Dear Jason
I keep receiving the same error everytime I try to run FAST with InflowWind entry.
First, I tested with steady wind, it ran normally. Then I introduced the InflowWind input, when I started to get the following messages:
violated in SUBROUTINE SmllRotTrans() due to a large tower deflection (ElastoDyn SetCoordSy). The
be suppressed.
Additional debugging message from SUBROUTINE SmllRotTrans(): 0.3875 s
WARNING: High VT velocity encountered during induction factor calculation.
Blade number 1, Element number 1
VNW = 8.9453, VT = -560.63
Blade number 1, Element number 2
VNW = 10.169, VT = -557.62
Blade number 1, Element number 3
VNW = 10.322, VT = -554.83
Blade number 1, Element number 4
VNW = 10.305, VT = -551.68
Blade number 1, Element number 5
VNW = 10.293, VT = -548.55
WARNING: Induced velocity warning written 5 times. The message will not be repeated, though
the condition may persist.
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:AD14_CalcOutput:ELEMFRC:BeddoesModel:ATT
ACH: Blade #1 element #4 is supersonic! Other elements are likely supersonic as well. Supersonic
mach nos. will be set to 0.7 to attempt continuation.
AD14_CalcOutput:ELEMFRC:BeddoesModel:SEPAR: Angle of attack = 2.64230E+20 is outside table.
CalcOutputs_And_SolveForInputs:SolveOption1:ED_SD_HD_BD_Orca_InputOutputSolve:HydroDyn_CalcOutput:
Angles in GetSmllRotAngs() are larger than 0.4 radians.
ED_SD_HD_BD_Orca_InputOutputSolve:HydroDyn_CalcOutput: Angles in GetSmllRotAngs() are larger than
0.4 radians.
FAST encountered an error at simulation time 0.3875 of 299.99 seconds.
Aborting FAST.
I am using NREL 5MW Baseline Offshore Monopile OC3 inputs.
What did I missed?
Thanks!
