Hello!
I’m looking at NREL’s OC3-PhaseIV results and I have a question about the generator torque in simulations 5.2 and 5.3. The VS-controller developed in the offshore reference turbine document (NREL/TP-500-38060) allows for a maximum gen-torque of 10% above rated (47.4 kN-m). However the OC3 results show this maximum gen-torque to be only the rated (43.09 kN-m). Can someone help explain this for me?
Thanks!
Sean Q
Dear Sean,
When the NREL 5-MW turbine is placed atop the OC3-Hywind spar, modifications are needed to the baseline controller to ensure stable operation. One change made was to change the torque control above rated from a constant power to a constant torque region; in effect, the maximum torque is limited to rated torque. See Section 6 of the OC3-Hywind specifications document for more information: nrel.gov/docs/fy10osti/47535.pdf.
Jason,
Thanks! All these years and I never noticed that section at the end of the floating platform document.
Sean Q
