Dear @Jason.Jonkman ,
I am simulating the free decay of an onshore wind turbine. And I model the tower in Subdyn. Only Elastodyn and Subdyn is enabled in .fst file. In Elasotdyn file, I turned off all tower DOF, and turned on all platform DOF:
True          FlapDOF1    - First flapwise blade mode DOF (flag)
True          FlapDOF2    - Second flapwise blade mode DOF (flag)
True          EdgeDOF     - First edgewise blade mode DOF (flag)
False         TeetDOF     - Rotor-teeter DOF (flag) [unused for 3 blades]
True          DrTrDOF     - Drivetrain rotational-flexibility DOF (flag)
True          GenDOF      - Generator DOF (flag)
False          YawDOF      - Yaw DOF (flag)
False          TwFADOF1    - First fore-aft tower bending-mode DOF (flag)
False          TwFADOF2    - Second fore-aft tower bending-mode DOF (flag)
False          TwSSDOF1    - First side-to-side tower bending-mode DOF (flag)
False          TwSSDOF2    - Second side-to-side tower bending-mode DOF (flag)
True          PtfmSgDOF   - Platform horizontal surge translation DOF (flag)
True          PtfmSwDOF   - Platform horizontal sway translation DOF (flag)
True          PtfmHvDOF   - Platform vertical heave translation DOF (flag)
True          PtfmRDOF    - Platform roll tilt rotation DOF (flag)
True          PtfmPDOF    - Platform pitch tilt rotation DOF (flag)
True          PtfmYDOF    - Platform yaw rotation DOF (flag)
To simulate the free decay, I want to apply intial displacement at tower top in x axis. So I applied an initial platform displacement of 1 meter in x axis with all other intial condition keeping 0:
          0   OoPDefl     - Initial out-of-plane blade-tip displacement (meters)
          0   IPDefl      - Initial in-plane blade-tip deflection (meters)
          0   BlPitch(1)  - Blade 1 initial pitch (degrees)
          0   BlPitch(2)  - Blade 2 initial pitch (degrees)
          0   BlPitch(3)  - Blade 3 initial pitch (degrees) [unused for 2 blades]
          0   TeetDefl    - Initial or fixed teeter angle (degrees) [unused for 3 blades]
          0   Azimuth     - Initial azimuth angle for blade 1 (degrees)
          0   RotSpeed    - Initial or fixed rotor speed (rpm)
          0   NacYaw      - Initial or fixed nacelle-yaw angle (degrees)
          0   TTDspFA     - Initial fore-aft tower-top displacement (meters)
          0   TTDspSS     - Initial side-to-side tower-top displacement (meters)
          1   PtfmSurge   - Initial or fixed horizontal surge translational displacement of platform (meters)
          0   PtfmSway    - Initial or fixed horizontal sway translational displacement of platform (meters)
          0   PtfmHeave   - Initial or fixed vertical heave translational displacement of platform (meters)
          0   PtfmRoll    - Initial or fixed roll tilt rotational displacement of platform (degrees)
          0   PtfmPitch   - Initial or fixed pitch tilt rotational displacement of platform (degrees)
          0   PtfmYaw     - Initial or fixed yaw rotational displacement of platform (degrees)
As the tower height is 87.6, and I need to keep tower zeroed in Elastodyn. So I only assigin 0.001 meter  to tower height, by changing TowerBsHt and PtfmRefzt to 87.599:
        87.6   TowerHt     - Height of tower above ground level [onshore] or MSL [offshore] (meters)
       87.599   TowerBsHt   - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
          0   PtfmCMxt    - Downwind distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
          0   PtfmCMyt    - Lateral distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
          0   PtfmCMzt    - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
       87.599   PtfmRefzt   - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform reference point (meters)
And platform has no mass and inertia:
          0   PtfmMass    - Platform mass (kg)
          0   PtfmRIner   - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
          0   PtfmPIner   - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
          0   PtfmYIner   - Platform inertia for yaw rotation about the platform CM (kg m^2)
In Subdyn file, I have located the interface point at (0, 0, 87.599).
But when I start simulation, it aborted with following warning:
Running ElastoDyn.
Running SubDyn.
   Fixed bottom case detected
   Performing Craig-Bampton reduction 66 DOFs -> 0 modes + 6 DOFs
   Using static improvement method for gravity and ext. loads
   Calculating Full System Modes for output files
   Exporting Summary file
 Time: 0 of 120 seconds.
FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption1:FullOpt1_InputOutputSolve:SD_CalcOutput:
Angles in GetSmllRotAngs() are larger than 0.4 radians.
SD_CalcOutput: Angles in GetSmllRotAngs() are larger than 0.4 radians.
FullOpt1_InputOutputSolve:SD_CalcOutput: Angles in GetSmllRotAngs() are larger than 0.4 radians.
Denominator is zero in GetSmllRotAngs().
 OpenFAST encountered an error at simulation time 0.49375 of 120 seconds.
 Aborting OpenFAST.
My OpenFAST version is v3.2.1.
Could you please give me some suggestion on this error?
For the damping in Subdyn, I am also confused. It has Damping Ratios for each retained mode and GuyanDampMod. Are there any posts explaining this point? As in my previous model, Elastodyn adopted 1% of critical damping for tower. I don’t know the equivalent configuration in Subdyn.
How about:
True             CBMod       - [T/F] If True perform C-B reduction, else full FEM dofs will be retained. If True, select Nmodes to retain in C-B reduced system.
             4   Nmodes      - Number of internal modes to retain (ignored if CBMod=False). If Nmodes=0 --> Guyan Reduction.
             1   JDampings   - Damping Ratios for each retained mode (% of critical) If Nmodes>0, list Nmodes structural damping ratios for each retained mode (% of critical), or a single damping ratio to be applied to all retained modes. (last entered value will be used for all remaining modes).
             0   GuyanDampMod - Guyan damping {0=none, 1=Rayleigh Damping, 2=user specified 6x6 matrix}
- Can Subdyn model tapered beam now? Actually I used different cross-section property at two joints connecting one element. But the Subdyn file said Tapered E-B (unavailable) and 2-node tapered Timoshenko (unavailable):
             1   FEMMod      - FEM switch: element model in the FEM. [1= Euler-Bernoulli(E-B);  2=Tapered E-B (unavailable);  3= 2-node Timoshenko;  4= 2-node tapered Timoshenko (unavailable)]
Ran Tu
