I am working on the linearization of a direct-drive wind turbine and would like to examine the modal behavior of the model through feature analysis. I am using ‘runLinTurbine.py’ and would like to try linearization for the power generation state at rated wind speed. I have a few questions:
Due to linearization, I had to use simple variable-speed torque control. Is this option correct?
Could you please explain the specific meanings of these four parameters, especially the fourth one?
VS_RtGnSp - Rated generator speed for simple variable-speed generator control (HSS side) (rpm) [used only when VSContrl=1]
VS_RtTq - Rated generator torque/constant generator torque in Region 3 for simple variable-speed generator control (HSS side) (N-m) [used only when VSContrl=1]
VS_Rgn2K - Generator torque constant in Region 2 for simple variable-speed generator control (HSS side) (N-m/rpm^2) [used only when VSContrl=1]
VS_SlPc - Rated generator slip percentage in Region 2 1/2 for simple variable-speed generator control (%) [used only when VSContrl=1]
The reason for asking these question is that I encountered an error while running: ‘FAST_Solution:FAST_AdvanceStates:SrVD_UpdateStates:CalculateTorque:u%HSS_Spd is negative. Simple variable-speed control model is not valid for motoring situations.’ What does this error mean?
Thanks in advance for any help.
Chen
