Dear @Jason.Jonkman ,
For the simulations I’m using the files provided in IEA’s page in github with some alterations to fit my specific case. I’m using a TurbSim box with a spatial resolution of 10 m and a time step of 0.1 s . In case you want to check the files used in FAST.Farm:
------- InflowWind v3.01.* INPUT FILE -------------------------------------------------------------------------Generated with AeroElasticSE FAST driver
False Echo - Echo input data to .ech (flag)3 WindType - switch for wind file type (1=steady; 2=uniform; 3=binary TurbSim FF; 4=binary Bladed-style FF; 5=HAWC format; 6=User defined; 7=native Bladed FF)0.0 PropagationDir - Direction of wind propagation (meteorological rotation from aligned with X (positive rotates towards -Y) – degrees) (not used for native Bladed format WindType=7)0.0 VFlowAng - Upflow angle (degrees) (not used for native Bladed format WindType=7)False VelInterpCubic - Use cubic interpolation for velocity in time (false=linear, true=cubic) [Used with WindType=2,3,4,5,7]1 NWindVel - Number of points to output the wind velocity (0 to 9)0.0 WindVxiList - List of coordinates in the inertial X direction (m)0.0 WindVyiList - List of coordinates in the inertial Y direction (m)119.0 WindVziList - List of coordinates in the inertial Z direction (m)================== Parameters for Steady Wind Conditions [used only for WindType = 1] =========================5.0 HWindSpeed - Horizontal windspeed (m/s)119.0 RefHt - Reference height for horizontal wind speed (m)0.2 PLexp - Power law exponent (-)================== Parameters for Uniform wind file [used only for WindType = 2] ============================“none” Filename_Uni - Filename of time series data for uniform wind field. (-)119.0 RefHt_Uni - Reference height for horizontal wind speed (m)1.0 RefLength - Reference length for linear horizontal and vertical sheer (-)================== Parameters for Binary TurbSim Full-Field files [used only for WindType = 3] ==============“90m_10mps.bts” FileName_BTS - Name of the Full field wind file to use (.bts)================== Parameters for Binary Bladed-style Full-Field files [used only for WindType = 4 or WindType = 7] =========“none” FilenameRoot - WindType=4: Rootname of the full-field wind file to use (.wnd, .sum); WindType=7: name of the intermediate file with wind scaling valuesFalse TowerFile - Have tower file (.twr) (flag) ignored when WindType = 7================== Parameters for HAWC-format binary files [Only used with WindType = 5] =====================“none” FileName_u - name of the file containing the u-component fluctuating wind (.bin)“none” FileName_v - name of the file containing the v-component fluctuating wind (.bin)“none” FileName_w - name of the file containing the w-component fluctuating wind (.bin)2 nx - number of grids in the x direction (in the 3 files above) (-)2 ny - number of grids in the y direction (in the 3 files above) (-)2 nz - number of grids in the z direction (in the 3 files above) (-)10 dx - distance (in meters) between points in the x direction (m)10 dy - distance (in meters) between points in the y direction (m)10 dz - distance (in meters) between points in the z direction (m)0.0 RefHt_Hawc - reference height; the height (in meters) of the vertical center of the grid (m)------------- Scaling parameters for turbulence ---------------------------------------------------------2 ScaleMethod - Turbulence scaling method [0 = none, 1 = direct scaling, 2 = calculate scaling factor based on a desired standard deviation]1.0 SFx - Turbulence scaling factor for the x direction (-) [ScaleMethod=1]1.0 SFy - Turbulence scaling factor for the y direction (-) [ScaleMethod=1]1.0 SFz - Turbulence scaling factor for the z direction (-) [ScaleMethod=1]1.0 SigmaFx - Turbulence standard deviation to calculate scaling from in x direction (m/s) [ScaleMethod=2]1.0 SigmaFy - Turbulence standard deviation to calculate scaling from in y direction (m/s) [ScaleMethod=2]1.0 SigmaFz - Turbulence standard deviation to calculate scaling from in z direction (m/s) [ScaleMethod=2]------------- Mean wind profile parameters (added to HAWC-format files) ---------------------------------12 URef - Mean u-component wind speed at the reference height (m/s)2 WindProfile - Wind profile type (0=constant;1=logarithmic,2=power law)0.2 PLExp_Hawc - Power law exponent (-) (used for PL wind profile type only)0.03 Z0 - Surface roughness length (m) (used for LG wind profile type only)0 XOffset - Initial offset in +x direction (shift of wind box) (-)================== LIDAR Parameters ===========================================================================0 SensorType - Switch for lidar configuration (0 = None, 1 = Single Point Beam(s), 2 = Continuous, 3 = Pulsed)0 NumPulseGate - Number of lidar measurement gates (used when SensorType = 3)30 PulseSpacing - Distance between range gates (m) (used when SensorType = 3)0 NumBeam - Number of lidar measurement beams (0-5)(used when SensorType = 1)-200 FocalDistanceX - Focal distance co-ordinates of the lidar beam in the x direction (relative to hub height) (only first coordinate used for SensorType 2 and 3) (m)0 FocalDistanceY - Focal distance co-ordinates of the lidar beam in the y direction (relative to hub height) (only first coordinate used for SensorType 2 and 3) (m)0 FocalDistanceZ - Focal distance co-ordinates of the lidar beam in the z direction (relative to hub height) (only first coordinate used for SensorType 2 and 3) (m)0.0 0.0 0.0 RotorApexOffsetPos - Offset of the lidar from hub height (m)17 URefLid - Reference average wind speed for the lidar[m/s]0.25 MeasurementInterval - Time between each measurement [s]False LidRadialVel - TRUE => return radial component, FALSE => return ‘x’ direction estimate1 ConsiderHubMotion - Flag whether to consider the hub motion’s impact on Lidar measurements====================== OUTPUT ==================================================True SumPrint - Print summary data to .IfW.sum (flag)OutList - The next line(s) contains a list of output parameters. See OutListParameters.xlsx for a listing of available output channels, (-)“Wind1VelX” X-direction wind velocity at point WindList(1)“Wind1VelY” Y-direction wind velocity at point WindList(1)“Wind1VelZ” Z-direction wind velocity at point WindList(1)END of input file (the word “END” must appear in the first 3 columns of this last OutList line)
------- OpenFAST INPUT FILE -------------------------------------------
False Echo - Echo input data to <RootName>.ech (flag)
"FATAL" AbortLevel - Error level when simulation should abort (string) {"WARNING", "SEVERE", "FATAL"}
1.0 TMax - Total run time (s)
0.0025 DT - Recommended module time step (s)
1 InterpOrder - Interpolation order for input/output time history (-) {1=linear, 2=quadratic}
99999.0 DT_UJac - Time between calls to get Jacobians (s)
1000000.0 UJacSclFact - Scaling factor used in Jacobians (-)
1 CompElast - Compute structural dynamics (switch) {1=ElastoDyn; 2=ElastoDyn + BeamDyn for blades; 3=Simplified ElastoDyn}
1 CompInflow - Compute inflow wind velocities (switch) {0=still air; 1=InflowWind; 2=external from ExtInflow}
2 CompAero - Compute aerodynamic loads (switch) {0=None; 1=AeroDisk; 2=AeroDyn; 3=ExtLoads}
0 CompSeaSt - Compute sea state information (switch) {0=None; 1=SeaState}
0 CompHydro - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
0 CompSub - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn; 2=External Platform MCKF}
0 CompMooring - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
0 MHK - MHK turbine type (switch) {0=Not an MHK turbine; 1=Fixed MHK turbine; 2=Floating MHK turbine}
0 WtrDens - Water density (kg/m^3)
1.464e-05 KinVisc - Kinematic viscosity of working fluid (m^2/s)
335 SpdSound - Speed of sound in working fluid (m/s)
103500 Patm - Atmospheric pressure (Pa) [used only for an MHK turbine cavitation check]
1700 Pvap - Vapour pressure of working fluid (Pa) [used only for an MHK turbine cavitation check]
000 WtrDpth - Water depth (m)
0 MSL2SWL - Offset between still-water level and mean sea level (m) [positive upward]
"IEA-10.0-198-RWT_ElastoDyn.dat" EDFile - Name of file containing ElastoDyn input parameters (quoted string)
"unused" BDBldFile(1) - Name of file containing BeamDyn input parameters for blade 1 (quoted string)
"unused" BDBldFile(2) - Name of file containing BeamDyn input parameters for blade 2 (quoted string)
"unused" BDBldFile(3) - Name of file containing BeamDyn input parameters for blade 3 (quoted string)
"IEA-10.0-198-RWT_InflowFile.dat" InflowFile - Name of file containing inflow wind input parameters (quoted string)
"IEA-10.0-198-RWT_AeroDyn15.dat" AeroFile - Name of file containing aerodynamic input parameters (quoted string)
"IEA-10.0-198-RWT_ServoDyn_WT1.dat" ServoFile - Name of file containing control and electrical-drive input parameters (quoted string)
"IEA-10.0-198-RWT_SeaState.dat" SeaStFile - Name of file containing sea state input parameters (quoted string)
"IEA-10.0-198-RWT_HydroDyn.dat" HydroFile - Name of file containing hydrodynamic input parameters (quoted string)
"IEA-10.0-198-RWT_SubDyn.dat" SubFile - Name of file containing sub-structural input parameters (quoted string)
"none" MooringFile - Name of file containing mooring system input parameters (quoted string)
"none" IceFile - Name of file containing ice input parameters (quoted string)
False SumPrint - Print summary data to "<RootName>.sum" (flag)
10.0 SttsTime - Amount of time between screen status messages (s)
99999.0 ChkptTime - Amount of time between creating checkpoint files for potential restart (s)
0.1 DT_Out - Time step for tabular output (s) (or "default")
20.0 TStart - Time to begin tabular output (s)
3 OutFileFmt - Format for tabular (time-marching) output file (switch) {1: text file [<RootName>.out], 2: binary file [<RootName>.outb], 3: both 1 and 2, 4: uncompressed binary [<RootName>.outb, 5: both 1 and 4}
True TabDelim - Use tab delimiters in text tabular output file? (flag) {uses spaces if false}
"ES10.3E2" OutFmt - Format used for text tabular output, excluding the time channel. Resulting field should be 10 characters. (quoted string)
False Linearize - Linearization analysis (flag)
False CalcSteady - Calculate a steady-state periodic operating point before linearization? [unused if Linearize=False] (flag)
3 TrimCase - Controller parameter to be trimmed {1:yaw; 2:torque; 3:pitch} [used only if CalcSteady=True] (-)
0.001 TrimTol - Tolerance for the rotational speed convergence [used only if CalcSteady=True] (-)
0.01 TrimGain - Proportional gain for the rotational speed error (>0) [used only if CalcSteady=True] (rad/(rad/s) for yaw or pitch; Nm/(rad/s) for torque)
0.0 Twr_Kdmp - Damping factor for the tower [used only if CalcSteady=True] (N/(m/s))
0.0 Bld_Kdmp - Damping factor for the blades [used only if CalcSteady=True] (N/(m/s))
2 NLinTimes - Number of times to linearize (-) [>=1] [unused if Linearize=False]
30.000000, 60.000000 LinTimes - List of times at which to linearize (s) [1 to NLinTimes] [used only when Linearize=True and CalcSteady=False]
1 LinInputs - Inputs included in linearization (switch) {0=none; 1=standard; 2=all module inputs (debug)} [unused if Linearize=False]
1 LinOutputs - Outputs included in linearization (switch) {0=none; 1=from OutList(s); 2=all module outputs (debug)} [unused if Linearize=False]
False LinOutJac - Include full Jacobians in linearization output (for debug) (flag) [unused if Linearize=False; used only if LinInputs=LinOutputs=2]
False LinOutMod - Write module-level linearization output files in addition to output for full system? (flag) [unused if Linearize=False]
0 WrVTK - VTK visualization data output: (switch) {0=none; 1=initialization data only; 2=animation}
1 VTK_type - Type of VTK visualization data: (switch) {1=surfaces; 2=basic meshes (lines/points); 3=all meshes (debug)} [unused if WrVTK=0]
False VTK_fields - Write mesh fields to VTK data files? (flag) {true/false} [unused if WrVTK=0]
10.0 VTK_fps - Frame rate for VTK output (frames per second){will use closest integer multiple of DT} [used only if WrVTK=2]
------- FAST.Farm for OpenFAST INPUT FILE -------------------------------------------------
FAST.Farm input file, using two turbines separated by 3D downstream and an offset of 30m, with a turbulent inflow given by one turbsim box
False Echo - Echo input data to <RootName>.ech? (flag)
FATAL AbortLevel - Error level when simulation should abort (string) {"WARNING", "SEVERE", "FATAL"}
700 TMax - Total run time (s) [>=0.0]
False UseSC - Use a super controller? (flag)
2 Mod_AmbWind - Ambient wind model (-) (switch) {1: high-fidelity precursor in VTK format, 2: one InflowWind module, 3: multiple instances of InflowWind module}
2 Mod_WaveField - Wave field handling (-) (switch) {1: use individual HydroDyn inputs without adjustment, 2: adjust wave phases based on turbine offsets from farm origin}
0 Mod_SharedMooring - Shared mooring system model (switch) {0: None, 3=MoorDyn}}
--- SUPER CONTROLLER --- [used only for UseSC=True]
"unused" SC_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} containing the Super Controller algorithms (quoated string)
--- SHARED MOORING SYSTEM --- [used only for Mod_SharedMoor>0]
"" SharedMoorFile - Name of file containing shared mooring system input parameters (quoted string) [used only when Mod_SharedMooring > 0]
0.04 DT_Mooring - Time step for farm-level mooring coupling with each turbine (s) [used only when Mod_SharedMooring > 0]
true WrMooringVis - Write shared mooring visualization, at the global FAST.Farm time step (-) [only used for Mod_SharedMooring=3]
--- AMBIENT WIND: PRECURSOR IN VTK FORMAT --- [used only for Mod_AmbWind=1]
3.0 DT_Low-VTK - Time step for low -resolution wind data input files; will be used as the global FAST.Farm time step (s) [>0.0]
0.1 DT_High-VTK - Time step for high-resolution wind data input files (s) [>0.0]
"unused" WindFilePath - Path name to VTK wind data files from precursor (string)
False ChkWndFiles - Check all the ambient wind files for data consistency? (flag)
--- AMBIENT WIND: INFLOWWIND MODULE --- [used only for Mod_AmbWind=2 or 3]
3.0 DT_Low - Time step for low -resolution wind data interpolation; will be used as the global FAST.Farm time step (s) [>0.0]
0.1 DT_High - Time step for high-resolution wind data interpolation (s) [>0.0]
223 NX_Low - Number of low -resolution spatial nodes in X direction for wind data interpolation (-) [>=2]
141 NY_Low - Number of low -resolution spatial nodes in Y direction for wind data interpolation (-) [>=2]
23 NZ_Low - Number of low -resolution spatial nodes in Z direction for wind data interpolation (-) [>=2]
-250 X0_Low - Origin of low -resolution spatial nodes in X direction for wind data interpolation (m)
-700.0 Y0_Low - Origin of low -resolution spatial nodes in Y direction for wind data interpolation (m)
5.0 Z0_Low - Origin of low -resolution spatial nodes in Z direction for wind data interpolation (m)
10.17 dX_Low - Spacing of low -resolution spatial nodes in X direction for wind data interpolation (m) [>0.0]
10.0 dY_Low - Spacing of low -resolution spatial nodes in Y direction for wind data interpolation (m) [>0.0]
10 dZ_Low - Spacing of low -resolution spatial nodes in Z direction for wind data interpolation (m) [>0.0]
46 NX_High - Number of high-resolution spatial nodes in X direction for wind data interpolation (-) [>=2]
25 NY_High - Number of high-resolution spatial nodes in Y direction for wind data interpolation (-) [>=2]
24 NZ_High - Number of high-resolution spatial nodes in Z direction for wind data interpolation (-) [>=2]
"IEA-10.0-198-RWT_InflowFile.dat" InflowFile - Name of file containing InflowWind module input parameters (quoted string)
--- WIND TURBINES ---
2 NumTurbines - Number of wind turbines (-) [>=1] [last 6 columns below used only for Mod_AmbWind=2 or 3]
WT_X WT_Y WT_Z WT_FASTInFile X0_High Y0_High Z0_High dX_High dY_High dZ_High
(m) (m) (m) (string) (m) (m) (m) (m) (m) (m)
0 0 0 "IEA-10.0-198-RWT1.fst" -100.49 -120.0 5.0 10.17 10.0 10.0
1578 138.1 0 "IEA-10.0-198-RWT2.fst" 1478 18.1 5.0 10.17 10.0 10.0
--- WAKE DYNAMICS ---
1 Mod_Wake - Switch between wake formulations {1:Polar, 2:Curl, 3:Cartesian} (-) (switch)
198 RotorDiamRef - Reference turbine rotor diameter for wake calculations (m) [>0.0]
2 dr - Radial increment of radial finite-difference grid (m) [>0.0]
125 NumRadii - Number of radii in the radial finite-difference grid (-) [>=2]
156 NumPlanes - Number of wake planes (-) [>=2]
0.17 f_c - Cutoff (corner) frequency of the low-pass time-filter for the wake advection, deflection, and meandering model [recommended=1.28*U0/R] (Hz) [>0.0] or DEFAULT [DEFAULT=12.5/R, R estimated from dr and NumRadii, not recommended]
DEFAULT C_HWkDfl_O - Calibrated parameter in the correction for wake deflection defining the horizontal offset at the rotor (m ) or DEFAULT [DEFAULT= 0.0 ]
DEFAULT C_HWkDfl_OY - Calibrated parameter in the correction for wake deflection defining the horizontal offset at the rotor scaled with yaw error (m/deg) or DEFAULT [DEFAULT= 0.0 if Mod_Wake is 2, 0.3 otherwise]
DEFAULT C_HWkDfl_x - Calibrated parameter in the correction for wake deflection defining the horizontal offset scaled with downstream distance (- ) or DEFAULT [DEFAULT= 0.0 ]
DEFAULT C_HWkDfl_xY - Calibrated parameter in the correction for wake deflection defining the horizontal offset scaled with downstream distance and yaw error (1/deg) or DEFAULT [DEFAULT= 0.0 if Mod_Wake is 2, -0.004 otherwise]
1.8 C_NearWake - Calibrated parameter for the near-wake correction (-) [>1.0 and <2.5] or DEFAULT [DEFAULT=1.8]
DEFAULT k_vAmb - Calibrated parameters for the influence of the ambient turbulence in the eddy viscosity (set of 5 parameters: k, FMin, DMin, DMax, Exp) (-) [>=0.0, >=0.0 and <=1.0, >=0.0, >DMin, >=0.0] or DEFAULT [DEFAULT=0.05, 1.0, 0.0, 1.0, 0.01]
DEFAULT k_vShr - Calibrated parameters for the influence of the shear layer in the eddy viscosity (set of 5 parameters: k, FMin, DMin, DMax, Exp) (-) [>=0.0, >=0.0 and <=1.0, >=0.0, >DMin, >=0.0] or DEFAULT [DEFAULT=0.016, 0.2, 3.0, 25.0, 0.1]
DEFAULT Mod_WakeDiam - Wake diameter calculation model (-) (switch) {1: rotor diameter, 2: velocity based, 3: mass-flux based, 4: momentum-flux based} or DEFAULT [DEFAULT=1]
DEFAULT C_WakeDiam - Calibrated parameter for wake diameter calculation (-) [>0.0 and <0.99] or DEFAULT [DEFAULT=0.95] [unused for Mod_WakeDiam=1]
DEFAULT Mod_Meander - Spatial filter model for wake meandering (-) (switch) {1: uniform, 2: truncated jinc, 3: windowed jinc} or DEFAULT [DEFAULT=3]
DEFAULT C_Meander - Calibrated parameter for wake meandering (-) [>=1.0] or DEFAULT [DEFAULT=1.9]
--- CURLED-WAKE PARAMETERS [only used if Mod_Wake=2 or 3] ---
DEFAULT Swirl - Switch to include swirl velocities in wake (-) (switch) [DEFAULT=TRUE]
DEFAULT k_VortexDecay - Vortex decay constant for curl (-) [DEFAULT=0.0001]
DEFAULT NumVortices - The number of vortices in the curled wake model (-) [DEFAULT=100]
DEFAULT sigma_D - The width of the vortices in the curled wake model non-dimesionalized by rotor diameter (-) [DEFAULT=0.2]
DEFAULT FilterInit - Switch to filter the initial wake plane deficit and select the number of grid points for the filter {0: no filter, 1: filter of size 1} or DEFAULT [DEFAULT=1] [unused for Mod_Wake=1] (switch)
DEFAULT k_vCurl - Calibrated parameter for scaling the eddy viscosity in the curled-wake model (-) [>=0] or DEFAULT [DEFAULT=2.0 ]
DEFAULT Mod_Projection - Switch to select how the wake plane velocity is projected in AWAE {1: keep all components, 2: project against plane normal} or DEFAULT [DEFAULT=1: if Mod_Wake is 1 or 3, or DEFAULT=2: if Mod_Wake is 2] (switch)
--- WAKE-ADDED TURBULENCE ---
2 WAT - Switch between wake-added turbulence box options {0: no wake added turbulence, 1: predefined turbulence box, 2: user defined turbulence box} (switch)
"C:\\Users\\raque\\.spyder-py3\\ex_t\\FFarm_template\\FFDB_D100_512x512x64.u" WAT_BoxFile - Filepath to the file containing the u-component of the turbulence box (either predefined or user-defined) (quoted string)
512, 512, 64 WAT_NxNyNz - Number of points in the x, y, and z directions of the WAT_BoxFile [used only if WAT=2, derived value if WAT=1] (-)
5.0, 5.0, 5.0 WAT_DxDyDz - Distance (in meters) between points in the x, y, and z directions of the WAT_BoxFile [used only if WAT=2, derived value if WAT=1] (m)
default WAT_ScaleBox - Flag to scale the input turbulence box to zero mean and unit standard deviation at every node [DEFAULT=False] (flag)
default WAT_k_Def - Calibrated parameters for the influence of the maximum wake deficit on wake-added turbulence (set of 5 parameters: k_Def, FMin, DMin, DMax, Exp) (-) [>=0.0, >=0.0 and <=1.0, >=0.0, >DMin, >=0.0] or DEFAULT [DEFAULT=[0.6, 0.0, 0.0, 2.0, 1.0 ]]
default WAT_k_Grad - Calibrated parameters for the influence of the radial velocity gradient of the wake deficit on wake-added turbulence (set of 5 parameters: k_Grad, FMin, DMin, DMax, Exp) (-) [>=0.0, >=0.0 and <=1.0, >=0.0, >DMin, >=0.0] or DEFAULT [DEFAULT=[3.0, 0.0, 0.0, 12.0, 0.65]
False WrDisWind - Write low- and high-resolution disturbed wind data to <RootName>.Low.Dis.t<n>.vtk etc.? (flag)
0 NOutDisWindXY - Number of XY planes for output of disturbed wind data across the low-resolution domain to <RootName>.Low.DisXY<n_out>.t<n>.vtk (-) [0 to 99]
90.0 OutDisWindZ - Z coordinates of XY planes for output of disturbed wind data across the low-resolution domain (m) [1 to NOutDisWindXY] [unused for NOutDisWindXY=0]
0 NOutDisWindYZ - Number of YZ planes for output of disturbed wind data across the low-resolution domain to <RootName>/Low.DisYZ<n_out>.t<n>.vtk (-) [0 to 999]
63.,441. OutDisWindX - X coordinates of YZ planes for output of disturbed wind data across the low-resolution domain (m) [1 to NOutDisWindYZ] [unused for NOutDisWindYZ=0]
0 NOutDisWindXZ - Number of XZ planes for output of disturbed wind data across the low-resolution domain to <RootName>/Low.DisXZ<n_out>.t<n>.vtk (-) [0 to 999]
0.0 OutDisWindY - Y coordinates of XZ planes for output of disturbed wind data across the low-resolution domain (m) [1 to NOutDisWindXZ] [unused for NOutDisWindXZ=0]
3.0 WrDisDT - Time step for disturbed wind visualization output (s) [>0.0] or DEFAULT [DEFAULT=DT_Low or DT_Low-VTK] [unused for WrDisWind=False and NOutDisWindXY=NOutDisWindYZ=NOutDisWindXZ=0]
--- OUTPUT ---
False SumPrint - Print summary data to <RootName>.sum? (flag)
99999.9 ChkptTime - Amount of time between creating checkpoint files for potential restart (s) [>0.0]
0.0 TStart - Time to begin tabular output (s) [>=0.0]
1 OutFileFmt - Format for tabular (time-marching) output file (switch) {1: text file [<RootName>.out], 2: binary file [<RootName>.outb], 3: both}
True TabDelim - Use tab delimiters in text tabular output file? (flag) {uses spaces if False}
DEFAULT OutAllPlanes - Output all wake planes at all time steps. [DEFAULT=False]
7 NOutRadii - Number of radial nodes for wake output for an individual rotor (-) [0 to 20]
0, 2, 5, 11, 17, 21, 39 OutRadii - List of radial nodes for wake output for an individual rotor (-) [1 to NOutRadii] [unused for NOutRadii=0]
1 NOutDist - Number of downstream distances for wake output for an individual rotor (-) [0 to 9 ]
63.0 OutDist - List of downstream distances for wake output for an individual rotor (m) [1 to NOutDist ] [unused for NOutDist =0]
0 NWindVel - Number of points for wind output (-) [0 to 9]
0.0 WindVelX - List of coordinates in the X direction for wind output (m) [1 to NWindVel] [unused for NWindVel=0]
0.0 WindVelY - List of coordinates in the Y direction for wind output (m) [1 to NWindVel] [unused for NWindVel=0]
90.0 WindVelZ - List of coordinates in the Z direction for wind output (m) [1 to NWindVel] [unused for NWindVel=0]
OutList - The next line(s) contains a list of output parameters. See OutListParameters.xlsx for a listing of available output channels (quoted string)
"RtVAmbT1"
"RtVAmbT2"
"RtVRelT2"
"YawErrT1"
"YawErrT2"
"CtT1N02 , CtT1N03 , CtT1N04 , CtT1N05 , CtT1N06"
WkAxsXT2D1"
WkAxsYT2D1"
WkAxsZT2D1"
WkPosXT2D1"
WkPosYT2D1"
WkPosZT2D1"
"WkDfVxT1N01D1, WkDfVxT1N02D1, WkDfVxT1N03D1, WkDfVxT1N04D1, WkDfVxT1N05D1, WkDfVxT1N06D1, WkDfVxT1N07D1"
"WkDfVrT1N01D1, WkDfVrT1N02D1, WkDfVrT1N03D1, WkDfVrT1N04D1, WkDfVrT1N05D1, WkDfVrT1N06D1, WkDfVrT1N07D1"
"WkDfVxT2N01D1, WkDfVxT2N02D1, WkDfVxT2N03D1, WkDfVxT2N04D1, WkDfVxT2N05D1, WkDfVxT2N06D1, WkDfVxT2N07D1"
"WkDfVrT2N01D1, WkDfVrT2N02D1, WkDfVrT2N03D1, WkDfVrT2N04D1, WkDfVrT2N05D1, WkDfVrT2N06D1, WkDfVrT2N07D1"
I’ve put here only one ServoDyn and one OpenFAST since they are the same for the second wind turbine.
I’m simulating for more than 10 minutes so that I can cut off the transient and only averaging after that. For both power and fatigue the average is over time and seeds. The plot of tower fatigue in my first post refers to the maximum fatigue damage at the tower base due to fore-aft and side-to-side bending moments .
If you need any more information please let me know.
