Hi All,
I am modeling the IEA-10MW turbine on a floating platform. I have modified the tower and run an analysis in BModes to fit out the mode shapes and frequencies. I am confident that the mode shapes are correct.
When I simulate the model in OpenFAST, I get suspicious tower response. I ran a simulation wherein:
- Rotor speed and blade pitch were held constant (no control, Gen DOF = False)
- Steady wind @ 13.5 m/s
- All structural DOFs enabled
Taking an FFT of the Q_TFA1 result shows this:
This was after further stiffening the tower, thinking that the tower resonance I was seeing was my first modification attempt still being too close to the 3P operating frequency. Additionally, the actual tower deflection is VERY small:
This makes me think that OpenFAST is overestimating the stiffness of the tower. I checked the rotor thrust output and it is ~1200kN, and doing a quick manual calculation the static tower deflection should be about 0.14m, which I did in Matlab like this:
M = 1200000 * (newHt - tower.Elevation);
Curvature = M./tower.TwFAStif;
Theta = cumtrapz(tower.Elevation,Curvature);
Deflection = cumtrapz(tower.Elevation,Theta)
My ElastoDyn tower looks like this:
------- ELASTODYN V1.00.* TOWER INPUT FILE -------------------------------------
Generated with MATLAB tower properties driver
---------------------- TOWER PARAMETERS ----------------------------------------
11 NTwInpSt - Number of input stations to specify tower geometry
1.0 TwrFADmp(1) - Tower 1st fore-aft mode structural damping ratio (%)
1.0 TwrFADmp(2) - Tower 2nd fore-aft mode structural damping ratio (%)
1.0 TwrSSDmp(1) - Tower 1st side-to-side mode structural damping ratio (%)
1.0 TwrSSDmp(2) - Tower 2nd side-to-side mode structural damping ratio (%)
---------------------- TOWER ADJUSTMENT FACTORS ------------------------------
1.0 FAStTunr(1) - Tower fore-aft modal stiffness tuner, 1st mode (-)
1.0 FAStTunr(2) - Tower fore-aft modal stiffness tuner, 2nd mode (-)
1.0 SSStTunr(1) - Tower side-to-side stiffness tuner, 1st mode (-)
1.0 SSStTunr(2) - Tower side-to-side stiffness tuner, 2nd mode (-)
1.0 AdjTwMa - Factor to adjust tower mass density (-)
1.0 AdjFASt - Factor to adjust tower fore-aft stiffness (-)
1.0 AdjSSSt - Factor to adjust tower side-to-side stiffness (-)
---------------------- DISTRIBUTED TOWER PROPERTIES ----------------------------
HtFract TMassDen TwFAStif TwSSStif
(-) (kg/m) (Nm^2) (Nm^2)
0.000000000000000e+00 1.917165418002903e+04 5.543311365245792e+12 5.543311365245792e+12
9.949824860361640e-02 1.824232866916633e+04 4.775666711761255e+12 4.775666711761255e+12
1.989018271324434e-01 1.610411113499036e+04 3.810408420103280e+12 3.810408420103280e+12
2.984000757360599e-01 1.411100012842773e+04 3.008551066454783e+12 3.008551066454783e+12
3.978036542648869e-01 1.338304444997033e+04 2.566561082972286e+12 2.566561082972286e+12
4.973019028685033e-01 1.160650772637432e+04 1.992355932286332e+12 1.992355932286332e+12
5.967054813973303e-01 9.964050224125884e+03 1.525293366530144e+12 1.525293366530144e+12
6.962037300009468e-01 8.451518159698828e+03 1.149112790713548e+12 1.149112790713548e+12
7.956073085297738e-01 6.186913747460687e+03 7.451822089485516e+11 7.451822089485516e+11
8.951055571333901e-01 4.975599365823232e+03 5.275547630880361e+11 5.275547630880361e+11
1.000000000000000e+00 4.643445033141643e+03 4.287993905217201e+11 4.287993905217201e+11
---------------------- TOWER FORE-AFT MODE SHAPES ------------------------------
0.5219 TwFAM1Sh(2) - Mode 1, coefficient of x^2 term
1.3105 TwFAM1Sh(3) - , coefficient of x^3 term
-2.1424 TwFAM1Sh(4) - , coefficient of x^4 term
2.0489 TwFAM1Sh(5) - , coefficient of x^5 term
-0.7389 TwFAM1Sh(6) - , coefficient of x^6 term
6.1138 TwFAM2Sh(2) - Mode 2, coefficient of x^2 term
8.3540 TwFAM2Sh(3) - , coefficient of x^3 term
-23.0055 TwFAM2Sh(4) - , coefficient of x^4 term
19.2777 TwFAM2Sh(5) - , coefficient of x^5 term
-9.7400 TwFAM2Sh(6) - , coefficient of x^6 term
---------------------- TOWER SIDE-TO-SIDE MODE SHAPES --------------------------
0.5130 TwSSM1Sh(2) - Mode 1, coefficient of x^2 term
1.2832 TwSSM1Sh(3) - , coefficient of x^3 term
-2.0713 TwSSM1Sh(4) - , coefficient of x^4 term
1.9734 TwSSM1Sh(5) - , coefficient of x^5 term
-0.6983 TwSSM1Sh(6) - , coefficient of x^6 term
3.8012 TwSSM2Sh(2) - Mode 2, coefficient of x^2 term
5.9813 TwSSM2Sh(3) - , coefficient of x^3 term
-15.7293 TwSSM2Sh(4) - , coefficient of x^4 term
14.2215 TwSSM2Sh(5) - , coefficient of x^5 term
-7.2747 TwSSM2Sh(6) - , coefficient of x^6 term
The stiffness values are comparable to the IEA-15MW system, and in comparing the input files everything appears in order. I’m not sure where else to look to debug this.
