When I run the M-file for open-loop I encounter this error by Matlab:
Error reported by S-function ‘FAST_SFunc’ in ‘OpenLoop/FAST Nonlinear Wind Turbine/S-Function’:
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:InflowWind_CalcOutput:CalcOutput:IfW_TSFFWind_CalcOutput
[position=(-8.2999, -15.666, 52.964) in wind-file coordinates]: Error: FF wind array was exhausted at 65.369 seconds (trying to
access data at 72.102 seconds).
Whereas previously I wasn’t faced such an error! I don’t know what file or parameter I have changed that it gives me such an error! Could you help me to solve this problem?
Sina
Dear Sina,
An error regarding the “FF wind array was exhausted” has been discussed many times on this forum e.g.: Error: FF wind array was exhausted - #6 by Jason.Jonkman.
Dear Dr. Jonkman,
Thanks for replying and introducing the helpful forum. The underlying reason that I didn’t get such an error is that I made a uniform wind input (without using Turbsim), which is why I could extend the time of the program. Now my question is that since it doesn’t give me any error with my own input wind, if I extend the run time and use my uniform wind and run the open loop, does it affect the open loop behavior in comparison with the default Fast wind input? I asked this question because I save the open loop data (say 400s) forever to run the closed-loop system easily.
Sina
Dear Sina,
I’m not sure I fully understand your question, but FAST supports both uniform wind input and turbulent wind generated by a preprocessor. Each type of wind data has its own uses.
Dear Dr. Jonkman,
Thanks for your prompt response. My question was about the dynamic of the wind turbine that I don’t know whether it is changed by the type of the wind signal or not in the first run (open loop).
Sina
Dear Sina,
I’m still not really sure I understand your question. What are you trying to simulate?
