I am trying to run 10 MW and 15 MW wind turbines, but I have some problems as follows:
For 10 MW;
FAST_InitializeAll:SrvD_Init:BladedInterface_Init:The dynamic library
.\path2rosco/libdiscon.dylib could not be loaded. Check that the file exists in the specified
location and that it is compiled for 64-bit applications.
For 15 MW;
FAST_InitializeAll:HydroDyn_Init:HydroDynInput_ProcessInitData: A requested output channel is
invalid
/usr/share/miniconda3/envs/test/lib/libdiscon.so could not be loaded. Check that the file exists
in the specified location and that it is compiled for 64-bit applications.
I believe I compiled my openfast correctly because “openfast\reg_tests\r-test-main\glue-codes\openfast\5MW_OC3Spar_Linear\5MW_OC3Spar_Linear.fst” works perfectly. I suspect that I put the files for 10 MW and 15 MW wind turbines in the wrong directory. Where should I put these files? Or is this issue about ROSCO? Should I compile it as well?
PS: I am using Windows.
Kaan Akkaş
