Hi all,
I am trying to design baseline torque controller and pitch controller as the description of Chapter 7.2 and 7.3 of this Pdf " [url]http://www.nrel.gov/docs/fy09osti/38060.pdf[/url]" .Now I have some confusion about the baseline torque controller. The curve between generator torque and generator speed is like the blue one in Figure 1
. I set the wind speed is a constant 18m/s and results are obtained like in Figure 2. You can see the generator power and torque both have some fluctuation at near 11s -16s which is caused by the little fluctuation of the rotor speed. I found this is because when the generator speed vibrates lightly between region 2 1/2 and region 3, the output torque and power have a big fluctuation showed in Figure 2. I think the fluctuation of generator power like in Figure 2 is caused by the region 2 1/2. What’s the purpose of the region 2 1/2?Because the above problem, when I set the wind speed as changing, the generator power fluctuated too much like in Figure 3
. Can anyone help me to explain or solve this problem? It drives me crazy. Thank you so much!All the best.
Yanhua
