Is it possible to run simulations with the NREL15MW new turbine without using any SubDyn data as it was onshore? I have been doing that with DTU10MW until now without any problems, but now I am having some issues with this new turbine.
The message that appears is the next one:
“FAST_Solution:FAST_AdvanceStates:SolveOption2c_Inp2AD_SrvD:InflowWind_CalcOutput:CalcOutput:IfW_TS
FFWind_CalcOutput [position=(-0.16947, 0.29429, -5.58670E-02) in wind-file coordinates]: FF wind
array boundaries violated. Grid too small in Z direction (height (Z=-5.58670E-02 m) is below the
grid and no tower points are defined)”
At the beginning the message was showing a positive value for Z coordinate, which has been solved updating my TurbSim archive, but now…I cannot understand why I need to have my grid defined under Z=0m if there is nothing there (apart that this makes nosense)
If I try to run the same case but adding the SubDyn.dat, I do not have any issues to run the simulation, which means that the substructure is necessary, but I do not get why.
Can be that without the substructure, the WTG suffers an abnormal deflection?
I would appreciate any kind of help, thank you in advanced,
Gonzalo Ahedo
