Hello everyone,
I am modelling a monopile-based version of the IEA-15MW wind turbine using openfast. I have turned off all the foundation degrees of freedom and the structure is subjected to a range of turbulent wind scenarios with varying mean wind speed, wind shear and turbulence intensity. I have attached the plots for tower-top fore-aft deflection (TwrTpTDxi) and fft of the response. I expected the tower fore-aft deformations to be significantly damped and have a much smoother response, however, the obtained response seems to have significant oscillations at high frequencies.
Is this behaviour expected or could there be some mistake in my simulation setup?
Shubham
