Dear everyone,
I want to add a synthetic fiber to the floating wind turbine mooring system to replace the iron chain. I use Moordyn as the mooring module, but I have encountered a problem where my Moordyn always fails to initialize, as shown in the following picture
On a mooring line, I am divided into three sections. The first section closest to the platform is the iron chain, the second section is the synthetic fiber, and the third section is the iron chain. I can determine the length of these three sections, but I cannot determine the specific node positions. After several failed experiences, I believe that the failure of catenary linearization was caused by incorrect coordinate settings at POINT. Do you have any good methods to determine the coordinate positions that can help me simulate my idea smoothly?
--------------------- MoorDyn Input File ------------------------------------
MoorDyn v2 sample input file
---------------------- LINE TYPES -----------------------------------
TypeName Diam Mass/m EA BA/-zeta EI Cd Ca CdAx CaAx
(name) (m) (kg/m) (N) (N-s/-) (N-m^2) (-) (-) (-) (-)
Chain 0.333 685.0 3.27E9 -1 0 1.11 0.82 0.2 0.27 !chain
Polyester 0.205 45.10 3.97E8 -1 0 1.2 0.82 0.2 0.27 !polyester static
Polyester1 0.205 45.10 1.01E8|1.01E8 -1|-1 0 1.2 0.82 0.2 0.27 !polyester line1 viscoelastic
Polyester23 0.205 45.10 1.01E8|1.91E8 -1|-1 0 1.2 0.82 0.2 0.27 !polyester line2/3 viscoelastic
---------------------- POINTS ---------------------------------------
ID Attachment X Y Z Mass Volume CdA Ca
(#) (word/ID) (m) (m) (m) (kg) (m^3) (m^2) (-)
1 Vessel -58.000 0.000 -14.000 0 0 0 0
2 Free -71.522 0.000 -37.550 0 0 0 0
3 Free -81.632 0.000 -51.230 0 0 0 0
4 Fixed -837.600 0.000 -200.000 0 0 0 0
5 Vessel 29.000 50.229 -14.000 0 0 0 0
6 Free 37.146 62.761 -34.387 0 0 0 0
7 Free 42.170 71.488 -48.09 0 0 0 0
8 Fixed 418.800 725.383 -200.000 0 0 0 0
9 Vessel 29.000 -50.229 -14.000 0 0 0 0
10 Free 37.146 -62.761 -34.387 0 0 0 0
11 Free 42.170 -71.488 -48.09 0 0 0 0
12 Fixed 418.800 -725.383 -200.000 0 0 0 0
---------------------- LINES ----------------------------------------
ID LineType AttachA AttachB UnstrLen NumSegs LineOutputs
(#) (name) (ID) (ID) (m) (-) (-)
1 Chain 2 1 30.00 2 -
2 Polyester 3 2 20.00 10 ts
3 Chain 4 3 800.00 80 -
4 Chain 6 5 30.00 2 -
5 Polyester 7 6 20.00 10 t
6 Chain 8 7 800.00 80 -
7 Chain 10 9 30.00 2 -
8 Polyester 11 10 20.00 10 -
9 Chain 12 11 800.00 80 -
---------------------- OPTIONS -----------------------------------------
0.001 dtM time step to use in mooring integration (s)
3e6 kbot bottom stiffness (Pa/m)
3e5 cbot bottom damping (Pa-s/m)
0.01 dtIC time interval for analyzing convergence during IC gen (s)
60 TmaxIC max time for ic gen (s)
0.01 threshIC threshold for IC convergence (-)
0 MU_KT axial line friction coefficients
0 MU_KA transverse line friction coefficients
"wavedynamic.dat" WaterKin the wave elevations are provided in a grid (-)
---------------------- OUTPUTS -----------------------------------------
FAIRTEN1
FAIRTEN2
FAIRTEN3
ANCHTEN1
ANCHTEN2
ANCHTEN3
END
------------------------- need this line -------------------------------------
