Hello everyone,
yesterday I downloaded the updated version of SOWFA from github. After several small tweaks everything
compiles fine. I tried the precursorABL/neutral tutorial case and after some updates (fixedFluxPressure
instead of buoyantPressure) I started the case. I used blockMesh, setFieldsABL (which already failed
because there was the following error)
[code]Build : 2.3.0-f5222ca19ce6
Exec : setFieldsABL
Date : Dec 05 2014
Time : 14:08:06
Host : “cfd”
PID : 2650
Case : /home/cfd/OpenFOAM/cfd-2.3.0/run/SOWFA/tutorials/precursorABL/neutral
nProcs : 1
sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field U
Reading field T
Reading field p_rgh
Creating/Calculating face flux field, phi…
Reading gravitational acceleration…
Selecting incompressible transport model Newtonian
Creating the kinematic density field, rhok…
u* = 0.35863751503 m/s
<U_1> = (6.92820323026 3.99999999999 0) <U_s> = (6.92820323026 3.99999999999 0) <dU/dn> = (-1.16193474595e-18 -3.25610680393e-18 0)
→ FOAM FATAL ERROR:
updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() or evaluate() to set the boundary gradient.
From function fixedFluxPressureFvPatchScalarField::updateCoeffs()
in file fields/fvPatchFields/derived/fixedFluxPressure/fixedFluxPressureFvPatchScalarField.C at line 151.
FOAM exiting
[/code]
I anyways tried to let the ABLSolver run but an error alike the above occured. I then commented out the line 325 in setFieldsABL.C
(p_rgh.correctBoundaryConditions()
and the setFieldABL utility ran afterwards. I also commented the line 92 in ABLSolver.C out
(see before) and the solver ran up to this point
[code]/---------------------------------------------------------------------------
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 2.3.0 |
| \ / A nd | Web: www.OpenFOAM.org |
| \/ M anipulation | |
Exec : ABLSolver
Date : Dec 05 2014
Time : 12:28:26
Host : “cfd”
PID : 10092
nProcs : 1
Create time
Reading the gravitational acceleration, g…
Reading planetary rotation rate…
Reading the latitude…
Creating and reading potential temperature field, T…
Creating and reading modified pressure field, p_rgh…
Creating and reading velocity field, U…
Creating and calculating velocity flux field, phi…
Reading/calculating face flux field phi
Reading transport properties…
Reading the atmospheric boundary layer properties…
Specified wind at 80 m:
Time 0, wind from 240 degrees at 8 m/s
Time 50000, wind from 240 degrees at 8 m/s
+x is east and +y is north
N
0
W 270 -- -- 90 E
180
S
Omega [0 0 -1 0 0 0 0] (0 5.40430167656e-05 4.86605508618e-05)
Creating turbulence model…
Selecting turbulence model type LESModel
Selecting LES turbulence model dynLagrangianCsBound
Selecting LES delta type smooth
Selecting LES delta type cubeRootVol
dynLagrangianCsBoundCoeffs
filter simple;
ce 1.048;
theta 1.5;
Creating the Coriolis force vector, fCoriolis…
Creating kinematic (Boussinesq) density field, rhok…
Creating the kinematic thermal conductivity field, kappat…
Reading and creating the wall shear stress field, Rwall…
Reading and creating the wall temperature flux field, qwall…
Creating and calculating the gravity potential field, gh and ghf…
Creating and calculating the static pressure field, p…
Setting up the pressure reference cell information…
Creating mean temperature field, Tmean…
Creating fluctuating temperature field, Tprime…
Creating mean velocity field, Umean…
Creating fluctuating velocity field, Uprime…
Creating mean SGS stress field, Rmean…
Creating mean SGS temperature flux field, qmean…
Creating mean SGS viscosity field, nuSGSmean…
Initializing with zero pressure gradient…
Courant Number mean: 0.373333333393 max: 0.373333333333
Total number of cell center height levels: 100
78400 90000000
78400 90000000
Local Flux Continuity Error: Min 0 Max 3.39686165615e-14 Weighted Mean 8.87516162301e-17
Total Boundary Flux: 3.92910790963e-24
PIMPLE: Operating solver in PISO mode
Starting time loop
<U_1> = (8 0 0) <U_s> = (8 0 0) <dU/dn> = (0 0 0)
DILUPBiCG: Solving for flm, Initial residual = 1, Final residual = 0.00180675762046, No Iterations 1
DILUPBiCG: Solving for fmm, Initial residual = 1, Final residual = 0.00180675761966, No Iterations 1
TRef = 290
uStarMean = 0.817991099632 LMean = 9.99999999996e+29 phiMMean = 1
UParallelMeanMag = 8 UParallelPMeanMag = 8
RwMagMean = 0.669109439077 RwMeanMag = 0.669109439077 sqrt(RwMagMean) = 0.817991099632 sqrt(RwMeanMag) = 0.817991099632 uStarMean = 0.817991099632
z1Mean = 4.99999999999
TRef = 290
TSurfaceMean = 300 TAdjacentMean = 300 deltaTMean = 0
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in “/lib/x86_64-linux-gnu/libc.so.6”
#3 Foam::fixedHeatingRateFvPatchField::qwEvaluate(double&, double&, double&, double&, double&, double, double, double, double, double, double, double, double, double, double, double, double, double, double, int) at ??:?
#4 Foam::fixedHeatingRateFvPatchField::evaluate(Foam::UPstream::commsTypes) at ??:?
#5 Foam::GeometricField<Foam::Vector, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() at ??:?
#6
at ??:?
#7 __libc_start_main in “/lib/x86_64-linux-gnu/libc.so.6”
#8
at ??:?
Gleitkomma-Ausnahme (Speicherabzug geschrieben)
[/code]
Anyone out there who could help me resolve this issue? Is there a function that is used to replace the p_rgh.correctBoundaryConditions()???
Any help is greatly appreciated!
Thanks a lot!
Best, Thomas
