Dear Jonkman sir,
I used turbsim to generate wind file and used to run NREL 5MW wind turbine. By running i am facing the problem (snapshot is attached). Please help me to sort out the issue. My wind file details read as follows
TurbSim Input File. Valid for TurbSim v1.50; 17-May-2010; Example file that can be used with simulations for the NREL 5MW Baseline Turbine
511347 RandSeed1 - First random seed (-2147483648 to 2147483647)
RanLux RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
False WrADFF - Output full-field time-series data in TurbSim/AeroDyn form? (Generates RootName.bts)
True WrBLFF - Output full-field time-series data in BLADED/AeroDyn form? (Generates RootName.wnd)
13 NumGrid_Z - Vertical grid-point matrix dimension
13 NumGrid_Y - Horizontal grid-point matrix dimension
0.01 TimeStep - Time step [seconds]
1100.0 AnalysisTime - Length of analysis time series [seconds]
1030.0 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds)
90.0 HubHt - Hub height [m] (should be > 0.5GridHeight)
170.0 GridHeight - Grid height [m]
170.0 GridWidth - Grid width [m] (should be >= 2(RotorRadius+ShaftLength))
IECKAI TurbModel - Turbulence model (“IECKAI”=Kaimal, “IECVKM”=von Karman, “GP_LLJ”, “NWTCUP”, “SMOOTH”, “WF_UPW”, “WF_07D”, “WF_14D”, or “NONE”)
“1-ed3” IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
“A” IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP, not used for other models)
NTM IEC_WindType - IEC turbulence type (“NTM”=normal, “xETM”=extreme turbulence, “xEWM1”=extreme 1-year wind, “xEWM50”=extreme 50-year wind, where x=wind turbine class 1, 2, or 3)
default ETMc - IEC Extreme turbulence model “c” parameter [m/s]
default WindProfileType - Wind profile type (“JET”=Low-level jet,“LOG”=Logarithmic,“PL”=Power law, or “default”, or “USR”=User-defined)
87.2876 RefHt - Height of the reference wind speed [m]
12.0 URef - Mean (total) wind speed at the reference height [m/s]
default PC_UW - Hub mean u’w’ Reynolds stress [(m/s)^2] (or “default”)
default PC_UV - Hub mean u’v’ Reynolds stress [(m/s)^2] (or “default”)
default PC_VW - Hub mean v’w’ Reynolds stress [(m/s)^2] (or “default”)
default IncDec1 - u-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default IncDec2 - v-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default IncDec3 - w-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default CohExp - Coherence exponent (or “default”)
“C:\Users\Abhishek\Desktop\compound\turbsim\Test\EventData” CTEventPath - Name of the path where event data files are located
“Random” CTEventFile - Type of event files (“random”, “les” or “dns”)
true Randomize - Randomize disturbance scale and location? (true/false)
1.0 DistScl - Disturbance scale (ratio of dataset height to rotor disk).
0.5 CTLy - Fractional location of tower centerline from right (looking downwind) to left side of the dataset.
0.5 CTLz - Fractional location of hub height from the bottom of the dataset.
30.0 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
NOTE: Do not add or remove any lines in this file!
