Hello everyone,
I’m still trying to create a ABLTerrainSolver case and it seems there are some bugs in the implementation
or am I doing something wrong? Somebody here who could help me with this case?
dropbox.com/s/d9zzp19qfasym … e.tgz?dl=0
It uses moveDynamicMesh to attach to the terrain and calls setFieldsABL afterwards. The ABLTerrainSolver
crashes with this error message:
PIMPLE: Operating solver in PISO mode
Starting time loop
<U_1> = (-1.25337e-05 15.0001 0) <U_s> = (0.0136353 14.5618 0.680718) <dU/dn> = (-0.000705281 0.0216922 -0.0335939)
DILUPBiCG: Solving for flm, Initial residual = 1, Final residual = 0.0359155, No Iterations 1
bounding flm, min: -0.0230707 max: 0.0223845 average: -4.22079e-05
DILUPBiCG: Solving for fmm, Initial residual = 1, Final residual = 0.0359094, No Iterations 1
bounding fmm, min: -0.00913156 max: 0.133026 average: 0.00141043
TRef = 300
uStarMean = 1.09808 LMean = 1e+30 phiMMean = 1
UParallelMeanMag = 14.5776 UParallelPMeanMag = 14.7777
RwMagMean = 1.20486 RwMeanMag = 1.20447 sqrt(RwMagMean) = 1.09766 sqrt(RwMeanMag) = 1.09748 uStarMean = 1.09808
Time = 21 Time Step = 21
Courant Number mean: 1.55351 max: 2.0861
deltaT = 0.358696
DILUPBiCG: Solving for Ux, Initial residual = 0.350015, Final residual = 1.96455e-16, No Iterations 6
DILUPBiCG: Solving for Uy, Initial residual = 0.970456, Final residual = 1.77876e-16, No Iterations 6
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.45511e-17, No Iterations 6
DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 5.24417e-16, No Iterations 6
GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00935106, No Iterations 11
<U_1> = (-0.0509501 15.9364 0.476419) <U_s> = (-0.0439888 15.6557 0.746193) <dU/dn> = (-0.000636055 0.0133576 -0.0127496)
DILUPBiCG: Solving for T, Initial residual = 0.242254, Final residual = 2.41253e-17, No Iterations 6
GAMG: Solving for p_rgh, Initial residual = 0.119069, Final residual = 0.00113359, No Iterations 8
<U_1> = (-0.0329056 15.9365 0.484592) <U_s> = (-0.0282349 15.7298 0.752945) <dU/dn> = (-0.000600525 0.0116376 -0.0125505)
DILUPBiCG: Solving for T, Initial residual = 0.237378, Final residual = 2.67629e-17, No Iterations 6
GAMG: Solving for p_rgh, Initial residual = 0.0170006, Final residual = 8.93181e-09, No Iterations 35
<U_1> = (-0.0303681 15.9439 0.485109) <U_s> = (-0.0256299 15.7398 0.752529) <dU/dn> = (-0.000603657 0.0115944 -0.0125146)
DILUPBiCG: Solving for T, Initial residual = 0.234728, Final residual = 9.29193e-17, No Iterations 6
Local Flux Continuity Error: Min 6.62286e-16 Max 1.27786 Weighted Mean 1.99251e-05
Total Boundary Flux: -5361.84
Total Boundary Area: 2.64029e+06
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3
at ??:?
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#5
at ??:?
I would loooove to find out why this is happening! I am using the current github release
of SOWFA and OpenFOAM 2.3.0 on a 14.04 XUbuntu 64bit system (to setup the case).
The case does only run up to this point due to the fact that I disabled the “fixedHeatingRate”
in the qwall file (0.orig folder) and set it to “zeroGradient”. There seems to be an error in
the patch field source too. Please help!
Best,
Thomas
