Dear All,
I performed linearization analysis using FAST (3-bladed NREL turbine with blade properties from ‘UPWIND’ project) for two scenarios:
Scenario 1): No imbalance in 3 blades
Scenario 2): 5%, 0 % and -5% Imbalance in Blades
Attached is a excel sheet Campbell.xlsx for these two scenarios. I see there is a ‘slight increase’ in frequencies of blade and tower modes as we move from scenario 1 to scenario 2. My parameters are as follows:
AnalMode = 2
YCMode = 0
TMax = 9900
PCMode = 0
GenTiStr = True
GenTiStp = True
TimGenOn = 0.0
TimGenOf = 9999.9
THSSBrDp = 9999.9
TiDynBrk = 9999.9
TTpBrDp(i) = 9999.9
TYawManS = 9999.9
TPitManS(i) = 9999.9
TBDepISp(i) = 9999.9
StallMod = STEADY
InfModel = EQUIL
Wind: 3.5m/s hub higher steady wind (vertical shear)
Enabled DOF:
FlapDOF1
FlapDOF2
EdgeDOF
DrTrDOF
GenDOF
YawDOF
TwFADOF1
TwFADOF2
TwSSDOF1
TwSSDOF2
CompAero
RotSpeed = 7 rpm
CalcStdy = True
TrimCase = 2 (As indicated in FAST Manual for Variable Speed, Region 2 Linearization)
DispTol = 0.0001
VelTol = 0.00001
NAzimStep = 12
NInputs = 2
CntrlInpt = 3,4
NDisturbs = 2
Disturbnc = 1, 5
I have three questions:
i) Why is there a drop in frequency; I would expect unbalanced case to be more prone to resonance than a balanced case?
ii) Could you help me in deciphering the modes from this.
Mode----> Description
1,2----> Rigid modes of Generator
3---->1st Tower Fore-aft
4----> 1st Tower side to side
5----> Drive train torsion OR 1st Blade Asymmetric Flapwise Yaw??
6,7—>1st Blade Asymmetric Flapwise Pitch and 1st Blade Collective Flap
8,9,10—> 1st Blade Edgewise Pitch, Yaw, Collective??
11,12,13,14,15,16,17–> ???
CampbellDiagram_lin_1_5%_imbalance.xls (265 KB)
CampbellDiagram_lin_1_No_imbalance.xls (256 KB)
iii) As elasticity of yaw system and tower are taken into account the mass imbalance should induce a tower torsion instability, which should effect the blades? Is it true?
Thanks a lot,
Neelabh
