Dear Jonkman,
I want to linearize NREL 5MW_ITIBarge_DLL_WTurb_WavesIrr as Mohamed in Fri Jun 26, 2020 7:57 pm. But I met some problems and the above discussion may not solve my problem. I enabled only two DOFs, GenDOF and PtfmPDOF. But when I run linearization, but it aborted.
Could you please help me?
The input file is shown below.
------- OpenFAST EXAMPLE INPUT FILE -------------------------------------------
FAST Certification Test #22: NREL 5.0 MW Baseline Wind Turbine with ITI Barge Configuration, for use in offshore analysis
True Echo - Echo input data to <RootName>.ech (flag)
"FATAL" AbortLevel - Error level when simulation should abort (string) {"WARNING", "SEVERE", "FATAL"}
600 TMax - Total run time (s)
0.0125 DT - Recommended module time step (s)
99999 DT_UJac - Time between calls to get Jacobians (s)
1E+06 UJacSclFact - Scaling factor used in Jacobians (-)
1 CompHydro - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
0 CompSub - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn; 2=External Platform MCKF}
1 CompMooring - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
"NRELOffshrBsline5MW_ITIBarge4_ElastoDyn.dat" EDFile - Name of file containing ElastoDyn input parameters (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(1) - Name of file containing BeamDyn input parameters for blade 1 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(2) - Name of file containing BeamDyn input parameters for blade 2 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(3) - Name of file containing BeamDyn input parameters for blade 3 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_InflowWind_Steady18mps.dat" InflowFile - Name of file containing inflow wind input parameters (quoted string)
"NRELOffshrBsline5MW_ITIBarge_AeroDyn15.dat" AeroFile - Name of file containing aerodynamic input parameters (quoted string)
"NRELOffshrBsline5MW_ITIBarge4_ServoDyn.dat" ServoFile - Name of file containing control and electrical-drive input parameters (quoted string)
"NRELOffshrBsline5MW_ITIBarge4_HydroDyn.dat" HydroFile - Name of file containing hydrodynamic input parameters (quoted string)
"unused" SubFile - Name of file containing sub-structural input parameters (quoted string)
"NRELOffshrBsline5MW_ITIBarge4_MAP.dat" MooringFile - Name of file containing mooring system input parameters (quoted string)
"unused" IceFile - Name of file containing ice input parameters (quoted string)
True SumPrint - Print summary data to "<RootName>.sum" (flag)
10 SttsTime - Amount of time between screen status messages (s)
1000 ChkptTime - Amount of time between creating checkpoint files for potential restart (s)
0.0125 DT_Out - Time step for tabular output (s) (or "default")
0 TStart - Time to begin tabular output (s)
0 OutFileFmt - Format for tabular (time-marching) output file (switch) {0: uncompressed binary [<RootName>.outb], 1: text file [<RootName>.out], 2: binary file [<RootName>.outb], 3: both 1 and 2}
True TabDelim - Use tab delimiters in text tabular output file? (flag) {uses spaces if false}
"ES15.7E2" OutFmt - Format used for text tabular output, excluding the time channel. Resulting field should be 10 characters. (quoted string)
true Linearize - Linearization analysis (flag)
true CalcSteady - Calculate a steady-state periodic operating point before linearization? [unused if Linearize=False] (flag)
3 TrimCase - Controller parameter to be trimmed {1:yaw; 2:torque; 3:pitch} [used only if CalcSteady=True] (-)
0.001 TrimTol - Tolerance for the rotational speed convergence [used only if CalcSteady=True] (-)
0.01 TrimGain - Proportional gain for the rotational speed error (>0) [used only if CalcSteady=True] (rad/(rad/s) for yaw or pitch; Nm/(rad/s) for torque)
0 Twr_Kdmp - Damping factor for the tower [used only if CalcSteady=True] (N/(m/s))
0 Bld_Kdmp - Damping factor for the blades [used only if CalcSteady=True] (N/(m/s))
2 NLinTimes - Number of times to linearize (-) [>=1] [unused if Linearize=False]
160, 360 LinTimes - List of times at which to linearize (s) [1 to NLinTimes] [used only when Linearize=True and CalcSteady=False]
1 LinInputs - Inputs included in linearization (switch) {0=none; 1=standard; 2=all module inputs (debug)} [unused if Linearize=False]
1 LinOutputs - Outputs included in linearization (switch) {0=none; 1=from OutList(s); 2=all module outputs (debug)} [unused if Linearize=False]
False LinOutJac - Include full Jacobians in linearization output (for debug) (flag) [unused if Linearize=False; used only if LinInputs=LinOutputs=2]
False LinOutMod - Write module-level linearization output files in addition to output for full system? (flag) [unused if Linearize=False]
0 WrVTK - VTK visualization data output: (switch) {0=none; 1=initialization data only; 2=animation; 3=mode shapes}
2 VTK_type - Type of VTK visualization data: (switch) {1=surfaces; 2=basic meshes (lines/points); 3=all meshes (debug)} [unused if WrVTK=0]
false VTK_fields - Write mesh fields to VTK data files? (flag) {true/false} [unused if WrVTK=0]
15 VTK_fps - Frame rate for VTK output (frames per second){will use closest integer multiple of DT} [used only if WrVTK=2 or WrVTK=3]
ElastDyn File
[code]------- ELASTODYN for OpenFAST INPUT FILE -------------------------------------------
“default” DT - Integration time step (s)
false FlapDOF1 - First flapwise blade mode DOF (flag)
false FlapDOF2 - Second flapwise blade mode DOF (flag)
false EdgeDOF - First edgewise blade mode DOF (flag)
false DrTrDOF - Drivetrain rotational-flexibility DOF (flag)
false YawDOF - Yaw DOF (flag)
false TwFADOF1 - First fore-aft tower bending-mode DOF (flag)
false TwFADOF2 - Second fore-aft tower bending-mode DOF (flag)
false TwSSDOF1 - First side-to-side tower bending-mode DOF (flag)
false TwSSDOF2 - Second side-to-side tower bending-mode DOF (flag)
false PtfmSgDOF - Platform horizontal surge translation DOF (flag)
false PtfmSwDOF - Platform horizontal sway translation DOF (flag)
false PtfmHvDOF - Platform vertical heave translation DOF (flag)
false PtfmRDOF - Platform roll tilt rotation DOF (flag)
false PtfmYDOF - Platform yaw rotation DOF (flag)
14 BlPitch(1) - Blade 1 initial pitch (degrees)
14 BlPitch(2) - Blade 2 initial pitch (degrees)
14 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
12.1 RotSpeed - Initial or fixed rotor speed (rpm)
63 TipRad - The distance from the rotor apex to the blade tip (meters)
-5.0191 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5 ShftTilt - Rotor shaft tilt angle (degrees)
0 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
-0.281768 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
-0 PtfmRefzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform reference point (meters)
56780 HubMass - Hub mass (kg)
2.60789E+06 NacYIner - Nacelle inertia about yaw axis (kg m^2)
0 YawBrMass - Yaw bearing mass (kg)
5.452E+06 PtfmMass - Platform mass (kg)
7.269E+08 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
7.269E+08 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
1.4539E+09 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
17 BldNodes - Number of blade nodes (per blade) used for analysis (-)
“…/5MW_Baseline/NRELOffshrBsline5MW_Blade.dat” BldFile(1) - Name of file containing properties for blade 1 (quoted string)
“…/5MW_Baseline/NRELOffshrBsline5MW_Blade.dat” BldFile(2) - Name of file containing properties for blade 2 (quoted string)
“…/5MW_Baseline/NRELOffshrBsline5MW_Blade.dat” BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
97 GBRatio - Gearbox ratio (-)
“NRELOffshrBsline5MW_ITIBarge4_ElastoDyn_Tower.dat” TwrFile - Name of file containing tower properties (quoted string)
30 TStart - Time to begin tabular output (s) (currently unused)
1 NTwGages - Number of tower nodes that have strain gages for output [0 to 9] (-)
10 TwrGagNd - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
1 NBlGages - Number of blade nodes that have strain gages for output [0 to 9] (-)
9 BldGagNd - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
“BldPitch1” - Pitch angles for blades 1, 2, and 3
“BldPitch2” - Pitch angles for blades 1, 2, and 3
“BldPitch3” - Pitch angles for blades 1, 2, and 3
“Azimuth” - Blade 1 azimuth angle
“RotSpeed” - Low-speed shaft and high-speed shaft speeds
“GenSpeed” - Low-speed shaft and high-speed shaft speeds
“NacYaw” - Nacelle yaw angle and nacelle yaw error estimate
“OoPDefl1” - Blade 1 out-of-plane and in-plane deflections and tip twist
“IPDefl1” - Blade 1 out-of-plane and in-plane deflections and tip twist
“TwstDefl1” - Blade 1 out-of-plane and in-plane deflections and tip twist
“OoPDefl2” - Blade 2 out-of-plane and in-plane deflections and tip twist
“IPDefl2” - Blade 2 out-of-plane and in-plane deflections and tip twist
“TwstDefl2” - Blade 2 out-of-plane and in-plane deflections and tip twist
“OoPDefl3” - Blade 3 out-of-plane and in-plane deflections and tip twist
“IPDefl3” - Blade 3 out-of-plane and in-plane deflections and tip twist
“TwstDefl3” - Blade 3 out-of-plane and in-plane deflections and tip twist
“TwrClrnc1” - Tip-to-tower clearance estimate for blades 1, 2, and 3
“TwrClrnc2” - Tip-to-tower clearance estimate for blades 1, 2, and 3
“TwrClrnc3” - Tip-to-tower clearance estimate for blades 1, 2, and 3
“NcIMUTAxs” - Nacelle IMU translational accelerations (absolute) in the nonrotating, shaft coordinate system
“NcIMUTAys” - Nacelle IMU translational accelerations (absolute) in the nonrotating, shaft coordinate system
“NcIMUTAzs” - Nacelle IMU translational accelerations (absolute) in the nonrotating, shaft coordinate system
“TTDspFA” - Tower fore-aft and side-to-side displacements and top twist
“TTDspSS” - Tower fore-aft and side-to-side displacements and top twist
“TTDspTwst” - Tower fore-aft and side-to-side displacements and top twist
“PtfmSurge” - Platform translational surge, sway, and heave displacements
“PtfmSway” - Platform translational surge, sway, and heave displacements
“PtfmHeave” - Platform translational surge, sway, and heave displacements
“PtfmRoll” - Platform rotational roll, pitch and yaw displacements
“PtfmPitch” - Platform rotational roll, pitch and yaw displacements
“PtfmYaw” - Platform rotational roll, pitch and yaw displacements
“PtfmTAxt” - Platform translation accelerations (absolute) in the tower-base coordinate system
“PtfmTAyt” - Platform translation accelerations (absolute) in the tower-base coordinate system
“PtfmTAzt” - Platform translation accelerations (absolute) in the tower-base coordinate system
“RootFxc1” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 1
“RootFyc1” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 1
“RootFzc1” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 1
“RootMxc1” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 1
“RootMyc1” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 1
“RootMzc1” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 1
“RootFxc2” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 2
“RootFyc2” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 2
“RootFzc2” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 2
“RootMxc2” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 2
“RootMyc2” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 2
“RootMzc2” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 2
“RootFxc3” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 3
“RootFyc3” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 3
“RootFzc3” - Out-of-plane shear, in-plane shear, and axial forces at the root of blade 3
“RootMxc3” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 3
“RootMyc3” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 3
“RootMzc3” - In-plane bending, out-of-plane bending, and pitching moments at the root of blade 3
“Spn1MLxb1” - Blade 1 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLyb1” - Blade 1 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLzb1” - Blade 1 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLxb2” - Blade 2 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLyb2” - Blade 2 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLzb2” - Blade 2 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLxb3” - Blade 3 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLyb3” - Blade 3 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“Spn1MLzb3” - Blade 3 local edgewise bending, flapwise bending, and pitching moments at span station 1 (approx. 50% span)
“RotThrust” - Rotor thrust and low-speed shaft 0- and 90-rotating shear forces at the main bearing
“LSSGagFya” - Rotor thrust and low-speed shaft 0- and 90-rotating shear forces at the main bearing
“LSSGagFza” - Rotor thrust and low-speed shaft 0- and 90-rotating shear forces at the main bearing
“RotTorq” - Rotor torque and low-speed shaft 0- and 90-rotating bending moments at the main bearing
“LSSGagMya” - Rotor torque and low-speed shaft 0- and 90-rotating bending moments at the main bearing
“LSSGagMza” - Rotor torque and low-speed shaft 0- and 90-rotating bending moments at the main bearing
“YawBrFxp” - Fore-aft shear, side-to-side shear, and vertical forces at the top of the tower (not rotating with nacelle yaw)
“YawBrFyp” - Fore-aft shear, side-to-side shear, and vertical forces at the top of the tower (not rotating with nacelle yaw)
“YawBrFzp” - Fore-aft shear, side-to-side shear, and vertical forces at the top of the tower (not rotating with nacelle yaw)
“YawBrMxp” - Side-to-side bending, fore-aft bending, and yaw moments at the top of the tower (not rotating with nacelle yaw)
“YawBrMyp” - Side-to-side bending, fore-aft bending, and yaw moments at the top of the tower (not rotating with nacelle yaw)
“YawBrMzp” - Side-to-side bending, fore-aft bending, and yaw moments at the top of the tower (not rotating with nacelle yaw)
“TwrBsFxt” - Fore-aft shear, side-to-side shear, and vertical forces at the base of the tower (platform)
“TwrBsFyt” - Fore-aft shear, side-to-side shear, and vertical forces at the base of the tower (platform)
“TwrBsFzt” - Fore-aft shear, side-to-side shear, and vertical forces at the base of the tower (platform)
“TwrBsMxt” - Side-to-side bending, fore-aft bending, and yaw moments at the base of the tower (platform)
“TwrBsMyt” - Side-to-side bending, fore-aft bending, and yaw moments at the base of the tower (platform)
“TwrBsMzt” - Side-to-side bending, fore-aft bending, and yaw moments at the base of the tower (platform)
“TwHt1MLxt” - Local side-to-side bending, fore-aft bending, and yaw moments at tower gage 1 (approx. 50% elevation)
“TwHt1MLyt” - Local side-to-side bending, fore-aft bending, and yaw moments at tower gage 1 (approx. 50% elevation)
“TwHt1MLzt” - Local side-to-side bending, fore-aft bending, and yaw moments at tower gage 1 (approx. 50% elevation)
[/code]
ServoDyn File
[code]------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
“default” DT - Communication interval for controllers (s) (or “default”)
0 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TPCOn - Time to enable active pitch control (s) [unused when PCMode=0]
2 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
2 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
2 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
1 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TimGenOn - Time to turn on the generator for a startup (s) [used only when GenTiStr=True]
9999.9e-9 VS_RtGnSp - Rated generator speed for simple variable-speed generator control (HSS side) (rpm) [used only when VSContrl=1]
43093.55 VS_RtTq - Rated generator torque/constant generator torque in Region 3 for simple variable-speed generator control (HSS side) (N-m) [used only when VSContrl=1]
9999.9e-9 VS_Rgn2K - Generator torque constant in Region 2 for simple variable-speed generator control (HSS side) (N-m/rpm^2) [used only when VSContrl=1]
9999.9e-9 VS_SlPc - Rated generator slip percentage in Region 2 1/2 for simple variable-speed generator control (%) [used only when VSContrl=1]
0 YawNeut - Neutral yaw position–yaw spring force is zero at this yaw (degrees)
9.02832E+09 YawSpr - Nacelle-yaw spring constant (N-m/rad)
1.916E+07 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
2 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
0 NacYawF - Final yaw angle for override yaw maneuvers (degrees)
---------------------- STRUCTURAL CONTROL --------------------------------------
0 NumBStC - Number of blade structural controllers (integer)
“unused” BStCfiles - Name of the files for blade structural controllers (quoted strings) [unused when NumBStC==0]
0 NumNStC - Number of nacelle structural controllers (integer)
“unused” NStCfiles - Name of the files for nacelle structural controllers (quoted strings) [unused when NumNStC==0]
0 NumTStC - Number of tower structural controllers (integer)
“unused” TStCfiles - Name of the files for tower structural controllers (quoted strings) [unused when NumTStC==0]
0 NumSStC - Number of substructure structural controllers (integer)
“unused” SStCfiles - Name of the files for substructure structural controllers (quoted strings) [unused when NumSStC==0]
“…/5MW_Baseline/ServoData/DISCON_ITIBarge.dll” DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
“DISCON.IN” DLL_InFile - Name of input file sent to the DLL (-) [used only with Bladed Interface]
“DISCON” DLL_ProcName - Name of procedure in DLL to be called (-) [case sensitive; used only with DLL Interface]
“default” DLL_DT - Communication interval for dynamic library (s) (or “default”) [used only with Bladed Interface]
false DLL_Ramp - Whether a linear ramp should be used between DLL_DT time steps [introduces time shift when true] (flag) [used only with Bladed Interface]
9999.9 BPCutoff - Cutoff frequency for low-pass filter on blade pitch from DLL (Hz) [used only with Bladed Interface]
0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
0 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
0 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
0 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
0 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
0 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
0 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
True SumPrint - Print summary data to .sum (flag) (currently unused)
“GenPwr” - Electrical generator power and torque
“GenTq” - Electrical generator power and torque
[/code]
Error
BldPitch
PtfmPitch
Are there some instructions about the linearization of offshore wind turbines?
Best regards!
