We are currently working on fatigue preliminary calculations for land-based wind turbines using MLife and DEL as a quantitative measurement. We have a few doubts that we would like to clarify if possible. Here are some of our questions:
1- Short-term DEL vs. lifetime DEL:
Based on the information we gathered from the “MLife Theory Manual” and this forum, it seems that short-term DEL is calculated based on a “single time-series,” while lifetime DEL is based on the “entire set of time-series data.” We are unsure about when it’s appropriate to use one or the other. For instance, should we obtain the short-term DEL of a specific channel if we want to analyze the DEL caused by a particular event (i.e., only one time-series with a wind gust included)?
2-Fatigue analysis simulations:
We are also seeking guidance on how to perform proper simulations for fatigue analysis. Is there any recommended reference for land-based wind turbines? We have been reading the report “Dynamics Modeling and Loads Analysis of an Offshore Floating Wind Turbine” by J.M. Jonkman, specifically chapter 5.
3- Weibull distribution in MLife:
Regarding the Weibull distribution used in MLife, are its default parameters taken from the input files? The “MLife Theory Manual” mentions that MLife models the wind with a Weibull distribution, but we are unsure if the default Weibull distribution parameters are taken from the time-series, since this wind distribution is place-dependent.
As you can see, probably some of these questions are trivial, but we want to know if we are in the correct path. This is what is planned for the preliminary fatigue analysis (in general, we have to select the channels, etc):
a) We intend to use OpenFast to generate six 10-minute simulations for each wind condition, ranging from 4 to 24 m/s, centered within bins of 2 m/s. This will result in a total of 66 simulations. Is it recommended/enough to use Turbsim for generating the wind profiles?
b) After generating the 66 .out files, we plan to use MLife for fatigue analysis.
We apologize if some of these questions seem trivial, but we want to ensure we are on the correct path for our analysis.
