Offshore Wind Turbine Simulation with AMR-Wind
Are there any test cases available that simulate a floating (or fixed-bottom) wind turbine, including wave interactions, using the AMR-Wind simulation environment coupled with OpenFAST?
Hamid
Hi Hamid,
There are a few ways to run cases.
You can look at this GUI to help you setup a case.
Also, this tutorial could provide some guidelines.
You can setup the platform motions using openfast.
Best,
Tony
