Hello all,
Very brief question regarding the Primary Wind Speed Channel (WSChan) in an MLife input file.
I have some cases where my turbine is yawed by 60 degrees, the results are correct & match hand-calcs.
However, when I use MLife to process the data I can only specify one primary wind speed channel. I can’t seem to figure out if I can use the resultant wind speed (Between x-axis and y-axis for example). This is effecting my binning as I can’t compare with other cases correctly (aligned with 0 degrees)
I’d like to use the resultant, otherwise I am under evaluating the actual in-line wind speed
Is this possible? or will I have to modify my FAST .INP file to request some resultant value and re-run some cases?
UPDATE:
I believe I can achieve what I want by using the “HorWindV” or “TotWindV” in my InflowWind file as listed in the OutlistParameters speadsheet. However, when I request them - I get “INVALID” in my .OUT file.
Have these output requests changed? Maybe in their spelling etc…
