Our lab is planning to conduct a model test using the OC3-Hywind OFWT concept. I’ve noticed that for numerical calculation, FAST uses a simplified model adding a yaw stiffness instead of the original delta-line concept described in your report “Definition of the Floating System for Phase IV of OC3”.
So I would be very appreciated if you could help me find the original mooring system configurations and the original mooring line parameters.
Thank you very much.
When the OC3-Hywind specification document was originally published, I was able to obtain information from Statoil regarding the specifications of the delta connection and multisegment lines; however, at the time, Statoil requested that I not redistribute those details to the entire OC3 group. I’ve recently heard from others that they were able to obtain information regarding the delta when they contacted Statoil. I suggest you contact Finn Gunnar Nielsen of Statoil from which I obtained the original data.
