Hello!
I’m currently working on an animation visualizing basic movements (DOFs and tower deflection) in offshore turbines. I’m modeling a 5MW spar turbine in FAST using the information provided in “Dynamics Modeling and Loads Analysis of an Offshore Floating Wind Turbine” by J.M. Jonkman as well as FAST’s user manual and have visualized the turbine structure itself in paraview, but I can’t figure out how to generate files that demonstrate DOFs and tower motion, or how to visualize them.
In the Elastodyn file I run, will the platform have to be initially displaced in order to result in platform movement? (All my desired DOFs are enabled).
I’m fairly new to FAST and any pointers or tips would be appreciated!
Thanks!
Dear Sunny,
The visualization functionality of FAST is well documented in the FAST v8 ReadMe file: wind.nrel.gov/nwtc/docs/README_FAST8.pdf. You should be able to watch an animation within ParaView if WrVTK is set to 2.
Thank you so much for your time!
I followed the ReadMe to correct some of my input file, but am now running into this error:
FAST_InitializeAll:AD_Init:ReadInputFiles:ReadPrimaryFile:Invalid logical input for file
“.\5MW_Baseline/NRELOffshrBsline5MW_Onshore_AeroDyn15.dat” occurred while trying to read
CavitCheck.
a FAST encountered an error during module initialization.
I am confused by this error report because I have run the Aerodyn input file without problems before, would you be able to clarify the meaning of “invalid logical input” ?
Thank you again for your help and reply!
Sunny Li
Pasted below is my aerodyn file input for clarification
------- AERODYN v15.03.* INPUT FILE ------------------------------------------------
“default” DTAero - Time interval for aerodynamic calculations {or “default”} (s)
1 WakeMod - Type of wake/induction model (switch) {0=none, 1=BEMT}
2 AFAeroMod - Type of blade airfoil aerodynamics model (switch) {1=steady model, 2=Beddoes-Leishman unsteady model}
1 TwrPotent - Type tower influence on wind based on potential flow around the tower (switch) {0=none, 1=baseline potential flow, 2=potential
flow with Bak correction}
False TwrShadow – Calculate tower influence on wind based on downstream tower shadow? (flag)
True TwrAero - Calculate tower aerodynamic loads? (flag)
2 SkewMod - Type of skewed-wake correction model (switch) {1=uncoupled, 2=Pitt/Peters, 3=coupled} [used only when WakeMod=1]
True TanInd - Include tangential induction in BEMT calculations? (flag) [used only when WakeMod=1]
False AIDrag - Include the drag term in the axial-induction calculation? (flag) [used only when WakeMod=1]
False TIDrag - Include the drag term in the tangential-induction calculation? (flag) [used only when WakeMod=1 and TanInd=TRUE]
“Default” IndToler - Convergence tolerance for BEMT nonlinear solve residual equation {or “default”} (-) [used only when WakeMod=1]
100 MaxIter - Maximum number of iteration steps (-) [used only when WakeMod=1]
3 UAMod - Unsteady Aero Model Switch (switch) {1=Baseline model (Original), 2=Gonzalez’s variant (changes in Cn,Cc,Cm),
3=Minemma/Pierce variant (changes in Cc and Cm)} [used only when AFAeroMod=2]
True FLookup - Flag to indicate whether a lookup for f’ will be calculated (TRUE) or whether best-fit exponential equations will be used (FALSE); if
FALSE S1-S4 must be provided in airfoil input files (flag) [used only when AFAeroMod=2]
“Airfoils/Cylinder1.dat” AFNames - Airfoil file names (NumAFfiles lines) (quoted strings)
“Airfoils/Cylinder2.dat”
“Airfoils/DU40_A17.dat”
“Airfoils/DU35_A17.dat”
“Airfoils/DU30_A17.dat”
“Airfoils/DU25_A17.dat”
“Airfoils/DU21_A17.dat”
“Airfoils/NACA64_A17.dat”
“NRELOffshrBsline5MW_AeroDyn_blade.dat” ADBlFile(1) - Name of file containing distributed aerodynamic properties for Blade #1 (-)
“NRELOffshrBsline5MW_AeroDyn_blade.dat” ADBlFile(2) - Name of file containing distributed aerodynamic properties for Blade #2 (-) [unused if
NumBl < 2]
“NRELOffshrBsline5MW_AeroDyn_blade.dat” ADBlFile(3) - Name of file containing distributed aerodynamic properties for Blade #3 (-) [unused if
NumBl < 3]
====== Tower Influence and Aerodynamics ============================================================= [used only when TwrPotent/=0,
TwrShadow=True, or TwrAero=True]
12 NumTwrNds - Number of tower nodes used in the analysis (-) [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
TwrElev TwrDiam TwrCd
(m) (m) (-)
0.0000000E+00 6.0000000E+00 1.0000000E+00
8.5261000E+00 5.7870000E+00 1.0000000E+00
1.7053000E+01 5.5740000E+00 1.0000000E+00
2.5579000E+01 5.3610000E+00 1.0000000E+00
3.4105000E+01 5.1480000E+00 1.0000000E+00
4.2633000E+01 4.9350000E+00 1.0000000E+00
5.1158000E+01 4.7220000E+00 1.0000000E+00
5.9685000E+01 4.5090000E+00 1.0000000E+00
6.8211000E+01 4.2960000E+00 1.0000000E+00
7.6738000E+01 4.0830000E+00 1.0000000E+00
8.5268000E+01 3.8700000E+00 1.0000000E+00
8.7600000E+01 3.8700000E+00 1.0000000E+00
True SumPrint - Generate a summary file listing input options and interpolated properties to “.AD.sum”? (flag)
0 NBlOuts - Number of blade node outputs [0 - 9] (-)
1, 9, 19 BlOutNd - Blade nodes whose values will be output (-)
1, 2, 6 TwOutNd - Tower nodes whose values will be output (-)
Dear Sunny,
AeroDyn input CavitCheck (plus a few other related inputs) were added in AeroDyn v15.04 and newer. My guess is you updated FAST (e.g. to OpenFAST v1.0.0 from FAST v8.16) without updating your input file(s).
is there a new reference for the FAST8 ReadMe with paraview/viz information?
I cannot seem to be able to locate it any longer,
Thank you
Hi Rick,
The replacement for the NWTC Information Portal is being finalized. In the meantime, I’ve shared the FAST v8 ReadMe file on my Google drive: drive.google.com/file/d/17LDwMn … sp=sharing.
