Dear Ali,
The rotor- and tail-furling degrees of freedom in FAST v7 are explained in the Model Description section of the old FAST User’s Guide: nwtc.nrel.gov/system/files/FAST.pdf (pages 12-14 and Figures 17-19).
Dear Ali,
Tell me if furling-Tail represent the blades rotations away from the direction of the wind, either horizontally or vertically.
And tell me also what is the difference between them and the yaw roation
I want also to know Mr jason if the flap-wise bending moment at the root of the pales is the moment at the tip or at the level of hub
" In FAST each blade is modelled by 3 DOFS flap-wise deflexion as well as torsion and the edge-wise deflexion". I have found also other nomination ‘’ Each blade is modelled by 3 DOFS which are the first and second flap-wise and the first edge-wise modes". Can you please confirm or explain these sentences and what is the relations between them
Sincerely yours
Dear Ali,
Yes, either rotor- or tail-furling will result in the rotor skewing out of the primary wind direction to reduce thrust, power, etc. The difference between furling and yawing is the location/orientation of the hinge; also, furling is typically passive whereas yawing is often actively controlled.
I’m sorry, but I don’t understand your question about the flapwise moment.
I’m not sure where these sentences came from, but only the second one is correct for the ElastoDyn module of FAST: “Each blade is modelled by 3 DOFS which are the first and second flap-wise and the first edge-wise modes.”
Thank you very much Mr Jason
I meant what represent the “flap-wise bending moment at the root of the blades”. Normally the moment is always calculated according an point, tell me at which point is calculated this moment in the figure attached
Dear Ali,
The ElastoDyn module of FAST will calculate the blade-root loads about the point where the blade-pitch axis intersects with the blade root plane. Normally this point would be at the center of the pitch bearing, but the “root” location in the numerical FAST model is really up to who put the FAST model together.
Mr Jason
Thank you for your reply
I have found in litterature that the WT may be modelled from one to sex MASS model
I have found that in FAST the drive train is two mass model (2DOFs) in addition 9 DOFs of the blades. If we take the sex mass model we found the blades are modelled by 3 inertia, hub one, gerabox one and the generator one.
Can you please explain me what is the relation between the modelisation by mass ( 3, 6 mass) and the modelisation by DOFs (24 DOFS)
Dear Ali,
I’m not familiar with the 6-mass model you are referring to. Is this a model composed of 6 rigid bodies and 6 rotational joints?
On which model is based FAST. I found it is based on the modularization , can we said that the components of the WT is modelled as bodies linked with DOFs?
Dear Ali,
Please see the following forum topic for more information on the theory basis of the ElastoDyn module of FAST: Coupled blade modes in FAST. Of course, FAST has other structural modules e.g. BeamDyn for advanced blade dynamics and SubDyn for substructures.
A simple aking, when we said the first and second flap-wise mode, tel me if it means the bending and its derivative, or what
Dear Ali,
The first and second flapwise modes are the first two bending modes of the blade (associated with the first and second natural frequencies, respectively).
Sorry for my multiples asking, but my thesis is based on this code AND I nedded to know these details
Tel me again if some structures of the code are based on finite element method, or what position of this method in this simulateur
Sincerely yours
Dear Ali,
The SubDyn module of FAST is based on a linear beam finite-element approach and the BeamDyn module of FAST is based on a nonlinear beam finite-element approach. I wouldn’t call the ElastoDyn module a finite-element approach, although the tower and blades are similar to a finite-element approach in that shape functions (in this case mode shapes) are used to form generalized mass, stiffness, and damping matrices (and geometric nonlinear terms as well). However–as described in the forum topic I linked above: Coupled blade modes in FAST --ElastoDyn employs a combined modal and multibody dynamics formulation.
