I’m performing 10-min simulation with NREL 5MW turbine based on 5MW_Land_DLL_WTurb.fst with NTM condition in the wind speed range of 3m/s-25m/s. When the simulation is performed in large wind speed (e.g. 25m/s), I got the following warnings:
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:AD_CalcOutput:RotCalcOutput:BEMT_CalcOut
put(node 5, blade 1):UA_CalcOutput:UA_BlendSteady:Temporarily turning off UA due to high angle of
attack or low relative velocity. This warning will not be repeated though the condition may
persist.
violated in SUBROUTINE SmllRotTrans() due to a large blade deflection (ElastoDyn SetCoordSy). The
be suppressed.
Additional debugging message from SUBROUTINE SmllRotTrans(): 3.7688 s
put(node 18, blade 2):UA_CalcOutput:Mach number exceeds 0.3. Theory is invalid. This warning will
not be repeated though the condition may persist.
The last two warning is mainly due to the start-up transient and does not repeat in the following time steps. However, for the first warning, the angle of attack at node 5, blade 1 is always high as in the following figure.
My question is:
(1) Are the 2nd and 3rd warning is indeed due to startup transient as I guessed?
(2) Is such high angle of attack normal? Does it match the realistic situation that in high wind speeds the A.o.A is such high?
You will get the first warning regarding “temporarily turning off UA” if either the angle of attack approaches UACutOut (DEFUALT = +/-45 degrees) (the warning is triggered 5-deg before the cut-out) or the relative inflow velocity approaches 0 m/s (the warning is triggered at 1 m/s).
You haven’t said what initial conditions you are using, but you can see if improving the initial conditions eliminates the 2nd and 3rd warnings. We typically recommend initializing the rotor speed and the blade-pitch angles to their expected (mean) values conditioned on the mean hub-height wind speed; are you doing that here? You can further improve the initial conditions by setting the initial blade and tower deflections to their expected (mean) values conditioned on the mean hub-height wind speed. Does that eliminate the 2nd and 3rd warnings?
I would expect large angles of attack at inboard stations and large variations in angle of attack at higher wind speeds (which likely have higher wind speed standard deviations than at lower mean wind speeds).
Regarding your 2nd comment, the current initial condition I’m using is as follows. I only changed RotSpeed to a roughly selected value as 8 rpm, so that tower strike at startup transients could be avoided in some degrees.
I’m trying to modify the initial condition as suggested, but I don’t think I fully understand your 2nd comment, so I will state what I’m doing in the following text to see if that is right:
The OopDef1, IPDefl, BlPitch(1)-(3) and RotSpeed should be modified to a value determined by the following prodecure:
(1) The mean hub-height wind speed is specified as 8.5 m/s according to an IEC wind turbine class of IIB, which is the situation I’m focusing on.
(2) Given this mean hub-height wind speed, some 10-min simulations could be performed and the mean value of OopDef1, IPDefl, BlPitch(1)-(3) and RotSpeed could be used for the initial condition.
Yes, that is correct. In general, we recommend to set the initial rotor speed and initial blade-pitch angles to their expected (mean) values conditioned on the mean hub-height wind speed. Setting initial blade-tip or tower-top displacments could further reduce the initial transients. At 8.5 m/s for the NREL 5-MW baseline wind turbine, I would expect these to be around 9.6 rpm and 0 degree for RotSpeed and BlPitch.
However, when I am performing multiple simulations at 25m/s wind speed with randomly selected random seeds in TurbSim, about 20% of the simulation are aborted due to the two following reasons:
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:AD_CalcOutput:RotCalcOutput:BEMT_CalcOutput(node 18, blade 2): UA_CalcOutput:Mach number exceeds 1.0. Equations cannot be evaluated.
For the first case, the tower clearance reaches around 3m as shown in the following figure, which triggers the tower strike I guess. I also notice the abnormal behavior of blade pitch as shown below.
I have no idea how I can further modify the model to avoid such situation.
Another situation is that, even though OpenFAST terminated normally, the load might be too little. For example, when I ran this model at 19m/s wind speed, the blade root flapwise bending moment may look like this:
The maximum of blade root flapwise bending is only 3000 kNm, which is much lower compared with existing studies. Is it because the turbine is not in the normal working condition?
Again, the initial conditions should depend on the mean hub-height wind speed being simulated. I suspect your controller is not responding properly because of poor initial conditions. At 25 m/s for the NREL 5-MW baseline wind turbine, I would expect these to be around 12.1 rpm and 23.5 degree for RotSpeed and BlPitch.
I understand. I misunderstood the “mean hub-height wind speed” as the expected value of long-term wind speed where the turbine is working. The initial conditions are dependent on the 10-min average wind speed, which in my case should be the “URef” in TurbSim .inp file. I will try it later.
Dear Jason, I’m studying the IEA Wind 15-Megawatt VolturnUS-S and I want to simulate different wind velocities. I changed the initial blade pitch and the Initial rotor speed in Elastodyn but i got the following warnings
1)Temporarily turning off UA due to high angle of attack or low relative velocity. This warning will not be repeated though the condition may persist
2)Mach number exceeds 0.3.
My airfoil aerodynamics model is the Beddoes-Leishman.
Regarding the warning about “temporarily turning off UA”, this warning has been discussed in other several other forum topics and often happens at inboard stations
In fact it only fails when Turbsim|InflowFile|HFlowAng = 300, and can run normally in all other directions. I tried some methods to make it restrain itself(set a smaller time step size, set NumCrctn = 1), but all failed, could you tell me how should I do?
looking forward your reply!
Well, it looks like your modeling an idling turbine that goes unstable. At certain yaw errors in the idling condition, a known blade-edgewise instability exists, e.g., as discussed in the following forum topic: Designing for yaw errors using FAST. In the absence of more information, I would guess this is the issue you are running into.
FYI: You can set the fixed wind direction in either TurbSim (HFlowAng) or the InflowWind module of OpenFAST (PropagationDir), but the latter is preferred because the wind will propagate along the wind direction specified in InflowWind (PropagationDir) regardless of the setting of HFlowAng in TurbSim.
Thanks for your reply, The link you provided is very useful. If you could answer me another question I would appreciate it.
The first picture is the relationship between the bottom bending moment of the tower and the wind direction yaw that I drew. The wind300wave-90 will crash under the shutdown condition as described in your link.
Moreover, I think the tower bottom bending moment near the lateral direction of the wind300wave-90 shutdown condition is also inaccurate. Obvious data instability can be observed in both their tower bottom lateral displacement and bending moment.
I think, theoretically, the working condition with the maximum bending moment at the bottom of the tower should be at 90deg, as shown in the following figure. Do you agree?Or rather, which shutdown condition do you think corresponds to the maximum bending moment at the bottom of the tower?
In the absence of any aero-elastic instabilities, I would think the maximum tower-base moment of an idling rotor with fully feathered blades would occur when the blade is positioned flatwise normal to the wind, i.e. at 90 degrees yaw misalignment. But if an aero-elastic instability occurs at a different misalignment angle, this curve may change.
I’m also not sure which “bottom bending moment of the tower” you are plotting. I would not expect tower loads of a jacket support structure to be much effected by waves (the loads in the jacket would be, but not in the tower, above the wave action). I’m also not sure what the orientation of this moment is with respect to the wind direction.
Please excuse me for making a little deviation when elaborating the problem.
The first picture shows the maximum coupling bending moment at the bottom of the tower (coupling in the x and y directions) that I have tallied.
In fact, the second picture shows the coupled bending moments in the x and y directions at the bottom of the tower base without considering waves and the lower foundation (only considering the influence of the upper aerodynamic load). And the data in the figure is from a 5MW wind power project. I just want to know if this trend is correct.
Based on the answers and links of the previous posts, I think I should first determine the wind direction corresponding to the maximum coupling moment at the bottom of the tower (the maximum when the yaw Angle is around 90deg). During this process, if the previous simulation error is encountered, I choose to ignore it and explain it, and then determine the direction of the wave under this wind direction situation. So determine the wind and wave conditions corresponding to the maximum coupling bending moment at the bottom of the tower. Do you agree?
