est. wind Speed: 12.5 m/s
Generator speed: 7.6 RPM, Pitch angle: 6.3 deg, Power: 14738.2 kW, Est. wind Speed: 11.2 m/s
Generator speed: 7.7 RPM, Pitch angle: 6.7 deg, Power: 15465.9 kW, Est. wind Speed: 12.6 m/s
Generator speed: 8.0 RPM, Pitch angle: 8.2 deg, Power: 15849.4 kW, Est. wind Speed: 13.3 m/s
Generator speed: 7.7 RPM, Pitch angle: 9.3 deg, Power: 14964.0 kW, Est. wind Speed: 13.0 m/s
Generator speed: 7.4 RPM, Pitch angle: 9.3 deg, Power: 14856.7 kW, Est. wind Speed: 13.5 m/s
Generator speed: 7.8 RPM, Pitch angle: 10.4 deg, Power: 15452.6 kW, Est. wind Speed: 14.5 m/s
Generator speed: 7.6 RPM, Pitch angle: 10.0 deg, Power: 14927.4 kW, Est. wind Speed: 13.7 m/s
Generator speed: 7.0 RPM, Pitch angle: 7.9 deg, Power: 13913.3 kW, Est. wind Speed: 12.4 m/s
Generator speed: 7.3 RPM, Pitch angle: 6.6 deg, Power: 14348.8 kW, Est. wind Speed: 12.0 m/s
Generator speed: 7.4 RPM, Pitch angle: 4.1 deg, Power: 13714.1 kW, Est. wind Speed: 11.2 m/s
Generator speed: 7.5 RPM, Pitch angle: 4.2 deg, Power: 14330.2 kW, Est. wind Speed: 11.0 m/s
Generator speed: 7.8 RPM, Pitch angle: 5.1 deg, Power: 15508.0 kW, Est. wind Speed: 11.8 m/s
Generator speed: 7.9 RPM, Pitch angle: 6.6 deg, Power: 15720.6 kW, Est. wind Speed: 12.5 m/s
Generator speed: 7.8 RPM, Pitch angle: 8.0 deg, Power: 15318.9 kW, Est. wind Speed: 12.7 m/s
Generator speed: 7.4 RPM, Pitch angle: 7.5 deg, Power: 14683.6 kW, Est. wind Speed: 12.3 m/s
Generator speed: 7.5 RPM, Pitch angle: 7.3 deg, Power: 14812.5 kW, Est. wind Speed: 12.5 m/s
Generator speed: 7.8 RPM, Pitch angle: 8.4 deg, Power: 15528.0 kW, Est. wind Speed: 13.4 m/s
Generator speed: 7.9 RPM, Pitch angle: 10.0 deg, Power: 15733.2 kW, Est. wind Speed: 14.2 m/s
Generator speed: 7.6 RPM, Pitch angle: 10.0 deg, Power: 14936.8 kW, Est. wind Speed: 13.7 m/s
Generator speed: 7.3 RPM, Pitch angle: 9.3 deg, Power: 14462.6 kW, Est. wind Speed: 13.3 m/s
Generator speed: 7.2 RPM, Pitch angle: 7.4 deg, Power: 14439.2 kW, Est. wind Speed: 12.6 m/s
Generator speed: 7.3 RPM, Pitch angle: 6.4 deg, Power: 14519.9 kW, Est. wind Speed: 11.9 m/s
Generator speed: 7.4 RPM, Pitch angle: 5.3 deg, Power: 14747.3 kW, Est. wind Speed: 11.6 m/s
Generator speed: 7.6 RPM, Pitch angle: 5.5 deg, Power: 15038.2 kW, Est. wind Speed: 11.8 m/s
Generator speed: 7.7 RPM, Pitch angle: 6.5 deg, Power: 15251.2 kW, Est. wind Speed: 12.1 m/s
Generator speed: 7.5 RPM, Pitch angle: 5.7 deg, Power: 14866.3 kW, Est. wind Speed: 11.7 m/s
Generator speed: 7.5 RPM, Pitch angle: 6.1 deg, Power: 14822.1 kW, Est. wind Speed: 11.9 m/s
Generator speed: 7.5 RPM, Pitch angle: 5.2 deg, Power: 14980.6 kW, Est. wind Speed: 11.7 m/s
Total Real Time: 18.529 hours
Total CPU Time: 6.6003 hours
Simulation CPU Time: 6.5977 hours
Simulated Time: 8.33333E-02 hours
Time Ratio (Sim/CPU): 1.26307E-02
OpenFAST terminated normally.
