I am simulating a semisubmersible floating wind turbine for irregular wave+wind+current. There are three segments for the mooring lines. I simulated two cases: one segment mooring line and three segments mooring line, and found that mooring line tension, wind turbine thrust are comparable for the two cases, but there is a large difference for platform surge.
My concern is the coordinates of the line connections. How to specify these coordinates. At first when I randomly set the values, I got some warnings: “catenary solver failed for one or more lines, using linear node spacing”. After some adjustment, the warnings were eliminated. But still, the coordinates are based on assumptions.
I have following queries, any comments and suggestions will be greatly appreciated.
- Is there a method to locate the connection coordinates?
- How important is the accuracy of the connection location, can the mooring line be modelled by specifying the unstretched segment length instead of connection coordinates in MoorDyn?
- For the one line simulation, weighted average per length was used for mooring line properties, is it correct?
Results for one mooring line (average from 3600-7200 secs):
| FAIRTEN1 | FAIRTEN2 | FAIRTEN3 | ANCHTEN1 | ANCHTEN2 | ANCHTEN3 |
| (N) | (N) | (N) | (N) | (N) | (N) |
| 1.58E+06 | 4.07E+06 | 4.17E+06 | 8.13E+05 | 3.27E+06 | 3.37E+06 |
| PtfmSurge | PtfmSway | PtfmHeave | PtfmRoll | PtfmPitch | PtfmYaw |
| (m) | (m) | (m) | (deg) | (deg) | (deg) |
| 15.308 | 0.440 | -0.109 | 0.343 | 4.657 | 0.572 |
| RotTorq | RotThrust | ||||
| (kN-m) | (kN) | ||||
| 9685.297913 | 1727.854552 |
Results for three segments mooring line:
| FAIRTEN7 | FAIRTEN8 | FAIRTEN9 | ANCHTEN1 | ANCHTEN2 | ANCHTEN3 |
| 1.52E+06 | 4.19E+06 | 4.29E+06 | 8.89E+05 | 3.39E+06 | 3.49E+06 |
| 11.076 | 0.436 | -0.099 | 0.353 | 4.418 | 0.563 |
| 9695.272214 | 1723.659372 |
Xiaoqin
