Hello to all.
I have a very basic question about MoorDyn that I am embarrassed to ask in the Forum, but I have seen that it can sometimes cause confusion.
The DNV OS E301 standard states that the drag force per unit length is 1/2 rho Cd D v |v| where, for studless chain, Cd_longitudinal = 1.15 and Cd_transverse = 2.4.
What are the formulas for obtaining MoorDyn’s Cd, Ca, CdAx, and CaAx values from the standard values?
Considering that d is the chain link diameter, are these correct?
Cd = 1.15*d
Ca = 1
CdAx = 2.4*d*PI
CaAx = 0.5
Iñaki
Hi @Inaki.Zabala ,
The coefficients you input to MoorDyn don’t need to be modified with any diameter or Pi factors, that is all handled internally (example here). The equation internal to MoorDyn is the same as the one you cite above. One thing to be careful of is MoorDyn uses the volumetric diameter, not the nominal diameter of chain
Thank you @Ryan.Davies
So from the user point of view, using
Cd = 1.15
Ca = 1
CdAx = 2.4
CaAx = 0.5
is a good start point for a studless chain?
Iñaki
Hi @Inaki.Zabala ,
That would be a good start, but you need to account for volumetric diameter. We typically use the values in MoorPy as our starting points, with the coefficients have already been adjusted for volumetric diameter (instead of chain nominal diameter): MoorPy/moorpy/MoorProps_default.yaml at dev · NREL/MoorPy · GitHub
Hi @Ryan.Davies
So, if Diam is the volume-equivalent diameter of the line (the diameter of a cylinder having the same displacement per unit length), in meters, the equations would be like these?:
CdAx = 1.15*Diam
Cd = 2.4*Diam
Iñaki
You need to multiply by the ratios of diameters, because MoorDyn internally multiplies the drag coefficient by the volumetric diameter when calculating hydrodynamics. So the inputs to MoorDyn would be like this:
Cd_vol = Cd_nom (D_nom/D_vol)
For studless chain, D_vol/D_nom is 1.8, so from DNV standards 2.4 / 1.8 = 1.33 (which is what we have in MoorPy).
Thank you Ryan. Now I understand.
Iñaki
Dear @Ryan.Davies ,
I have several questions regarding certain parameters in the MoorDyn input file for the Test #25: NREL 5.0 MW Baseline Wind Turbine with OC4-DeepCwind Semi case. Based on correspondences with the literature (M. Hall and A. Goupee, “Validation of a lumped-mass mooring line model with DeepCwind semisubmersible model test data,” 2015), the following represents my understanding; I would appreciate confirmation of whether it is correct.
Cd corresponds to Cdn in Equation (8) , Ca corresponds to Can in Equation (10); CdAx corresponds to Cdt in Equation (9), and CaAx corresponds to Cat in Equation (10). The equation numbers refer to those in the above-mentioned reference.
Kbot and cbot correspond to kb and cb in Equation (12), respectively.
Hi @Yangyang.Li, those are all correct.
