Dear @Matthew.Hall ,
Sorry for being so demanding ! (I just wanna understand what is done behind MoorDyn dll).
I was reading MoorDyn User’s Guide - December15, 2015. So, if i understand well:
dtC is the coupling time step. Is it user defined ? In fact, it is written in page 4 that MoorDyn adjusts its internal time step size dtM. For me, dtM is specified in the input file in solver options. Could you please clarify this point ?
I will say that dtC is user defined. Therefore, it is an input argument for the function LinesCalc (MoorDyn in C++). If i fix dtC to 0.01 sec and dtM is defined in the input file and it equals 0.001 sec, that means MoorDyn will do calculation for N =dtC/dtM=10 steps ?? Could i choose these two parameters such that N=1 in order to let MoorDyn computes fast ?
Finally, in order to be sure that i get it: In the page 13 in the same document, you provide an example how to couple MoorDyn with MATLAB. In this example the variable dt is dtC right ?
Best Regards
Riad
              Also, i have another question if you dont mind.
in this paper: Validation of a lumped-mass mooring line model with DeepCwind semisubmersible model test data - ScienceDirect.
you said that MoorDyn neglects wave kinematics and you justify that in section 3.4
This neglection is valid in the standalone version of MoorDyn and not in OpenFast right ?
Riad
              Dear @Jason.Jonkman
In OpenFast, when MoorDyn wants to compute tension forces, it is given the position and the velocity of the fairleads right ? the units of the angular position in the position vector is degree or radians ?
Riad
              Hi Riad,
Sorry, I don’t check this forum enough. Here are a few responses:
- Angular units for MoorDyn function calls are radians.
- The validity of neglecting wave kinematics depends entirely on the scenario being simulated. Currently in OpenFAST, MoorDyn does not include wave kinematics by default. There is a special manual way of doing it, but it is not documented and requires running twice as many simulations. In future work we will make a direct coupling between SeaState wave kinematics data and MoorDyn.
- The coupling time step, dtC, is determined by whatever code calls MoorDyn. For example, it is usually equal to the global time step in OpenFAST, or in a custom code it can be set to whatever you like.
- Your dtC/dtM math is correct. Setting dtC=dtM is usually a bad idea because MoorDyn often needs a small dtM for stability.
- In the original Matlab coupling example, what’s written as dt is the dtC value, yes.
Best,
Matt
