Dear Jason,OC5 Phase III-OWT model-Jacket.rar (2.88 MB)
I’m doing research a model of a jacket is OC5 - phaseIII - OWT project, I established the lower supporting structure in the SubDyn module, and established in ElsoDYN REPower 5 mw tower , I modified RNA of geometry size, and quality and moment of inertia of the corresponding REPower modified into 5 mw, but, blade I completely or use your NREL - 5 mw wind turbine, mainly airfoil aerodynamic performance and no change.
According to this, I built a model of oc5-phaseiii-owt-jacket in FAST.
I run two case first is regular wave, I simulated and the ability to run successfully, but the second case is steady wind+regular wave then,the program run error, an error results as follows,
[code]FAST (v8.16.00a-bjj, 27-Jul-2016)
Copyright (C) 2016 National Renewable Energy Laboratory
This program comes with ABSOLUTELY NO WARRANTY. See the “license.txt” file distributed with this
software for details.
Running FAST (v8.16.00a-bjj, 27-Jul-2016), compiled as a 32-bit application using single
precision
linked with NWTC Subroutine Library (v2.09.00, 23-Jul-2016)
Heading of the FAST input file:
FAST Certification Test #21: NREL 5.0 MW Baseline Offshore Turbine with OC4 Jacket
Configuration
Running ElastoDyn (v1.04.00a-bjj, 26-Jul-2016).
Running AeroDyn14 (v14.05.01a-bjj, 25-Jul-2016).
Input values for DR(
are not compatible with input RElm(:).
To make them compatible, please modify DR in the AeroDyn input file,
.\5MW_Baseline/NRELOffshrBsline5MW_OC4Jacket_AeroDyn.dat, as follows:
DR (Old) → DR (New)
2.7333 → 2.4534
2.7333 → 3.0132
2.7333 → 2.4534
4.1000 → 4.3800
4.1000 → 3.8200
4.1000 → 4.3800
4.1000 → 3.8200
4.1000 → 4.3800
4.1000 → 3.8200
4.1000 → 4.3800
4.1000 → 3.8200
4.1000 → 4.3800
4.1000 → 3.8200
4.1000 → 4.3800
2.7333 → 2.4534
2.7333 → 3.0132
2.7333 → 2.4534
FAST_InitializeAll:CheckRComp: Input values for DR(
Aborting FAST. [/code]
but I modified the value of DR into the new, and then run, can run successfully, but seems to be no convergence, program the following condition, this kind of situation was the first time I met, so wish to request your help.
[code] Running InflowWind (v3.03.00, 26-Jul-2016).
Opening InflowWind input file: .\5MW_Baseline/NRELOffshrBsline5MW_InflowWind_12mps.dat
Running ServoDyn (v1.06.00a-bjj, 26-Jul-2016).
Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows,
14-Oct-2015).
Running HydroDyn (v2.05.01, 27-Jul-2016).
Running SubDyn (v1.03.00, 11-Apr-2016).
Calculating Internal Modal Eigenvectors
Timestep: 0 of 120 seconds.
Jonkman of NREL/NWTC for use in the IEA Annex XXIII OC3 studies.
FAST_Solution:FAST_AdvanceStates:ED_ABM4:ED_AB4:ED_RK4:ED_CalcContStateDeriv:SetCoordSy:Small
angle assumption violated in SUBROUTINE SmllRotTrans() due to a large platform displacement
(ElastoDyn SetCoordSy). The solution may be inaccurate. Simulation continuing, but future
warnings from SmllRotTrans() will be suppressed.
Additional debugging message from SUBROUTINE SmllRotTrans(): 2.00000E-03 s
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:InflowWind_CalcOutput:CalcOutput:IfW_Uni
formWind_CalcOutput:GetWindSpeed:Height must not be negative.
IfW_UniformWind_CalcOutput: Error calculating the wind speed at position (-2.44138E+17,
-1.30325E+17, -2.58685E+17) in the wind-file coordinates
SolveOption2:AD14_CalcOutput:AeroDyn was designed for an explicit-loose coupling scheme. Using
last calculated values from AeroDyn on all subsequent calls until time is advanced. Warning will
not be displayed again.
SolveOption2:SrvD_CalcOutput:BladedInterface option was designed for an explicit-loose coupling
scheme
FAST encountered an error at simulation time 0 of 120 seconds.
Simulation error level: FATAL ERROR [/code]
Aborting FAST.
The attachment is for my FAST model
Thank you for your kindness ,and look forward to your reply!!!
Zhou.Lin
