Hi Jason/NREL,
I have a quick question regarding out-of-plane tip displacements in OpenFAST.
Consider a blade with initial precone and no wind load. The turbine is then subjected to an extreme wind load with the rotor parked giving a significant deflection of the blade. In terms of OpenFAST/ElastoDyn output, is the out-of-plane tip displacement (perpendicular to rotor / parallel to wind) measured from the initial position (option B) or from the rotor plane (option A). See sketch below (please forgive my poor drawing ability!).
I imagine the answer is A but I just wanted to confirm with you.
A related question. If the deflection was smaller (e.g. 50% of that shown in sketch), would the out-of-plane tip displacement assume a negative value?
Aengus.
Dear @Aengus.Connolly,
In ElastoDyn, the undeflected blade is straight and aligned with the pitch axis and the out-of-plane blade deflection is measured relative from the pitch axis and can be both positive and negative. (Your illustration appears to show some upwind precurve/prebend, which is not possible in ElastoDyn, although other OpenFAST modules such as AeroDyn and BeamDyn support precurve/prebend).
Hi Jason @Jason.Jonkman,
Thank you for the clarification regarding the tip displacement output, this makes sense now.
At the risk of complicating matters further, if ElastoDyn does not support initial precone/prebend condition, does this not introduce some inconsistency between the structural (ElastoDyn) and aerodynamic (AeroDyn) model? Consider for example, a very low wind speed which does not introduce much blade deflection. Aerodynamic forces and moments will be computed on the basis of the precone/prebend shape of the blade, but these forces will be applied in a structural model whose initial/undisturbed position involves a straight line blade i.e. the positions of the blade nodes/stations, and orientation of blade elements, are different in both modules.
Note that this follow-up question is not urgent from my perspective, I am just curious. I have one or two other questions also but I will raise these in separate threads for clarity.
Aengus.
To clarify, ElastoDyn does consider blade precone, but it does not consider blade curvature such as prebend or precurve outboard of the pitch axis. If you want to model blades with built-in curvature, switching from modeling the blade structural dynamics in ElastoDyn to BeamDyn is preferred. BeamDyn can consider built-in blade curvature, as well as AeroDyn.
