See message I get below when running the Crunch test- I think I am giving the correct syntax
C:\Apps\Crunch\CertTest>Crunch_RegTest.py win32
Syntax is:
Crunch_RegTest.py <ExecType>
where is one of: win32, win64, gwin32, or gwin64.
Example:
will execute Crunch_win32.exe.
Dear Marshall.Buhl, Greg Hayman and Bonnie Jonkman,
I also have the same problem as Scott has on getting the Crunch_RegTest.py to run, under the \CertTest folder of the Crunch_v3.02.00c-mlb released version .
I installed the Anaconda2 (python 2.7, 32-bit version), and ran the following command:
Thereafter, there was no response from the system except that the script file Crunch_RegTest.py was automatically opened .
My system is 64-bit Windows 7.
Later I also tried using the “win64” method through the same way (install Anaconda3 <python 3.5, 64-bit version> and run the command “Crunch_RegTest.py win64”), however, leading to the same response.
Could you give any advice on how to resolve this problem? As I think it is common.
Thanks a lot in advance.
Yingyi Liu
