Hi everyone,
I’m trying to model the flexibility of large floating platforms, such as the IEA 22MW, using SubDyn. I’m struggling a bit with the initial step: creating the members and joints.
I simplified the geometry by removing the “horizontal braces” and keeping only the main column, peripheral columns, and pontoons. I defined all the joints and members, but I’m getting an error related to unwanted rigid-body modes (see attached image). There are exactly 14 “[info] Negative values…” messages.
I tried adding elements that connect the pontoons to the bottom of the columns, which reduced the number of error messages (see image).
However, I don’t fully understand the physical meaning behind this, as there’s nothing physically connecting these two elements unless I add a “virtual” internal element inside the columns to create a link —like in the image where I created a member between nodes 10 and 3.
I also tried increasing the Nmodes value to see if it would help, but no luck.
---- STRUCTURE JOINTS: joints connect structure members (~Hydrodyn Input File)---
14 NJoints - Number of joints (-)
JointID JointXss JointYss JointZss JointType JointDirX JointDirY JointDirZ JointStiff ![Coordinates of Member joints in SS-Coordinate System][JointType={1:cantilever, 2:universal joint, 3:revolute joint, 4:spherical joint}]
(-) (m) (m) (m) (-) (-) (-) (-) (Nm/rad)
1 0.0 0.0 -25.0 1 0.0 0.0 0.0 0.0
2 0.0 0.0 15 1 0.0 0.0 0.0 0.0
3 -65.0 0.0 -25.0 1 0.0 0.0 0.0 0.0
4 -65.0 0.0 15.0 1 0.0 0.0 0.0 0.0
5 32.5 56.29165 -25.0 1 0.0 0.0 0.0 0.0
6 32.5 56.29165 15.0 1 0.0 0.0 0.0 0.0
7 32.5 -56.29165 -25.0 1 0.0 0.0 0.0 0.0
8 32.5 -56.29165 15.0 1 0.0 0.0 0.0 0.0
9 -6.0 0.0 -17.0 1 0.0 0.0 0.0 0.0
10 -58.75 0.0 -17.0 1 0.0 0.0 0.0 0.0
11 3.0 5.196152 -17.0 1 0.0 0.0 0.0 0.0
12 29.375 50.878992 -17.0 1 0.0 0.0 0.0 0.0
13 3.0 -5.196152 -17.0 1 0.0 0.0 0.0 0.0
14 29.375 -50.878992 -17.0 1 0.0 0.0 0.0 0.0
------------------- BASE REACTION JOINTS: 1/0 for Locked/Free DOF @ each Reaction Node ---------------------
0 NReact - Number of Joints with reaction forces; be sure to remove all rigid motion DOFs of the structure (else det([K])=[0])
RJointID RctTDXss RctTDYss RctTDZss RctRDXss RctRDYss RctRDZss SSIfile ! [Global Coordinate System]
(-) (flag) (flag) (flag) (flag) (flag) (flag) (string)
------- INTERFACE JOINTS: 1/0 for Locked (to the TP)/Free DOF @each Interface Joint (only Locked-to-TP implemented thus far (=rigid TP)) ---------
1 NInterf - Number of interface joints locked to the Transition Piece (TP): be sure to remove all rigid motion dofs
IJointID ItfTDXss ItfTDYss ItfTDZss ItfRDXss ItfRDYss ItfRDZss ! [Global Coordinate System]
2 1 1 1 1 1 1
----------------------------------- MEMBERS --------------------------------------
13 NMembers - Number of frame members
MemberID MJointID1 MJointID2 MPropSetID1 MPropSetID2 MType COSMID ![MType={1:beam circ., 2:cable, 3:rigid, 4:beam arb.}. COMSID={-1:none}]
1 1 2 4 4 1 -1 ! Main column
2 3 4 1 1 1 -1 ! Base Column 1
3 5 6 1 1 1 -1 ! Base Column 2
4 7 8 1 1 1 -1 ! Base Column 3
5 9 10 2 2 1 -1 ! Delta Pontoon, Lower 1
6 11 12 2 2 1 -1 ! Delta Pontoon, Lower 2
7 13 14 2 2 1 -1 ! Delta Pontoon, Lower 3
8 10 3 1 1 1 -1 ! T-junction Pontoon 1
9 12 8 1 1 1 -1 ! T-junction Pontoon 2
10 14 7 1 1 1 -1 ! T-junction Pontoon 3
11 9 1 1 1 1 -1
12 11 1 1 1 1 -1
13 13 1 1 1 1 -1
If any of you have encountered similar issues, I’d be very curious to know how you resolved them.
Best Regards
