Dear Dr.Jonkman,
Am trying to understand how the Moordyn line properties are arrived in default OC4 Semi submersible and OC3 Hywind. OC4 default semisub has a Moordyn file  of its own but OC3 does not have.Still in Moordyn manual there is an example file posted for OC3 Hywind Moordyn. So am comparing these two. Based on the paper ‘validation of lumped mass mooring line model with DeepC semisubmerisble model test data’ and other references I understand that we
step 1:choose Diameter& massdensity (MassDen)of the line first(may be from manufactures)
step 2:then find (equivalent)volume diameter i.e Diam_vol=sqrt((4 x MassDen)/(7850 x pi)).
step 3:Then followed by finding the using the below formula from DNV-GL
step 4:Modulus=[6 −0.0033 x Diam_vol] x 〖10〗^10   (Diam in mm)
step 4.a: If modulus if less than 5.6e10 then modulus is 5.6e10 based on DNV OS E301
step 5:And then   Area=MasDen/7850 and finally E*A which is the stiffness of the line
If I follow these steps I could able to achieve the default OC4 line properties but am not able to get the default OC3 line properties(from Moordyn manual)
Default OC4 Line
1        NTypes    - number of LineTypes
Name     Diam      MassDen      EA    BA/-zeta  Can   Cat   Cdn   Cdt
(-)       (m)         (kg/m)       (N)       (N-s/-)   (-)       (-)   (-)   (-)
main     0.0766    113.35     7.536E8  -1.0     0.8     0.25  2.0   0.4
OC3 Line(From Manual)
(-) (     m)     (kg/m)     (N)       (N-s/-)    (-)   (-)  (-)  (-)
main 0.09   77.7066 384.243E6 -0.8      1.0   0.0  1.6  0.1
Kindly correct if my understanding on this concept is wrong and if is not kindly guide me on why am not able to get the values in case of OC3 Hywind.
Krishnaveni
              Dear Krishnaveni,
I’m not familiar with the formulas you obtained from DNV GL, but your equations relating MassDen and Diam assume that the mooring line cross section is circular and made of steel.  This may not always be a great assumption.
Regardless, the values of Diam, MassDen, and EA that you’ve stated for the OC4-DeepCwind semisubmersible and OC3-Hywind spar match those given in their specifications reports: nrel.gov/docs/fy10osti/47535.pdf (OC3).  I’m assuming these reports were the sources used to create these MoorDyn models.
              Dear Dr.Jonkman,
Thank you for your response to my earlier queries. I have one another question related to Moordyn Module
Am trying to do an analysis with anchors at varying depth both in Moordyn and in MAP++ modules
But am not able do it successfully.Below are my corresponding input files and the outputs am getting.
Platform -OC3 Hywind Spar
Water depth- 200m
Radial distance-800m
Mooring line properties modified accordingly.
Moordyn Input file:
--------------------- MoorDyn Input File ------------------------------------
Mooring system for OC3-Hywind
FALSE    Echo      - echo the input file data (flag)
----------------------- LINE TYPES ------------------------------------------
main     0.09        168       1.15E9   -0.8    0.55  0.27  1.0   0.19
---------------------- CONNECTION PROPERTIES --------------------------------
6       NConnects - number of connections including anchors and fairleads
Node    Type      X        Y        Z       M     V      FX   FY   FZ   CdA   CA
(-)     (-)      (m)      (m)      (m)     (kg)  (m^3)  (kN) (kN) (kN) (m^2)  (-)
1      Fixed   400.00	   692.8	 -202.0     0      0      0    0    0    0     0
2      Fixed  -800.00	    0.00	 -200.0     0      0      0    0    0    0     0
3      Fixed   400.00	  -692.8	 -201.0     0      0      0    0    0    0     0
4      Vessel   2.6	   4.50      -70.0     0      0      0    0    0    0     0
5      Vessel   -5.2      0	     -70.0     0      0      0    0    0    0     0
6      Vessel   2.60	  -4.50	     -70.0     0      0      0    0    0    0     0
---------------------- LINE PROPERTIES --------------------------------------
3        NLines    - number of line objects
Line    LineType  UnstrLen  NumSegs   NodeAnch  NodeFair  Flags/Outputs
(-)       (-)       (m)       (-)       (-)       (-)         (-)
1         main     830      20        1         4           p
2         main     830      20        2         5           p
3         main     830      20        3         6           p
---------------------- SOLVER OPTIONS ---------------------------------------
0.001    dtM       - time step to use in mooring integration (s)
3.0e6    kbot      - bottom stiffness (Pa/m)
3.0e5    cbot      - bottom damping (Pa-s/m)
2.0      dtIC      - time interval for analyzing convergence during IC gen (s)
200      WtrDpth   - water depth (m)
60.0     TmaxIC    - max time for ic gen (s)
4.0      CdScaleIC - factor by which to scale drag coefficients during dynamic relaxation (-)
0.01    threshIC  - threshold for IC convergence (-)
------------------------ OUTPUTS --------------------------------------------
FairTen1
FairTen2
FairTen3
AnchTen1
AnchTen2
AnchTen3
Con1fX
Con1fY
Con1fZ
Con2fX
Con2fY
Con2fZ
Con3fX
Con3fY
Con3fZ
END
------------------------- need this line --------------------------------------
Output
Am getting really large anchors forces (10000x) than when the anchors are at constant depth.
Map++ input file
---------------------- LINE DICTIONARY ---------------------------------------
LineType     Diam     MassDenInAir    EA        CB    CIntDamp   Ca   Cdn   Cdt
(-)          (m)      (kg/m)         (N)       (-)     (Pa-s)    (-)  (-)   (-)
Material     0.09     168            1.15E9     1         00    0.61 -1.0  0.19
---------------------- NODE PROPERTIES ---------------------------------------
Node Type       X        Y        Z     M     B     FX    FY    FZ
(-)  (-)       (m)      (m)      (m)   (kg)  (mˆ3)  (N)   (N)   (N)
1    fix     400.0    692.00    - 202   0     0     #     #     #
2    Vessel   2.6      4.5      -70.0   0     0     #     #     #
3    fix    -800.0      0.0       -200   0     0     #     #     #
4    Vessel  -5.2     0.0      -70.0   0     0     #     #     #
5    fix     400.0    -692.00    -201   0     0     #     #     #
6    Vessel    2.6     -4.5    -70.0   0     0     #     #     #
---------------------- LINE PROPERTIES ---------------------------------------
Line   LineType  UnstrLen    NodeAnch  NodeFair  Flags
1       Material   830.00      1         2        tension_fair tension_anch
2       Material   830.00      3         4        tension_fair tension_anch
3       Material   830.00      5         6        tension_fair tension_anch
Output
In  case of using MAP++ am not able to get anchor forces from line 2 and line 3 ,they are always zero. Only line 1 has forces in it.
Kindly help me in fixing it /guide me where I could have gone wrong.
Krishnaveni
              Dear Krishnaveni,
MoorDyn is not set up to handle non-uniform seabed depths at this time. You can specify different anchor depths, but only one depth (specified by  WtrDpth) will be used to model lines resting on the seabed. Positioning a line end below the seabed depth, as you do in your MoorDyn input file, could create very large seabed contact forces. I’d suggest ensuring WtrDpth is greater than or equal to the depth of all your anchors, then trying the simulation again.
I’m not as familiar with MAP++. My understanding is it will permit different lines to have different anchor depths and assume that seabed contact occurs at that same depth. If that’s correct, I’m not sure why some of the lines would have zero anchor tension.
Best,
Matt
              Hi all,
I am a new user of OpenFAST and I am trying to figure out how to pick up values for the ‘‘Line Types’’ MoorDyn module and more specifically values for BA/-zeta  Can   Cat   Cdn   Cdt
I couldn’t find extra information about MoorDyn at GitHub repository. Is there any manual that could help me?
Thank you in advance.
Ioannis.
              Dear Ionnis,
You can find more information on MoorDyn, including user and theory documentation, on Matt Hall’s website: matt-hall.ca/moordyn.html.
I would like to ask if it is possible to run the MoorDyn independently. If it is possible, where could I find the executable file?
Ioannis.
              Dear Ioannis,
MoorDyn doesn’t model a floating platform itself, so it isn’t set up to run purely independently. However, it is common to use a script to “drive” the fairlead motions in MoorDyn’s for a simplified analysis focused on the mooring system. The specified fairlead motions can even be zero if you’re only interested in the static mooring system behavior (though in that case using MAP++/pyMAP might be a better choice).
There should be an example of driving MoorDyn using Matlab in the archive on my old website. I aim to have a more complete set of examples available on a new readthedocs website in the future. In the meantime, let me know if there’s a specific example or use case you’re in need of.
Best,
Matt
              Dear Prof. Jonkman
I am a new user of FAST v8 and had been using it to design the DeepCWind platform for different environmental conditions. When I increase the water depth, I need to increase the unstretched length and also the coordinates of the anchor position. I don’t understand how do we do that. Do we assume a random value?
Reeti
Masters, Marine Structures
              Dear Reeti,
Yes, you would need to update the mooring inputs when changing the water depth.  This typically requires a redesign of the mooring system.  I’m not sure I understand what you trying to do, but in lieu of a a mooring system redesign, some geometric scaling of a given mooring system (in terms of unstretched length and anchor radius) to the different water depth may be satisfactory.  I’d aim to have a similar level of pretension at the fairleads when changing the mooring system parameters through scaling.
