I can now provide a MWE that I experimented so far, and its corresponding error message, respectively:
The example was directly based on:
OpenFAST/docs/source/user/beamdyn/examples/bd_driver_dynamic_nrel_5mw.inp
I added the following lines into the original file:
1 NumPointLoads - Number of Point Loads (primary input file section header)
---------------------- MULTIPLE POINT LOADS --------------------------------------
0.5 PointLoad(1,1) - Nodal point loads - Node No DOF No
0.0 PointLoad(1,2) - Nodal point loads - Node No DOF No
0.0 PointLoad(1,3) - Nodal point loads - Node No DOF No
0.0 PointLoad(1,4) - Nodal point loads - Node No DOF No
0.0 PointLoad(1,5) - Nodal point loads - Node No DOF No
0.0 PointLoad(1,6) - Nodal point loads - Node No DOF No
0.0 PointLoad(1,7) - Nodal point loads - Node No DOF No
- Accordingly, the modified file, bd_driver_dynamic_nrel_5mw.inp, became the following:
------- BEAMDYN V1.00.00 Driver INPUT FILE -------------------------------------
Dynamic analysis of rotating NREL 5MW blade under gravity force
0.018 t_initial - Starting time of simulation (s)
2E-02 t_final - Ending time of simulation (s)
2E-03 dt - Time increment size (s)
---------------------- GRAVITY PARAMETER --------------------------------------
0.0 Gx - Component of gravity vector along X direction (m/s^2)
0.0 Gy - Component of gravity vector along Y direction (m/s^2)
0.0 Gz - Component of gravity vector along Z direction (m/s^2)
---------------------- FRAME PARAMETER --------------------------------------
0.0 GlbPos(1) - Component of position vector of the reference blade frame along X direction (m)
0.0 GlbPos(2) - Component of position vector of the reference blade frame along Y direction (m)
1.0 GlbPos(3) - Component of position vector of the reference blade frame along Z direction (m)
---The following 3 by 3 matrix is the direction cosine matirx ,GlbDCM(3,3),
---relates global frame to reference blade frame
1.000E+00 0.000E+00 0.000E+00
0.000E+00 1.000E+00 0.000E+00
0.000E+00 0.000E+00 1.000E+00
---------------------- ROOT VELOCITY PARAMETER ----------------------------------
1.0006 RootVel(4) - Component of angular velocity vector of the beam root about X axis (rad/s)
0.0 RootVel(5) - Component of angular velocity vector of the beam root about Y axis (rad/s)
0.0 RootVel(6) - Component of angular velocity vector of the beam root about Z axis (rad/s)
---------------------- APPLIED FORCE ----------------------------------
0.0 DistrLoad(1) - Component of distributed force vector along X direction (N/m)
0.0 DistrLoad(2) - Component of distributed force vector along Y direction (N/m)
0.0 DistrLoad(3) - Component of distributed force vector along Z direction (N/m)
0.0 DistrLoad(4) - Component of distributed moment vector along X direction (N-m/m)
0.0 DistrLoad(5) - Component of distributed moment vector along Y direction (N-m/m)
0.0 DistrLoad(6) - Component of distributed moment vector along Z direction (N-m/m)
0.0 TipLoad(1) - Component of concentrated force vector at blade tip along X direction (N)
0.0 TipLoad(2) - Component of concentrated force vector at blade tip along Y direction (N)
0.0 TipLoad(3) - Component of concentrated force vector at blade tip along Z direction (N)
0.0 TipLoad(4) - Component of concentrated moment vector at blade tip along X direction (N-m)
0.0 TipLoad(5) - Component of concentrated moment vector at blade tip along Y direction (N-m)
0.0 TipLoad(6) - Component of concentrated moment vector at blade tip along Z direction (N-m)
---------------------- PRIMARY INPUT FILE --------------------------------------
"bd_primary_nrel_5mw_dynamic.inp" InputFile - Name of the primary input file
- This was executed as:
./beamdyn_driver bd_driver_dynamic_nrel_5mw.inp
- The error message as was below:
[code] **************************************************************************************************
BeamDyn Driver
Copyright (C) National Renewable Energy Laboratory
See the “LICENSE” file distributed with this software for details.
Running BeamDyn Driver
a part of OpenFAST - v1.0.0-dirty
linked with NWTC Subroutine Library
BD_ReadDvrFile:Invalid numerical input for file “bd_driver_dynamic_nrel_5mw.inp” occurred while
trying to read PointLoad.
BeamDyn Driver encountered simulation error level: FATAL ERROR
Aborting program.[/code]
Could you please at least give me some hint about where I should look at for the solution, if possible?
Many thanks,
Kuti
