I am performing linearization analysis using FAST (3-bladed NREL 1.5 MW). I want to linearize a wind turbine with pitch imbalance, e.g. an pitch offset of 0° / 0.3° / -0.3° for the three blades. It is appreciated if someone could give me a hint for linearizing thus a wind turbine by using FAST.
Thanks in advance.
Best wishes to you all
Chao Yang
Aalborg university, Denmark
Dear Chao,
A similar question was asked and answered in the following forum topic: Linearization in FAST with unbalanced Rotor.
Thank you very much for your fast reply.
I have read your mentioned topic “viewtopic.php?f=4&t=866”. But the topic is about lineariztion of an unbalance wind turbine with different blade mass. Now what i want to do is to linearize a wind turbine with different pitch mounting angle. What i mean about the so-called pitch mounting angle is the initial pitch angle when we mounting the three blades.
Hope you could give me some advises on how to linearize thus a wind turbine with different pitch mounting angle, e.g. 0° / 0.3° / -0.3° for the three blades.
Thanks again and best wishes.
Chao Yang
Dear Chao,
You can set different initial pitch angles so as to create an aerodynamic imbalance in a FAST linearization analysis except when using the TrimCase = 3 (find collective pitch) option for calculating a periodic steady state solution.
Thanks a lot for your guidance. I will try it.
Kind regards
Chao Yang
Aalborg University, Denmark
