Hello!
I’m trying to compare my own generator model that uses a thevenin equivalent circuit with that one from FAST. But I have a doubt about the model.
What’s the meaning of “complete circuit” at:
"TEC_RLR This is the leakage reactance of the generator rotor in the complete circuit. "?
Are the leakage reactance and the resistance of the generator rotor referred to stator? My circuit is referred to stator, and I’m not sure if I should use the values of my circuit, or if I should refer them to the rotor. I coudn’t find at the FAST Guide any indication about it. I attached an image of my circuit, do someone know if this circuit is the same of the “complete circuit” described at the FAST Guide?
Thank you for your help!
Mariely
