Hello!
The mentioned problem could be solved by the hints given in the follwing forum topic: [url]The effect of Tilt Angle]
→ The sensor “RotThrust” is not the aerodynamic thrust as it includes gravity and inertial loads.
As a result, I was able to calculate the coefficients for a wide range of pitch angle and TSR
Sebastian
